Icons only task manager not auto hiding on main monitor
As above, the icons only task manager is Not auto hiding on the main monitor, but does when the panel is moved to a secondary window.
Tried every setting that I could see.
On X11, KDE gaming dragonised
Any suggestions please?
Kernel: 6.9.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=4f8e2cdc-79a4-4506-a9c3-1aaf2113722e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop System: Gigabyte product: Z790 AORUS XTREME X v: -CF
Mobo: Gigabyte model: Z790 AORUS XTREME X v: x.x
Megatrends LLC. v: F3 date: 09/12/2023
Info: model: Intel Core i9-14900K bits: 64 type: MST AMCP arch: Raptor Lake
gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x123
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 930 high: 1969 min/max: 800/5700:6000:4400 scaling:
5: 1100 6: 800 7: 1100 8: 800 9: 800 10: 1969 11: 800 12: 800 13: 1100
14: 800 15: 1100 16: 800 17: 800 18: 800 19: 1100 20: 1100 21: 800
22: 1098 23: 1100 24: 1096 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800
31: 800 32: 1099 bogomips: 203980
Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Gigabyte
driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm)
built: 2022+ ports: active: none empty: DP-4,DP-5,HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:a780 class-ID: 0300
Device-2: NVIDIA AD102 [GeForce RTX 4090] vendor: ASUSTeK driver: nvidia
v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none
off: DP-1,DP-3,HDMI-A-2 empty: DP-2,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2684 class-ID: 0300
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.4.3.1:18
alternate: fbdev,intel,nv,vesa dri: iris gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 5360x2160 s-dpi: 94 s-size: 1447x583mm (56.97x22.95")
s-diag: 1560mm (61.42")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: middle-l
model: ASUS VG249Q1A serial: <filter> built: 2023 res: 1920x1080 hz: 144
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
Monitor-2: DP-3 mapped: DP-4 note: disabled pos: primary,top-right
model: Gigabyte M34WQ serial: <filter> built: 2022 res: 3440x1440 dpi: 109
gamma: 1.2 size: 800x340mm (31.5x13.39") diag: 867mm (34.1") modes:
max: 3440x1440 min: 640x480
Monitor-3: HDMI-A-2 mapped: HDMI-1 note: disabled pos: bottom-c
model: HDMI serial: <filter> built: 2019 res: 1920x720 hz: 60 dpi: 133
gamma: 1.2 size: 368x207mm (14.49x8.15") diag: 313mm (12.3") modes:
max: 1920x720 min: 640x480
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 550.78 device-ID: 10de:2684
surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel Graphics (RPL-S) driver: mesa intel v: 24.0.8-arch1.1
device-ID: 8086:a780 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.8-arch1.1 (LLVM
Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte
Device-2: NVIDIA AD102 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:22ba class-ID: 0403
Device-4: Thesycon System & Consulting GmbH SMSL USB AUDIO
lanes: 1 mode: 2.0 bus-ID: 1-1.4.4.4:20 chip-ID: 152a:85dd class-ID: 0300
Device-5: Giga-Byte ESSential HEX USB DAC
lanes: 1 mode: 2.0 bus-ID: 1-10:7 chip-ID: 0414:a013 class-ID: 0300
API: ALSA v: k6.9.2-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Aquantia AQtion AQC107 NBase-T/IEEE 802.3an Ethernet [Atlantic
10G] vendor: Gigabyte driver: atlantic v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 2 link-max: lanes: 4 port: N/A bus-ID: 06:00.0
chip-ID: 1d6a:07b1 class-ID: 0200 temp: 42.6 C
Device-2: Intel Ethernet I226-V vendor: Gigabyte driver: igc v: kernel
chip-ID: 8086:125c class-ID: 0200
IF: enp7s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-3: Qualcomm WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800]
vendor: Foxconn driver: ath12k_pci v: N/A modules: ath12k pcie: gen: 3
speed: 8 GT/s lanes: 1 link-max: lanes: 2 bus-ID: 08:00.0
chip-ID: 17cb:1107 class-ID: 0280
Device-4: Microsoft Xbox Wireless Adapter for Windows driver: N/A
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.2:4
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:15 chip-ID: 0489:e10d
Local Storage: total: 17.28 TiB used: 45.56 GiB (0.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QJXG7 temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital
model: WD BLACK SN850X 4000GB size: 3.64 TiB block-size: physical: 512 B
fw-rev: 624331WD temp: 53.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: Western Digital
fw-rev: 624331WD temp: 52.9 C scheme: GPT
ID-4: /dev/nvme3n1 maj-min: 259:4 vendor: Western Digital
fw-rev: 624331WD temp: 58.9 C scheme: GPT
ID-5: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion Desk
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 9401 scheme: GPT
ID-1: / raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 34.84 GiB (0.9%)
ID-3: /home raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 34.84 GiB (0.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
ID-5: /var/tmp raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
ID-1: swap-1 type: zram size: 62.56 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 26 C
Memory: total: 64 GiB note: est. available: 62.56 GiB
used: 11.99 GiB (19.2%)
Processes: 692 Power: uptime: 5h 18m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.98 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2195 libs: 618 tools: gnome-software, octopi,
pamac, paru Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date:     2024-05-27
Last full system update: 2024-05-28
(reported to 478797 – Metabug: issues with Panel in "Auto-Hide" or "Dodge Windows" modes inappropriately hiding or un-hiding in various circumstances )Preformatted text
Yep, for example this:
Please post your garuda-inxi as requested by the template.:wink:
Done
Not bad for a first time, now you just have to put your garuda-inxi in a code block :grinning:
Thanks - show me how please?
Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text.
Maybe you overlook or did not read the template?
Issue still unresolved? Then:
  • ONE issue per topic.
Thanks, done, and I have looked both in here and online with nothing specifically found
Most of the time we can’t solve upstream bugs, so, maybe you can read/post on/to
https://community.kde.org/Get_Involved/Issue_Reporting
I have already reported it this link, after discovering it whilst searching
https://bugs.kde.org/show_bug.cgi?id=478797
I was really looking for ideas and areas to look into, as you folk know way more than myself right now
Either you wait until the supposed bug is fixed or you wait until someone jumps in here and has an idea.
Going to see if I can live with it on the second monitor for now.
Bugs the heck out of me though
Sorry, I guess I didn’t see the link because the formatting didn’t fit at the beginning.
No probs, it’s good that you said it as bugs can so easily put folk off
