Inspiron blank screen after boot splash with later kernels
After an update a month or more ago, I think when the the switch to the 6.2 kernel series occurred, I stopped being able to boot my system, an Inspiron 7610. I get the boot menu, then the loading splash screen, then a blank screen (apart from a KDFONTOP message or similar). I can boot an LTS kernel, and that is what I'm using now. Unfortunately, I can't post a garuda-inxi of the failed system as I can't access it. The data for my working system is below. I haven't found any similar references, which is surprising, but does anyone have any ideas? I have tried with both the latest zen kernel and a recent vanilla kernel with the same result.
The boot parameters for the problem boot and the current system appear to be the same.
  Kernel: 6.1.28-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=f02c5d5a-67c0-42e2-bb12-69a48f130c56 rw [email protected]
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 info: latte-dock
    wm: kwin_x11 dm: SDDM Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: Dell product: Inspiron 16 7610 v: N/A serial: <filter>
    Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 1VFRT8 v: A01 serial: <filter> UEFI: Dell v: 1.8.0
    date: 05/09/2022
  ID-1: BAT0 charge: 44.2 Wh (100.0%) condition: 44.2/54.9 Wh (80.4%)
    volts: 12.5 min: 11.4 model: SMP DELL P8P1P95 type: Li-poly serial: <filter>
    status: full
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
  Info: model: 11th Gen Intel Core i5-11400H socket: U3E1 bits: 64
    type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    microcode: 0x44
    L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 2013 high: 2700 min/max: 800/4500 base/boost: 2673/4500
    ext-clock: 100 MHz cores: 1: 1064 2: 2700 3: 2700 4: 2700 5: 1119 6: 2700
    7: 2700 8: 2700 9: 1032 10: 1031 11: 2700 12: 1017 bogomips: 64536
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
    v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
    active: HDMI-A-1,eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 0000:00:02.0
    chip-ID: 8086:9a68 class-ID: 0300
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Dell
    driver: nouveau v: kernel non-free: 530.xx+ status: current (as of 2023-05)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22
    bus-ID: 0000:01:00.0 chip-ID: 10de:25a2 class-ID: 0302
  Device-3: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3
    chip-ID: 1bcf:2a02 class-ID: 0e02 serial: <filter>
    compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
  Screen-1: 0 s-res: 6912x2160 s-dpi: 96 s-size: 1827x571mm (71.93x22.48")
    s-diag: 1914mm (75.36")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: top-right model: Philips PHL 288E2
    serial: <filter> built: 2022 res: 3840x2160 hz: 60 dpi: 157 gamma: 1.2
    size: 621x341mm (24.45x13.43") diag: 708mm (27.9") ratio: 16:9 modes:
    max: 3840x2160 min: 720x400
  Monitor-2: eDP-1 pos: primary,bottom-l model: AU Optronics 0xc99e
    built: 2020 res: 3072x1920 hz: 60 dpi: 227 gamma: 1.2
    size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
    modes: 3072x1920
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics (TGL GT1)
    direct-render: Yes
  Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:43c8 class-ID: 0401
  API: ALSA v: k6.1.28-1-lts status: kernel-api tools: N/A
  Server-2: PipeWire v: 0.3.70 status: n/a (root, process) with:
    bus-ID: 0000:00:14.3 chip-ID: 8086:43f0 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:5 chip-ID: 8087:0026
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 6.83 TiB used: 585.68 GiB (8.4%)
    fw-rev: 2B2QEXM7 temp: 44.9 C scheme: GPT
  SMART: yes health: PASSED on: 12d 14h cycles: 416
    read-units: 11,648,360 [5.96 TB] written-units: 6,811,326 [3.48 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Toshiba model: KBG40ZNS512G
    NVMe KIOXIA 512GB size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 10410106 temp: 55.9 C scheme: GPT
  SMART: yes health: PASSED on: 186d 4h cycles: 419
    read-units: 24,814,856 [12.7 TB] written-units: 22,270,179 [11.4 TB]
    model: WD50NMZM-59A8XS1 size: 4.55 TiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 2007 scheme: GPT
  ID-1: / raw-size: 39.96 GiB size: 39.96 GiB (100.00%)
    used: 25.16 GiB (62.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 110.8 MiB (22.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-3: /home raw-size: 1.72 TiB size: 1.72 TiB (100.00%)
    used: 560.41 GiB (31.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3
    maj-min: 259:3
  ID-4: /var/log raw-size: 39.96 GiB size: 39.96 GiB (100.00%)
    maj-min: 259:2
  ID-5: /var/tmp raw-size: 39.96 GiB size: 39.96 GiB (100.00%)
    maj-min: 259:2
  ID-1: swap-1 type: zram size: 31.1 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 32.27 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
  System Temperatures: cpu: 38.0 C mobo: N/A
  Processes: 350 Uptime: 1h 5m wakeups: 8 Memory: available: 31.1 GiB
  used: 5.44 GiB (17.5%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1642 libs: 399 tools: octopi,pamac,paru,yay pm: flatpak pkgs: 0
  Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: alacritty
  inxi: 3.3.27
  System install date:     2023-04-21
  Last full system update: 2023-05-14
  Windows dual boot:       Yes
Welcome :slight_smile:
Just try this
Text consoles are not available with the current kernel, so I can't run commands from that environment. The absence of text consoles also suggests to me that the boot has stalled or failed at some early stage. I have run all the suggested commands from the working installation.
Another note: I can boot into recovery mode from the current kernel, so the basic kernel is working. In consequence, I think it is likely to be some sort of graphics driver problem.
The problem has persisted for an extended period through many updates, so cannot really be incomplete mirrors. sudo dkms autoinstall does nothing. garuda-update has been run multiple times without impact on the issue.
Did you chroot via live ISO?
The live ISO I used was bootable after install as long as the install disk was booted using free drivers. The problem only shows after the first update following install. I've done this experiment a couple of times.
Ok, I have no experience with dual GPU notebooks, did you check the forum about?
since you have no problems booting with the lts kernel could it be that you have a corrupt download for that other kernel. :thinking:
try reinstalling that kernel along with its headers for eg if the name of kernel is linux-zen then
first you should clean your cache directory so that pacman pulls a fresh copy of linux-zen instead of just reinstalling the corrupt package
sudo paccache -rk0
then redownload the package
garuda-update -- linux-zen linux-zen-headers
Try rebuilding the initramfs. From the chroot, run:
mkinitcpio -P
Or:
This should automatically kick off the initramfs generation as well.
If you rebuild the image and still cannot boot, we will have to take a look at /etc/mkinitcpio.conf to check for a bad hooks configuration.
Ok, so I think I have this fixed. Re-installing the kernel didn't work, but blacklisting and completely disabling the nouveau driver seems to have fixed the issue - for me at least as at the moment I don't use the nvidia card. Thanks to SGS for prompting this experiment. This will also likely save some watts when on battery as the nvidia card is now powered down.
Interesting--that's an odd one.
If you ever want to start using the driver, installing the proprietary version is likely to work since it also blacklists Nouveau as part of the installation.
You may also be interested in this guide, which explains how to set up the dGPU so it is only used when you explicitly call for it (starting a game or something, for example)--otherwise the iGPU is used, to conserve resources as you mentioned:
