Hey everyone, I'm not new to Garuda here but after updating my system about an hour ago I've been running into a few snags with my cursor. Although I managed to get it all set to the specific theme I wanted, thanks to the cursor themes page on the Arch Wiki, the one thing that still eludes me in Cinnamon however is setting a consistent cursor size, this issue has persisted for me well before the theme issue I mentioned.
I am currently using the Nordzy-cursors-white cursor theme and unfortunately the size slider in mouse and touchpad section doesn't apply to all windows and programs, as most applications such as Steam and Lutris will set the cursor to its smallest setting, when I want the cursor to be a little bigger across the board.
Spent a few hours scouring the internet on and off for the past couple of weeks and I'm seemingly at a dead stop so I thought I'd ask here. It's not a major issue by any means but it would be nice to have my cursor be a little bigger no matter what I'm hovering over.
Kernel: 6.0.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=d1811421-52d9-438e-bac3-684cad066ec0 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: Cinnamon v: 5.6.4 tk: GTK v: 3.24.35 wm: muffin vt: 7 dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Tactus product: Custom v: N/A
Mobo: ASUSTeK model: ROG STRIX X570-E GAMING WIFI II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4101
date: 09/10/2021
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA201204
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3686 high: 3700 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3700 4: 3700 5: 3700 6: 3700 7: 3700 8: 3700 9: 3700 10: 3700 11: 3700
12: 3700 13: 3700 14: 3700 15: 3700 16: 3700 17: 3593 18: 3593 19: 3700
20: 3700 21: 3700 22: 3700 23: 3700 24: 3593 bogomips: 177262
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Gigabyte
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 0c:00.0 chip-ID: 1002:73bf
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 777mm (30.58")
Monitor-1: DP-2 mapped: DisplayPort-1 model: Gigabyte AORUS FI32Q
serial: <filter> built: 2021 res: 2560x1440 dpi: 93 gamma: 1.2
size: 698x392mm (27.48x15.43") diag: 801mm (31.5") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 6800 XT (navi21
LLVM 14.0.6 DRM 3.48 6.0.11-zen1-1-zen) direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 1-3:2 pcie: gen: 4 chip-ID: 19f7:0003 class-ID: 0300 speed: 16 GT/s
lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28 class-ID: 0403
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: RODE Microphones NT-USB type: USB
Device-4: Creative Pebble V3 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2:2 chip-ID: 041e:3272
Sound API: ALSA v: k6.0.11-zen1-1-zen running: yes
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0608
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: MediaTek Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-6:4 chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
Local Storage: total: 8.19 TiB used: 3.8 TiB (46.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: FireCuda 530
ZP1000GM30013 size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: SU6SM001
temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
type: SSD serial: <filter> rev: 2B6Q
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000NE001-2MA101
type: HDD rpm: 7200 serial: <filter> rev: EN01
used: 125.6 GiB (13.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.71 GiB used: 768 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.0 C mobo: 33.0 C gpu: amdgpu temp: 67.0 C
mem: 66.0 C
Processes: 469 Uptime: 12m wakeups: 3 Memory: 62.71 GiB
used: 5.23 GiB (8.3%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: 1454 pm: pacman pkgs: 1442
libs: 412 tools: paru pm: flatpak pkgs: 12 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-11-20
Last full system update: 2022-12-08
