ICONS on screen randomly move
Issue still unresolved? Then:
The icons in the taskbar and the widget at the bottom, the icons move to be on top of each other and the bar for window controls on top of all windows are missing.
I have an image but i cannot add it.
Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=d7d5f27a-ae18-4fe5-9805-9830706b5270 rw rootflags=subvol=@
quiet resume=UUID=1f7c2397-0d5f-4e05-b03e-ba1588f1c244 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop System: ASUSTeK product: ROG STRIX G10DK_G10DK v: 1.0
Mobo: ASUSTeK model: G10DK v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: ASUSTek v: 310 date: 09/29/2022
Device-1: gip0.0 model: Microsoft X-Box One pad serial: N/A
charge: 50% (should be ignored) rechargeable: yes status: not charging
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 887 high: 4299 min/max: 400/5288 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 400 2: 400 3: 400
4: 400 5: 400 6: 400 7: 4298 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 4299 15: 400 16: 400 bogomips: 137596
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2504
link-max: gen: 4 speed: 16 GT/s ports: active: none
empty: DP-4,DVI-D-1,HDMI-A-2 bus-ID: 0c:00.0 chip-ID: 1002:1638
class-ID: 0300 temp: 36.0 C
Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 046d:0825
gpu: nvidia,amdgpu display-ID: 0
surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: zink
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
API: Vulkan v: 1.3.279 layers: 15 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 550.54.14
device-ID: 10de:2504 surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV RENOIR)
driver: mesa radv v: 24.0.3-arch1.1 device-ID: 1002:1638
17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.3-arch1.1 (LLVM 17.0.6)
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
link-max: gen: 4 speed: 16 GT/s bus-ID: 0c:00.1 chip-ID: 1002:1637
link-max: gen: 4 speed: 16 GT/s bus-ID: 0c:00.6 chip-ID: 1022:15e3
Device-4: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
Device-5: SteelSeries ApS Arctis Pro Wireless
lanes: 1 mode: 1.1 bus-ID: 5-1.3:5 chip-ID: 1038:1294 class-ID: 0300
API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: wireplumber
status: active 2: pw-jack type: plugin tools: pw-cat,pw-cli,wpctl
Server-2: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
vendor: Lite-On driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 08:00.0 chip-ID: 10ec:c822
IF: wlp8s0 state: up mac: <filter>
vendor: ASUSTeK RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 0a:00.0 chip-ID: 10ec:8168
IF: enp10s0 state: down mac: <filter>
Device-1: Lite-On Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:5 chip-ID: 04ca:4005
Local Storage: total: 2.05 TiB used: 1.35 TiB (65.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-256G-1002 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 21106000 temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA100
tech: HDD rpm: 7200 serial: <filter> fw-rev: A8S0 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WDBNCE5000PNC
tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WDBNCE5000PNC
ID-1: / raw-size: 221.76 GiB size: 221.76 GiB (100.00%)
used: 113.79 GiB (51.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 221.76 GiB size: 221.76 GiB (100.00%)
ID-4: /var/log raw-size: 221.76 GiB size: 221.76 GiB (100.00%)
ID-5: /var/tmp raw-size: 221.76 GiB size: 221.76 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.42 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 46.35 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.8 C mobo: N/A gpu: amdgpu temp: 36.0 C
Fan Speeds (rpm): cpu: 900
Memory: total: 48 GiB note: est. available: 46.35 GiB used: 5.07 GiB (10.9%)
Processes: 466 Power: uptime: 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.5 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2232 libs: 561 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0
Garuda (2.6.23-1):
System install date:     2024-01-15
Last full system update: 2024-03-15
WTF is this post about? Why did you not post in the required way?
