Kernel: 6.0.3-2-cachyos arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=952eaeec-7025-4a75-845b-9396911526a6 rw rootflags=subvol=@
resume=UUID=fdc5ecaf-2802-4a71-9089-200bfcfa40a3 loglevel=3
mitigations=off sysrq_always_enabled=1 systemd.unified_cgroup_hierarchy=1
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 20BU000AUS v: ThinkPad T450
Mobo: LENOVO model: 20BU000AUS v: SDK0E50510 WIN
serial: <superuser required> UEFI-[Legacy]: LENOVO v: JBET73WW (1.37 )
date: 08/14/2019
ID-1: BAT0 charge: 17.6 Wh (100.0%) condition: 17.6/23.5 Wh (74.8%)
volts: 12.5 min: 11.4 model: LGC 45N1113 type: Li-ion serial: <filter>
status: full
ID-2: BAT1 charge: 8.8 Wh (50.6%) condition: 17.4/23.2 Wh (74.8%)
volts: 12.0 min: 11.1 model: SANYO 45N1775 type: Li-ion serial: <filter>
status: charging
Info: model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2352 high: 2474 min/max: 500/2900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2474 2: 2295 3: 2295
4: 2344 bogomips: 18379
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable
Type: tsx_async_abort status: Vulnerable
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: Lite-On Integrated Camera type: USB driver: uvcvideo
bus-ID: 2-8:4 chip-ID: 04ca:703c class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: eDP-1 model: AU Optronics 0x303e built: 2012 res: 1600x900
hz: 60 dpi: 132 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1600x900
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa
22.2.1 direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
Sound API: ALSA v: k6.0.3-2-cachyos running: yes
Device-1: Intel Ethernet I218-LM vendor: Lenovo driver: e1000e v: kernel
port: 3080 bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095b class-ID: 0280
IF: wlan0 state: up mac: <filter>
IF-ID-2: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
bus-ID: 2-7:3 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 238.47 GiB used: 122.21 GiB (51.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power model: SPCC Solid State
Disk size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 91.3 scheme: MBR
ID-1: / raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 122.21 GiB
(53.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 122.21
GiB (53.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 122.21
ID-4: /var/tmp raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 122.21
ID-1: swap-1 type: zram size: 7.47 GiB used: 347.2 MiB (4.5%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 60.0 C pch: 53.5 C mobo: N/A
Fan Speeds (RPM): fan-1: 3598
Processes: 230 Uptime: 54m wakeups: 1 Memory: 7.47 GiB used: 4.05 GiB
(54.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1987
libs: 387 tools: aura,octopi,paru Shell: fish v: 3.5.1 running-in: tilix
inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-10-04
Last full system update: 2022-10-23 ↻
I'm using tilix
for the console and when I try to run tilix -q
to run in quake mode (opening the dropdown console window), it opens maximized instead of only taking up 40% of the top of the screen.
Is there some setting that forces all windows to open maximized or something?
How do I get tilix --quake
