Create account, login to https://www.reddit.com.
Observe the dark formatting is making some menu text, such as the one below the left top reddit logo illegible.
Please post your garuda-inxi as requested by the template.
Since Iām definitely not going to create a reddit account to check this, firedragon has darkreader installed and activated by default. Have you ever tried to disable this extension? Does the same issue happen for example with floorp or firefox with darkreader enabled/disabled?
I have tested in Floorp and FireDragon with Dark Reader and found no issue
It is related to darkreader for sure, but also the browser. In FLOORP with darkreader same settings reddit (when logged in) shows the top left menu text. For FireDragon it does not.
With darkreader disabled these show normally in both browsers. For FireDragon I disabled all other extensions, but no change.
I am using Ubuntu actually Ubuntu 24.10, Wayland, Linux 6.14.0-1-t2-oracular.
I wish I could share images to show it.
inxi -Faz is enough for us in this case. ![]()
You can use an external pic hoster and share the link here.
Kernel: 6.14.0-1-t2-oracular arch: x86_64 bits: 64 compiler: gcc v: 14.2.0
parameters: BOOT_IMAGE=/vmlinuz-6.14.0-1-t2-oracular
root=/dev/mapper/ubuntu--vg-ubuntu--lv ro security=selinux quiet splash
amdgpu.backlight=1 amdgpu.ppfeaturemask=0xffffffff
crashkernel=2G-4G:320M,4G-32G:512M,32G-64G:1024M,64G-128G:2048M,128G-:4096M
vt.handoff=7
Desktop: GNOME v: 47.0 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy avail: gnome-screensaver dm: GDM3 v: 47.0
Distro: Ubuntu 24.10 (Oracular Oriole)
Type: Desktop System: Apple product: MacPro7,1 v: 1.0
serial: <superuser required> Chassis: type: 7 v: Mac-27AD2F918AE68F61
Mobo: Apple model: Mac-27AD2F918AE68F61 v: MacPro7,1
serial: <superuser required> uuid: <superuser required> UEFI: Apple
v: 2022.140.5.0.0 (iBridge: 21.16.6074.0.0,0) date: 07/03/2024
Device-1: hid-CC22256089W1F42AY-battery model: Apple Inc. Magic Trackpad
serial: N/A charge: N/A status: discharging
Info: model: Intel Xeon W-3223 bits: 64 type: MT MCP arch: Cascade Lake
level: v4 note: check built: 2019 process: Intel 14nm family: 6
model-id: 0x55 (85) stepping: 7 microcode: 0x5003707
L3: 16.5 MiB desc: 1x16.5 MiB
Speed (MHz): avg: 1722 high: 4196 min/max: 1200/4200:4000 scaling:
driver: intel_pstate governor: performance cores: 1: 4196 2: 1200 3: 1200
4: 1200 5: 3888 6: 3883 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200 12: 1200
13: 1200 14: 1200 15: 1200 16: 1200 bogomips: 112000
Type: gather_data_sampling status: Vulnerable
Type: ghostwrite status: Not affected
Type: itlb_multihit status: KVM: Split huge pages
Type: reg_file_data_sampling status: Not affected
Type: spec_rstack_overflow status: Not affected
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2,
DP-3, HDMI-A-1, Writeback-1 bus-ID: 09:00.0 chip-ID: 1002:73bf
Device-2: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Dell
empty: DP-4, DP-5, DP-6, HDMI-A-2, Writeback-2 bus-ID: 15:00.0
chip-ID: 1002:73bf class-ID: 0300
Device-3: Nexight NexiGo N930E FHD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 11-2:2
chip-ID: 3433:930e class-ID: 0102 serial: <filter>
compositor: gnome-shell driver: X: loaded: amdgpu
unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi gpu: amdgpu
display-ID: 0
Monitor-1: DP-1 model: LG (GoldStar) ULTRAGEAR+ serial: <filter>
built: 2023 res: 3840x2160 dpi: 139 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 801mm (31.5") ratio: 16:9 modes: max: 3840x2160 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.2 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 6800 (radeonsi navi21 LLVM
19.1.7 DRM 3.61 6.14.0-1-t2-oracular) device-ID: 1002:73bf
memory: 15.62 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.3.290 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 (RADV NAVI21) driver: N/A device-ID: 1002:73bf
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: AMD Radeon
RX 6800 XT (RADV NAVI21) driver: N/A device-ID: 1002:73bf
Device-1: Apple Audio driver: aaudio pcie: gen: 3 speed: 8 GT/s lanes: 4
bus-ID: 01:00.3 chip-ID: 106b:1803 class-ID: 0401
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab28
Device-3: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 15:00.1 chip-ID: 1002:ab28
Device-4: Nexight NexiGo N930E FHD Webcam driver: snd-usb-audio,uvcvideo
Device-5: Other World OWC Thunderbolt 3 Audio Device
lanes: 1 mode: 1.1 bus-ID: 11-4:3 chip-ID: 1e91:4001 class-ID: 0300
Device-6: Texas Instruments PCM2704 16-bit stereo audio DAC
lanes: 1 mode: 1.1 bus-ID: 15-4:2 chip-ID: 08bb:2704 class-ID: 0300
API: ALSA v: k6.14.0-1-t2-oracular status: kernel-api
Server-1: PipeWire v: 1.2.4 status: active with: 1: pipewire-pulse
Device-1: Broadcom BCM4364 802.11ac Wireless Network Adapter vendor: Apple
driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 14e4:4464 class-ID: 0280
IF: wlan0 state: down mac: <filter>
Device-2: Aquantia AQtion AQC107 NBase-T/IEEE 802.3an Ethernet [Atlantic
10G] vendor: Apple driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 2 link-max: lanes: 4 port: N/A bus-ID: 03:00.0 chip-ID: 1d6a:07b1
class-ID: 0200 temp: 51.1 C
IF: enp3s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-3: Aquantia AQtion AQC107 NBase-T/IEEE 802.3an Ethernet [Atlantic
lanes: 2 link-max: lanes: 4 port: N/A bus-ID: 04:00.0 chip-ID: 1d6a:07b1
class-ID: 0200 temp: 47.4 C
Device-4: Aquantia AQC113C NBase-T/IEEE 802.3an Ethernet [Marvell
Scalable mGig] driver: atlantic v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 2 link-max: gen: 3 speed: 8 GT/s port: N/A bus-ID: 11:00.0
chip-ID: 1d6a:14c0 class-ID: 0200
IF: enp17s0 state: down mac: <filter>
Device-5: Intel I210 Gigabit Network vendor: OWC driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 31:00.0
chip-ID: 8086:1533 class-ID: 0200
IF: enp49s0 state: down mac: <filter>
IF-ID-1: enxacde48001122 state: down mac: <filter>
IF-ID-2: proton0 state: unknown speed: N/A duplex: N/A mac: N/A
IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-4: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
Info: services: iwd, NetworkManager, systemd-networkd, systemd-timesyncd,
wpa_supplicant
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1.3:5
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
lmp-v: 6 sub-v: 22bb hci-v: 6 rev: 22bb class-ID: 6c0104
Info: acl-mtu: 310:10 sco-mtu: 64:8 link-policy: rswitch hold sniff park
link-mode: peripheral accept service-classes: rendering, capturing, audio,
telephony
Supported mdraid levels: raid0 linear raid1 raid6 raid5 raid4 raid10
Device-1: md0 maj-min: 9:0 type: mdraid level: raid-0 status: active
Info: report: N/A blocks: 31251494912 chunk-size: 512k super-blocks: 1.2
Components: Online:
0: sdc maj-min: 8:32 size: 14.55 TiB
1: sdb maj-min: 8:16 size: 14.55 TiB
Local Storage: total: raw: 39.84 TiB usable: 39.84 TiB
used: 18.57 TiB (46.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apple model: SSD AP1024N
size: 931.84 GiB block-size: physical: 4096 B logical: 4096 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 1306
temp: 26.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620361WD temp: 44.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Sabrent model: Rocket CFX P
size: 476.94 GiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 0213 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 model: WUH721816ALE6L4 size: 14.55 TiB
block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: W232
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WUH721816ALE6L0 size: 14.55 TiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: T680
ID-6: /dev/sdd maj-min: 8:48 vendor: OWC model: TB3 SD Card Reader
size: 238.5 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1616 scheme: MBR
ID-7: /dev/sdf maj-min: 8:80 model: Leef Bridge-C size: 28.88 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: PMAP
scheme: MBR
ID-8: /dev/sdg maj-min: 8:96 vendor: OWC model: Mercury - RAID 1 OAkeb
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: 1H02 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 407.58 GiB (22.3%)
fs: ext4 dev: /dev/dm-1 maj-min: 252:1 mapped: ubuntu--vg-ubuntu--lv
ID-2: /boot raw-size: 2 GiB size: 1.9 GiB (95.01%) used: 311.5 MiB (16.0%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:6
ID-3: /boot/efi raw-size: 1.05 GiB size: 1.05 GiB (99.80%)
used: 6.1 MiB (0.6%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swap.img
System Temperatures: cpu: N/A pch: 53.0 C mobo: N/A
Fan Speeds (rpm): cpu: 501 fan-2: 499 fan-3: 495 fan-4: 505
GPU: device: amdgpu temp: 45.0 C mem: 44.0 C fan: 0 watts: 9.00
device: amdgpu temp: 39.0 C mem: 36.0 C fan: 0 watts: 6.00
Memory: total: 256 GiB note: est. available: 247.4 GiB
used: 10.35 GiB (4.2%)
Processes: 615 Power: uptime: 2d 21h 17m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 0 hibernate: shutdown
avail: reboot,suspend,test_resume image: 98.92 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 target: graphical (5)
Packages: 3719 pm: dpkg pkgs: 3667 libs: 1917 tools: apt, apt-get,
gnome-software, synaptic pm: flatpak pkgs: 52 Compilers: gcc: 14.2.0
alt: 13 Shell: Bash v: 5.2.32 running-in: gnome-terminal inxi: 3.3.35
Images:
