Hi folks,
Newcomer to Garuda as well as i3 as a window manager. Impressed with both. Did have a question though: In playing with the i3status components I was trying to get the battery status to display, with many failed attempts. After trying a bunch of things, I tried removing the <span> decorations from status_full, status_chr, etc. and it finally worked. These decorations were AFAIK part of the vanilla install I performed. Here's an example of what was in my .config/i3status/config file:
format = "<span color='#FEFF72'> %status: %percentage </span>"
status_chr = "<span color='#00e64d'>[ ] </span> "
Apparently the span decoration on status_chr cause i3status to have fits. If I remove those tags and just use the UTF8 content it works as expected. It was not clear to me from the i3status documentation whether or not decorating the status strings is allowed. The stock i3status config file from install also includes colors=yes and markup=pango.
My garuda-inxi:
Kernel: 5.18.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=4a3429c4-163c-46f1-b956-cb2c002214da rw rootflags=subvol=@
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.30.0
Type: Portable System: Dell product: Inspiron 5423 v: N/A
serial: <superuser required> Chassis: type: 8 serial: <superuser required>
Mobo: Dell model: 0F45CW v: A06 serial: <superuser required> UEFI: Dell
v: A06 date: 09/17/2012
ID-1: BAT0 charge: 33.4 Wh (89.3%) condition: 37.4/44.4 Wh (84.3%)
volts: 12.0 min: 11.1 model: SMP-SDI2.0 DELL 8JVDG27 type: Li-ion
Info: model: Intel Core i5-3317U bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 built: 2012-15 process: Intel 22nm family: 6
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1237 high: 1759 min/max: 800/2600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1759 2: 1118 3: 1230
4: 841 bogomips: 13568
Type: l1tf
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
v: kernel arch: Gen7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: Microdia Laptop_Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-1.5:5 chip-ID: 0c45:6448 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: Picom v: git-7e568
driver: X: loaded: modesetting alternate: fbdev,intel,vesa gpu: i915
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: AU Optronics 0x233c built: 2012 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1366x768
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
Sound Server-1: ALSA v: k5.18.5-zen1-1-zen running: yes
Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:0887
IF: wlp7s0 state: up mac: <filter>
Device-2: Qualcomm Atheros AR8162 Fast Ethernet vendor: Dell driver: alx
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 09:00.0
chip-ID: 1969:1090 class-ID: 0200
Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
driver: btusb v: 0.8 bus-ID: 1-1.4:4 chip-ID: 8087:07da class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 495.58 GiB used: 12.45 GiB (2.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-9WS142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM1
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD PM830 mSATA 32GB
size: 29.82 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3D1Q scheme: GPT
ID-1: / raw-size: 204.89 GiB size: 204.89 GiB (100.00%)
used: 12.4 GiB (6.1%) fs: btrfs dev: /dev/sda9 maj-min: 8:9
ID-2: /boot/efi raw-size: 500 MiB size: 496 MiB (99.20%)
used: 55.3 MiB (11.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 204.89 GiB size: 204.89 GiB (100.00%)
ID-4: /var/log raw-size: 204.89 GiB size: 204.89 GiB (100.00%)
ID-5: /var/tmp raw-size: 204.89 GiB size: 204.89 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.66 GiB used: 239.5 MiB (4.1%)
ID-2: swap-2 type: partition size: 11.12 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda10 maj-min: 8:10
System Temperatures: cpu: 46.0 C mobo: 44.0 C
Fan Speeds (RPM): cpu: 2978
Processes: 263 Uptime: 3h 49m wakeups: 1 Memory: 5.66 GiB
used: 3.34 GiB (59.1%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1409 lib: 365
Shell: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.18
Garuda (2.6.4-1):
System install date: 2022-06-20
Last full system update: 2022-06-23 ↻
