Hi Garuda maintainers,
A follow up to my post regarding transparency in conky, I did a bit more digging and believe the Garuda i3 default install runs two of the same conkys.
The default i3 config file starts up two conkys.
exec --no-startup-id conky
exec --no-startup-id conky -c ~/.config/conky/conky-shcts
The first one runs a "top" as conky must be configured to look for "conky.conf" in
~/.config/conky/conky.conf
While diagnosing conky, I noticed the following
ps -ef | grep conky
jsamuel 678061 1 0 17:36 ? 00:00:00 conky -c /home/jsamuel/.config/conky/conky-shcts
jsamuel 678386 1 1 17:36 ? 00:00:01 conky --daemonize --pause=1
jsamuel 679482 679449 0 17:37 pts/0 00:00:00 grep conky
Note that my i3 config, I have commented out the first conky exec
#exec --no-startup-id conky
But I still get the nice Conky "Top" on my left, and the i3 shortcuts on the right as something other than i3 config starts a "default" conky when i3 starts.
So with the i3 default setup, you end up running two conky "tops", they probably fit so nicely on top of each other you would not notice..
Perhaps the maintainers can confirm this, but it would probably best to remove whatever calls
And leave conky startup to i3 config file so that users can add or remove as many conkys as they wish via i3 config.
Thanks for your attention in this matter. I hope it helps. My inxi is below.
Kernel: 5.19.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=91f29d57-8423-442e-a227-98363728a986 rw rootflags=subvol=@
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Mini-pc System: Fanless Mini PC product: Quieter 3 v: N/A
serial: <superuser required> Chassis: type: 35 serial: <superuser required>
Mobo: Fanless Mini PC model: Rev JSL1 1.10 serial: <superuser required>
UEFI: American Megatrends LLC. v: ML_JPL1V3.2 date: 06/16/2022
Device-1: hidpp_battery_11 model: Logitech MX Vertical Advanced Ergonomic
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
Info: model: Intel Celeron N5105 bits: 64 type: MCP arch: Tremont
built: 2019 process: Intel 10nm family: 6 model-id: 0x9C (156) stepping: 0
microcode: 0x24000023
desc: d-4x32 KiB; i-4x32 KiB L2: 1.5 MiB desc: 1x1.5 MiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2109 high: 2895 min/max: 800/2900 scaling:
driver: intel_pstate governor: powersave cores: 1: 1759 2: 2000 3: 2895
4: 1784 bogomips: 15974
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
filling, PBRSB-eIBRS: Not affected
Device-1: Intel JasperLake [UHD Graphics] driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: HDMI-A-2
empty: DP-1,HDMI-A-1,HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:4e61
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-7e568
driver: X: loaded: modesetting alternate: fbdev,intel,vesa gpu: i915
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: LG (GoldStar) ULTRAWIDE
serial: <filter> built: 2016 res: 3440x1440 hz: 60 dpi: 109 gamma: 1.2
size: 800x335mm (31.5x13.19") diag: 867mm (34.1") modes: max: 3440x1440
min: 640x480
Device-1: Intel Jasper Lake HD Audio vendor: Realtek driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:4dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.19.6-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 160MHz driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:4df0 class-ID: 0280
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 1-8:5 chip-ID: 8087:0026 class-ID: e001
address: <filter>
Local Storage: total: 230.47 GiB used: 35.64 GiB (15.5%)
ID-1: /dev/mmcblk1 maj-min: 179:0 model: A3A444 size: 230.47 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
rev: 0x8 scheme: GPT
ID-1: / raw-size: 158.14 GiB size: 158.14 GiB (100.00%) used: 14.29 GiB
(9.0%) fs: btrfs dev: /dev/mmcblk1p4 maj-min: 179:4
(0.2%) fs: vfat dev: /dev/mmcblk1p1 maj-min: 179:1
ID-3: /home raw-size: 158.14 GiB size: 158.14 GiB (100.00%) used: 14.29
GiB (9.0%) fs: btrfs dev: /dev/mmcblk1p4 maj-min: 179:4
ID-4: /var/log raw-size: 158.14 GiB size: 158.14 GiB (100.00%) used: 14.29
ID-5: /var/tmp raw-size: 158.14 GiB size: 158.14 GiB (100.00%) used: 14.29
ID-1: swap-1 type: zram size: 7.52 GiB used: 179 MiB (2.3%) priority: 100
priority: -2 dev: /dev/mmcblk1p3 maj-min: 179:3
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 290 Uptime: 2d 23h 8m wakeups: 47302 Memory: 7.52 GiB used: 2.32
GiB (30.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1282 lib: 326 Shell: Bash
v: 5.1.16 running-in: alacritty inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-08-27
Last full system update: 2022-09-03
