Mod edit:
My input is not dected like internal microphone is not detected i was on garuda then i tried every dirsto but nothing fixed.
Pls help me now i am on fedora even this too not working why i am requesting because i used garuda linux has my first linux and it is my fav all of the time
╭─garuda@garuda in ~ as 🧙
╰─λ garuda-inxi
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64
lang=en_US keytable=us tz=UTC misobasedir=garuda
root=miso:LABEL=GARUDA_HYPRLAND_BIRDOFPREY quiet systemd.show_status=1
checksum=y driver=nonfree nouveau.modeset=0 i915.modeset=1
radeon.modeset=1
Desktop: Hyprland v: 0.39.1 with: waybar tools: avail: swayidle,swaylock
vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: HP product: Victus by HP Gaming Laptop 15-fb1xxx v: N/A
Mobo: HP model: 8C30 v: 88.14 serial: <superuser required>
part-nu: 8L083PA#ACJ uuid: <superuser required> UEFI: AMI v: F.03
date: 08/10/2023
ID-1: BAT0 charge: 50.3 Wh (100.0%) condition: 50.3/50.3 Wh (100.0%)
volts: 13.1 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 210
Info: model: AMD Ryzen 5 7535HS with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 567 high: 1407 min/max: 400/4603 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1397 2: 400 3: 400
4: 1407 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
bogomips: 79059
Device-1: NVIDIA GA107 [GeForce RTX 2050] vendor: Hewlett-Packard
driver: nvidia v: 550.76 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 4 speed: 16 GT/s
lanes: 8 link-max: lanes: 16 ports: active: none empty: HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:25ad class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: Hewlett-Packard
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1
bus-ID: 06:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 55.0 C
Device-3: Chicony HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 04f2:b766
compositor: Hyprland v: 0.39.1 driver: X: loaded: amdgpu,nvidia
gpu: amdgpu display-ID: 1
Monitor-1: eDP-1 model: BOE Display 0x094d built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 scale: 1 size: 344x194mm (13.54x7.64")
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:1681 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 2050 driver: nvidia v: 550.76
device-ID: 10de:25ad surfaces: xcb,xlib,wayland device: 2 type: cpu
v: 24.0.5-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 13d3:3567
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
Local Storage: total: 505.61 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN810 SDCPNRY-512G-1006 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Cruzer Blade
size: 28.67 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: swap-1 type: zram size: 6.97 GiB used: 5 MiB (0.1%) priority: 100
System Temperatures: cpu: 68.2 C mobo: 42.0 C gpu: amdgpu temp: 57.0 C
Fan Speeds (rpm): fan-1: 3189 fan-2: 2705
Memory: total: 8 GiB note: est. available: 6.97 GiB used: 3.22 GiB (46.2%)
Processes: 305 Power: uptime: 4m states: freeze,mem,disk suspend: s2idle
image: 2.75 GiB Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1316 libs: 380 tools: pacseek,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: foot
inxi: 3.3.34
System install date: 2025-02-18
Last full system update: 2025-02-18 ↻
