Icons disappear when moving rubbish bin
Hi everyone,
Relatively new user here, although I've previously ran Manjaro for a couple of years.
Anyways, I'm loving the Garuda with Cinnamon DE, but every time I try to move the Rubbish Bin (and only the Rubbish bin for some reason) icon on the desktop, all the icons disappear. Furthermore the right-click on the desktop is no longer possible once the icons disappear.
Logging out and back in fixes it. I've tried looking in here for someone who might have had the same issue, but sadly couldn't find it. I've also asked my new friend, Bard, whether anyone had this issue before and it tried linking me to bugs.garudalinux.org, which for some reason returned a 503. Google Bard said that the issue was known but there was no real fix for it yet.
Here's my inxi:
  Kernel: 6.3.6-273-tkg-tt arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: intel_pstate=passive split_lock_detect=off
    BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-tt
    root=UUID=1a5b81a2-3a69-423b-832f-95cf8ebd78d2 rw rootflags=subvol=@
    loglevel=3 ibt=off
  Desktop: Cinnamon v: 5.6.8 tk: GTK v: 3.24.38 wm: muffin vt: 7 dm: LightDM
    v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: ASRock model: B450M Pro4 serial: <superuser required>
    UEFI: American Megatrends v: P5.70 date: 10/20/2022
  Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
    model-id: 8 stepping: 2 microcode: 0x800820D
    L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 3675 high: 3900 min/max: 1550/3900 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3132 2: 3900
    3: 3138 4: 3576 5: 3900 6: 3900 7: 3122 8: 3834 9: 3900 10: 3900 11: 3900
    12: 3900 bogomips: 93696
  Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Micro-Star MSI
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 09:00.0 chip-ID: 1002:73ff
  Device-2: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.4:5
    chip-ID: 046d:0826 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1 driver: X:
    loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Monitor-1: DP-3 mapped: DisplayPort-2 model: BenQ BL2405 serial: <filter>
    built: 2015 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
    size: 531x298mm (20.91x11.73") diag: 609mm (24") ratio: 16:9 modes:
  API: OpenGL v: 4.6 Mesa 23.1.1 renderer: AMD Radeon RX 6600 XT (navi23
    LLVM 15.0.7 DRM 3.52 6.3.6-273-tkg-tt) direct-render: Yes
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab28
  Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
  Device-3: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.3.6-273-tkg-tt status: kernel-api tools: N/A
  Device-1: Broadcom vendor: ASUSTeK driver: brcmfmac v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 14e4:43c3
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2
  Local Storage: total: 2.24 TiB used: 538.82 GiB (23.5%)
    model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 211210WD temp: 33.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 043 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 model: SSD 960GB size: 894.25 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 3A0 scheme: GPT
  ID-1: / raw-size: 140 GiB size: 140 GiB (100.00%) used: 36.5 GiB (26.1%)
    used: 64.6 MiB (67.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 140 GiB size: 140 GiB (100.00%)
    used: 36.5 GiB (26.1%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-4: /var/log raw-size: 140 GiB size: 140 GiB (100.00%)
  ID-5: /var/tmp raw-size: 140 GiB size: 140 GiB (100.00%)
  System Temperatures: cpu: 61.4 C mobo: N/A gpu: amdgpu temp: 33.0 C
    mem: 30.0 C
  Processes: 388 Uptime: 10m wakeups: 0 Memory: available: 15.54 GiB
  used: 3.03 GiB (19.5%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1747
  libs: 493 tools: gnome-software,octopi,pamac,paru,yay pm: flatpak pkgs: 0
  Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: gnome-terminal
  inxi: 3.3.27
  System install date:     2023-05-27
  Last full system update: 2023-06-06
Welcome :slight_smile:
There is no bugs.garudalinux. org its all in gitlab. Who is Bard???
Post always your terminal in- and output as text like
Kernel: 5.18.15-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters:
looks like
    parameters:
in forum.
I have edited your post.
Oh, right. Thanks for the Edit!
Google Bard is the Google version of an AI language model like ChatGPT or BingGPT which basically does the searching for me and then gives me an easily readable answer :smiley:
Should I raise the issue in Gitlab?
No :slight_smile:
The maintainer will check as soon as possible.
Quick update just in case anyone reads this in the future: The issue looks like it solved itself just by keeping my PC up-to-date. I’m sure the Devs/Maintainers had a hand in this, so Thanks!
