Hey Guys,
i need your help and knowledge again, sorry for that.
I run Garadu Linux and i have noticed, that the sound output over the internal speaker is very bad.
With very bad i mean to much bass, dull (i don’t know that this is right the right word for that) and the speaker begins to clutter around 40 till 50 %.
I have installed besides pipewire
the JACK Support. But it doesn’t help. And other combinations doesn’t work on my laptop.
Here are the output of garuda-inxi
Kernel: 6.6.0-rc1-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
root=UUID=2b867869-1b5c-433f-84da-0008fde9aaf5 rw rootflags=subvol=@
intel_pstate=passive intel_pstate=no_hwp usbcore.autosuspend=-1
ipv6.disable=1 quiet quiet rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Laptop System: ASUSTeK product: ROG Strix G733ZW_G733ZW v: 1.0
Mobo: ASUSTeK model: G733ZW v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G733ZW.324 date: 02/21/2023
ID-1: BAT0 charge: 83.2 Wh (100.0%) condition: 83.2/90.0 Wh (92.5%)
volts: 17.0 min: 15.9 model: AS3GWYF3KC GA50358 type: Unknown
serial: <filter> status: full
Info: model: 12th Gen Intel Core i9-12900H bits: 64 type: MST AMCP
microcode: 0x42C
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 930 high: 5000 min/max: 400/5000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 773 2: 400 3: 400 4: 400
5: 711 6: 400 7: 400 8: 400 9: 400 10: 400 11: 736 12: 400 13: 400
14: 1070 15: 400 16: 400 17: 2300 18: 2820 19: 400 20: 5000
bogomips: 116780
Device-1: Intel Alder Lake-P Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: none empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:46a6
class-ID: 0380
Device-2: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] vendor: ASUSTeK
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:24a0 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau,nvidia
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915,nvidia display-ID: :0
Screen-1: 0 s-res: 2560x1440 s-dpi: 171 s-size: 380x210mm (14.96x8.27")
s-diag: 434mm (17.09")
Monitor-1: DP-2 pos: primary res: 2560x1440 dpi: 171
size: 380x210mm (14.96x8.27") diag: 434mm (17.09") modes: N/A
Monitor-2: None-2-1 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce RTX 3070
Ti Laptop GPU/PCIe/SSE2 direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
API: ALSA v: k6.6.0-rc1-1-mainline status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s port: 3000
bus-ID: 2e:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp46s0 state: down mac: <filter>
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033 class-ID: e001
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 1.86 TiB used: 52.67 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Micron model: 3400 MTFDKBA1T0TFH
lanes: 4 tech: SSD serial: <filter> fw-rev: P7MA001 temp: 29.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-1T00-1014 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 21103900 temp: 28.9 C scheme: GPT
used: 52.67 GiB (5.5%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 31.01 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nvidia temp: 44 C
Fan Speeds (rpm): cpu: 5600
Processes: 408 Uptime: 10m wakeups: 2 Memory: total: 32 GiB
available: 31.01 GiB used: 4.25 GiB (13.7%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: 1584 pm: pacman pkgs: 1511 libs: 367
tools: gnome-software,octopi,pamac,paru pm: flatpak pkgs: 73 Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.29
System install date: 2023-09-14
Last full system update: 2023-09-17
What i can try to get an louder, clearer sound with more heights and less bass?
Thank you very much for reading and answering. Greetings from Germany.
