Dear All,
first of all I would like to thank you for any kind of help you'll give to me and for your time, as well, in reading my issue.
Some now and then, randomly and with no relevant reason, I get stuck in booting as per subject.
I already went through the forum but did not find same situation (at least not able to....)
the abnormal thing is that this happens randomly with both kernels I have installed (zen and lts)
moreover, once it get stucked, I switch the laptop off and on again and might be that the issue is there again, but also might happen that the system boots without problems.
Since I installed Garuda I always used zen kernel and some now and then got the problem; I started hence to use LTS kernel and, for some time, it seemd to be the solution (even loosing the advantages of zen kernel).
yesterday I got the issue for the first time on the LTS kernel as well.
I am now writing from Garuda since, as written above, I made a reboot and it worked.
Thank you!
apologies for beeing tooooooo long.
Gionez.
here below the system config.
Kernel: 5.15.82-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=fc43e984-4019-4e90-b8a6-b7d891b04247 rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: GL753VD v: 1.0
Mobo: ASUSTeK model: GL753VD v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GL753VD.308 date: 04/29/2019
ID-1: BAT0 charge: 22.6 Wh (53.3%) condition: 42.4/48.2 Wh (87.8%)
volts: 13.3 min: 14.4 model: Simplo SDI ICR18650 type: Li-ion
serial: <filter> status: discharging cycles: 33
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3534 high: 3606 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 3524 2: 3525 3: 3518
4: 3528 5: 3606 6: 3587 7: 3487 8: 3498 bogomips: 44798
vulnerable
prctl and seccomp
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-1,eDP-1
empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8d
class-ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-11:4 chip-ID: 13d3:5666 class-ID: 0e02 serial: <filter>
Screen-1: 0 s-res: 2315x2280 s-dpi: 96 s-size: 611x602mm (24.06x23.70")
s-diag: 858mm (33.77")
Monitor-1: DP-1 pos: top-right model: Dell U2413 serial: <filter>
built: 2013 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
Monitor-2: eDP-1 pos: primary,bottom-l model: LG Display 0x04e8
built: 2016 res: 1920x1080 hz: 60 dpi: 128 gamma: 1.2
size: 382x215mm (15.04x8.46") diag: 438mm (17.3") ratio: 16:9
modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 630 (KBL
GT2) direct render: Yes
Device-1: Intel CM238 HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound API: ALSA v: k5.15.82-1-lts running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-9:3 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 1.14 TiB used: 17.95 GiB (1.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 MTFDDAV256TBN
type: SSD serial: <filter> rev: A020 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
type: SSD serial: <filter> rev: 043 scheme: MBR
ID-1: / raw-size: 150 GiB size: 150 GiB (100.00%) used: 17.92 GiB (11.9%)
fs: btrfs dev: /dev/sdb1 maj-min: 8:17
used: 30.7 MiB (12.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 150 GiB size: 150 GiB (100.00%)
used: 17.92 GiB (11.9%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-4: /var/log raw-size: 150 GiB size: 150 GiB (100.00%)
ID-5: /var/tmp raw-size: 150 GiB size: 150 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.51 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 65.0 C pch: 48.5 C mobo: N/A
Fan Speeds (RPM): cpu: 3200
Processes: 251 Uptime: 12m wakeups: 1 Memory: 15.51 GiB used: 3 GiB (19.3%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: pm: pacman pkgs: 1492 libs: 375
tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-11-15
Last full system update: 2022-12-10
