Hello all!
I've been struggling with a recent issue since I've upgraded my system and did a restart. Ever since that, my WM seems to be broken. Basically when i start the system, and log in the screen "freezes" but whatever I do in the background still works and executes, without any visual changes. I use the i3WM version of Garuda and had no issues with it ever so far until now. I know that stuff does work in the background because when I switch between workspaces (open a terminal on ws. 1, I can't see the window, then I switch to ws. 2, then switch back to ws. 1 and the terminal is there), then the screen and everything is redrawn, and I see what I did before switching. Other than this very painful workaround I get absolutely no visual feedback on whatever I do on the system, and I can't seem to fix it.
Usually I have somewhat of an idea about what the issue might be, but not this time. The only idea I came up with was to reset i3 config at ~/.config/i3 to the default one found in the /etc folder, and to reset the config file found at ~/.condig/i3status to the default one too, but this did not fix my redrawing graphical issue, even after a restart.
I've tried upgrading again everything, tried doing several restarts, but nothing worked so far.
I'd like to ask for help with this above issue, maybe someone has an idea about what might be the problem.
diag output:
Kernel: 6.0.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=bc61e47e-bd51-4e16-83c4-fd7d9a67f43b rw rootflags=subvol=@
resume=UUID=39952a4e-28ef-4ebe-bebf-7ed65cfbb27f loglevel=3
Desktop: i3 v: 4.21.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Kvm System: QEMU product: Standard PC (i440FX + PIIX, 1996)
v: pc-i440fx-6.1 serial: <superuser required> Chassis: type: 1
Mobo: N/A model: N/A serial: N/A BIOS: SeaBIOS
v: rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org date: 04/01/2014
Info: model: Common KVM bits: 64 type: MCP SMP arch: Netburst Presler
level: v1 built: 2006 process: Intel 65nm family: 0xF (15) model-id: 6
stepping: 1 microcode: 0x1
Topology: cpus: 2x cores: 4 smt: <unsupported> cache:
L1: 2x 256 KiB (512 KiB) desc: d-4x32 KiB; i-4x32 KiB L2: 2x 16 MiB (32 MiB)
desc: 4x4 MiB L3: 2x 16 MiB (32 MiB) desc: 1x16 MiB
Speed (MHz): avg: 2095 min/max: N/A cores: 1: 2095 2: 2095 3: 2095 4: 2095
5: 2095 6: 2095 7: 2095 8: 2095 bogomips: 33521
Flags: ht lm nx pae sse sse2 sse3
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT Host state unknown
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Red Hat Virtio GPU driver: virtio-pci v: 1 alternate: virtio_pci
bus-ID: 00:02.0 chip-ID: 1af4:1050 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-5d150
driver: X: loaded: modesetting alternate: fbdev,vesa gpu: virtio_gpu
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 270x203mm (10.63x7.99")
s-diag: 338mm (13.3")
Monitor-1: Virtual-1 model: QEMU Monitor built: 2014 res: 1024x768 hz: 75
dpi: 100 gamma: 1.2 size: 260x195mm (10.24x7.68") diag: 325mm (12.8")
ratio: 4:3 modes: max: 1024x768 min: 640x480
missing.
Message: No device data found.
Sound API: ALSA v: k6.0.9-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
Device-1: Intel 82371AB/EB/MB PIIX4 ACPI vendor: Red Hat Qemu virtual
machine type: network bridge driver: piix4_smbus v: N/A modules: i2c_piix4
port: N/A bus-ID: 00:01.3 chip-ID: 8086:7113 class-ID: 0680
Device-2: Red Hat Virtio network driver: virtio-pci v: 1
modules: virtio_pci port: e0e0 bus-ID: 00:12.0 chip-ID: 1af4:1000
IF: ens18 state: up speed: -1 duplex: unknown mac: <filter>
Device-3: Red Hat Virtio network driver: virtio-pci v: 1
modules: virtio_pci port: e100 bus-ID: 00:13.0 chip-ID: 1af4:1000
IF: ens19 state: down mac: <filter>
Device-4: Red Hat Virtio network driver: virtio-pci v: 1
modules: virtio_pci port: e120 bus-ID: 00:14.0 chip-ID: 1af4:1000
IF: ens20 state: down mac: <filter>
Local Storage: total: 75 GiB used: 37.49 GiB (50.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: QEMU model: HARDDISK size: 75 GiB
block-size: physical: 512 B logical: 512 B speed: <unknown> type: N/A
serial: <filter> rev: 2.5+ scheme: MBR
ID-1: / raw-size: 57.81 GiB size: 57.81 GiB (100.00%)
used: 37.49 GiB (64.9%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 57.81 GiB size: 57.81 GiB (100.00%)
ID-3: /var/log raw-size: 57.81 GiB size: 57.81 GiB (100.00%)
ID-4: /var/tmp raw-size: 57.81 GiB size: 57.81 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.19 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
ID-2: swap-2 type: zram size: 68.71 GiB used: 0 KiB (0.0%) priority: 100
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
or lm-sensors.
Processes: 226 Uptime: 6m wakeups: 1 Memory: 68.71 GiB used: 2.25 GiB (3.3%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: pm: pacman pkgs: 1587 libs: 341 tools: pamac,paru,yay
pm: rpm pkgs: 0 Shell: Zsh v: 5.9 running-in: alacritty inxi: 3.3.23
e[1;34mGaruda (2.6.9-1):e[0m
e[1;34m System install date:e[0m 2022-06-10
e[1;34m Last full system update:e[0m 2022-11-22
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m <superuser required>
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m bluetooth-autoconnect.service
