Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0db6fcc5-4934-4f6b-862c-21893cbeec24 rw rootflags=subvol=@
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: LENOVO product: 82LM v: IdeaPad 5 14ALC05
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 14ALC05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: G5CN20WW(V1.08)
date: 06/30/2021
ID-1: BAT1 charge: 50.9 Wh (87.0%) condition: 58.5/56.5 Wh (103.6%)
volts: 12.4 min: 11.5 model: 0x53 0x4D 0x50 0x00 0x32 0x30 0x 0x4C 0x31
0x39 0x4D 0x33 0x50 0x5650
type: Li-ion serial: <filter> status: Discharging cycles: 4
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1398 high: 1418 min/max: 1400/4056 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1418 11: 1397
12: 1397 bogomips: 50307
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:164c class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 174f:2459 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: gnome-shell driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :1 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 2000
bus-ID: 03:00.0 chip-ID: 10ec:c822 class-ID: 0280
bus-ID: 3-4:3 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 18 state: up address: <filter>
Local Storage: total: 476.94 GiB used: 18.61 GiB (3.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDHBA512QFD
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 0002P6LN
temp: 36.9 C scheme: GPT
used: 18.61 GiB (3.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.03 GiB used: 882.8 MiB (5.7%)
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
Processes: 355 Uptime: 2d 18h 3m wakeups: 21592 Memory: 15.03 GiB
used: 5.15 GiB (34.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1147 lib: 311 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-02-10
Last full system update: 2022-02-15
Hey there! On my Lenovo Ideapad 5 14 something, when i press the insert key it toggles airplane mode, i have to press fn
. The issue actually persists when i hit the FnLock key, which should invert having to press fn for the actual actions. Is there any place where i can disable this functionality? I would like for my insert key to work as normal, without it running the airplane mode command.
Any help will be much appreciated
