Hello.
After applying updates on Dec 5th, 2023 the display power management leaves one monitor turned on the second switched off. When system wakes up both monitors are in ‘Mirror displays’ mode.
Kernel: 6.1.59.16.realtime1-1-rt-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-rt-lts
root=UUID=b8c044ba-3855-4296-80c1-38218b0791fd rw rootflags=subvol=@ quiet quiet
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm v: 4.18.0 vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Compulab model: fitlet2 v: 1.31 serial: <superuser required>
UEFI: American Megatrends v: FLT2.TPM.0.46.02.01 date: 05/24/2021
Info: model: Intel Atom E3950 bits: 64 type: MCP arch: Goldmont level: v2 built: 2016
process: Intel 14nm family: 6 model-id: 0x5C (92) stepping: 9 microcode: 0x48
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB desc: d-4x24 KiB; i-4x32 KiB
L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1318 high: 2000 min/max: 800/2000 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 2000 2: 1674 3: 800 4: 800 bogomips: 12748
Device-1: Intel Apollo Lake [HD Graphics 505] driver: i915 v: kernel arch: Gen-9
process: Intel 14n built: 2015-16 ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1 bus-ID: 00:02.0
chip-ID: 8086:5a84 class-ID: 0300
Display: x11 server: X.Org v: 21.1.9 compositor: xfwm v: 4.18.0 driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,left model: HP 25es serial: <filter>
built: 2017 res: 1920x1080 hz: 60 dpi: 88 gamma: 1.2 size: 553x309mm (21.77x12.17")
diag: 633mm (24.9") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: right model: HP 25es serial: <filter> built: 2018
res: 1920x1080 hz: 60 dpi: 88 gamma: 1.2 size: 553x309mm (21.77x12.17") diag: 633mm (24.9")
API: Vulkan v: 1.3.269 layers: 5 device: 0 type: integrated-gpu name: Intel HD Graphics 505
(APL 3) driver: mesa intel v: 23.2.1-arch1.2 device-ID: 8086:5a84 surfaces: xcb,xlib device: 1
type: cpu name: llvmpipe (LLVM 16.0.6 128 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster driver: snd_hda_intel
v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:5a98 class-ID: 0403
API: ALSA v: k6.1.59.16.realtime1-1-rt-lts status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
Device-1: Intel I211 Gigabit Network driver: igb v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 01:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel I211 Gigabit Network driver: igb v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 8086:1539 class-ID: 0200
Device-3: Intel I211 Gigabit Network driver: igb v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: c000 bus-ID: 03:00.0 chip-ID: 8086:1539 class-ID: 0200
IF-ID-1: eno1 state: down mac: <filter>
Local Storage: total: 119.24 GiB used: 30.44 GiB (25.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: BIWIN model: SSD size: 119.24 GiB block-size:
physical: 5
12 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 2A scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 30.44 GiB (25.6%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 30.44 GiB (25.6%) fs: btrfs
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 30.44 GiB (25.6%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 30.44 GiB (25.6%)
ID-1: swap-1 type: zram size: 7.4 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 316 Uptime: 13h 39m wakeups: 0 Memory: total: 8 GiB note: est. available: 7.4 GiB
used: 2 GiB (27.0%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: pm: pacman pkgs: 1485 libs: 407 tools: pamac,paru Client: shell wrapper
v: 5.2.21-release inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-03-10
Last full system update: 2023-12-06 ↻
