Description:
I’ve been experiencing some programs not working correctly, when using KDE 6 and Wayland. I think the problem might be related to QT, or something like that, because both of the programs where I’ve found things not working correctly use QT.
The main problem:
the lack of a menu bar. The applications where I’ve encountered this problem lack a button block at the top of the program with most of the functionality. As a result, the functionality of the program becomes limited to the interface buttons only.
Examples of applications in which I have encountered this problem:
Additional problem:
In the HLAM program the window for model viewer is cropped to 1/4 of the size of the viewing area.
I contacted the developer via an issue on Github and he was unable to reproduce this issue.
Additional information:
- There are no such Problems when using X11.
- I have an additional distro (Endeavour OS) on a separate SSD - I only use it for testing or something like that. It also runs KDE Plasma 6 and Wayland and uses the Arch package base. So, running those two applications on it, I didn’t find the above problems. So it seems to me that the problem is not in QT or Wayland, but somewhere in Garuda.
garuda-inxi:
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4f0d418e-e934-494c-a4ff-99fda39dd558 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop System: HUANANZHI X99 product: N/A v: NALEX
Mobo: HUANANZHI model: X99-BD4 v: V1.1, NALEX serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: 5.11
date: 11/01/2020
Info: model: Intel Xeon E5-2666 v3 bits: 64 type: MT MCP arch: Haswell
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3F (63) stepping: 2 microcode: 0x49
Topology: cpus: 1x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB desc: 10x256 KiB
L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 3497 high: 3500 min/max: 1200/3500 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3492 2: 3494 3: 3500
4: 3500 5: 3493 6: 3500 7: 3500 8: 3500 9: 3500 10: 3500 11: 3500 12: 3500
13: 3500 14: 3500 15: 3500 16: 3492 17: 3492 18: 3492 19: 3500 20: 3500
bogomips: 115737
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] driver: nvidia v: 550.67
2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: none off: DP-2,HDMI-A-1 empty: DP-1,DP-3
bus-ID: 03:00.0 chip-ID: 10de:2482 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia d-rect: 5047x2389
display-ID: 0
Monitor-1: DP-2 pos: primary,top-left res: 3127x1309 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-r res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti driver: nvidia v: 550.67 device-ID: 10de:2482
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-2: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device
lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 0c76:1617 class-ID: 0300
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: outline-tun0 state: down mac: N/A
Local Storage: total: 1.61 TiB used: 716.59 GiB (43.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KingSpec model: NX-512
lanes: 4 tech: SSD serial: <filter> fw-rev: SN08381 temp: 39.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS721025CLA682
tech: HDD rpm: 7200 serial: <filter> fw-rev: A41A scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Patriot model: P210 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 002 scheme: GPT
used: 133.62 GiB (28.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.24 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 33.0 C mobo: N/A
Memory: total: 32 GiB available: 31.24 GiB used: 3.39 GiB (10.8%)
Processes: 446 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1745 libs: 506 tools: octopi,pamac,paru
pm: appimage pkgs: 0 Compilers: clang: 17.0.6 gcc: 13.2.1 alt: 12
Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-08
Last full system update: 2024-03-24
