Kernel: 6.0.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=7d549f10-2128-425f-a729-a334f876d69d rw rootflags=subvol=@
Desktop: i3 v: 4.21.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Gigabyte product: N/A v: N/A
Mobo: Gigabyte model: H110M-DS2-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F2 date: 10/30/2015
Info: model: Intel Core i5-6500 bits: 64 type: MCP arch: Skylake-S
desc: 1x6 MiB
Speed (MHz): avg: 3381 high: 3416 min/max: 800/3600 scaling:
driver: intel_pstate governor: performance cores: 1: 3416 2: 3363 3: 3365
4: 3380 bogomips: 25599
disabled
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
PBRSB-eIBRS: Not affected
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: Sapphire driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 1
link-max: lanes: 8 ports: active: HDMI-A-1 empty: DP-1,DVI-D-1
bus-ID: 01:00.0 chip-ID: 1002:699f class-ID: 0300 temp: 54.0 C
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-98a5c
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung S24F350
serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 550 / 550 Series
(polaris12 LLVM 14.0.6 DRM 3.48 6.0.9-zen1-1-zen) direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel bus-ID: 1-4:4 v: kernel bus-ID: 00:1f.3
chip-ID: 1e7d:3a3b class-ID: 0300 chip-ID: 8086:a170 class-ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 1 link-max: lanes: 8 bus-ID: 01:00.1 chip-ID: 1002:aae0
Device-3: ROCCAT SYN Pro Air type: USB
Sound API: ALSA v: k6.0.9-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
Local Storage: total: 1.38 TiB used: 56.96 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 model: PS3109S9 size: 20 MiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: N/A serial: N/A
rev: OOT2
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 QVO 1TB
type: SSD serial: <filter> rev: 1B6Q
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: N/A
used: 56.96 GiB (12.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.58 GiB used: 113 MiB (0.7%) priority: 100
System Temperatures: cpu: 73.0 C pch: 41.0 C mobo: N/A gpu: amdgpu
temp: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1035
Processes: 275 Uptime: 3h 20m wakeups: 0 Memory: 15.58 GiB
used: 5.66 GiB (36.4%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1444
libs: 456 tools: pamac,paru Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-25
Last full system update: 2022-11-25 ↻
Hi there,
whenever I disable the constant nightlight effect, the screen moves between redish to OK colors.
I think it's some kind of "warning" thing for gpu tempature, I changed the I3 status config to not display them but the issue presists.
how do I make it stop?
