OS: GarudaLinux
Host: HP ProBook 450 G6
Kernel: 5015.13-zen-1-zen
Packages:1868 (possibly more I'm seeing this in an old image)
Shell: bash
WM: Kwin
WM Theme: Sweet-Dark
Terminal: Konsol
CPU: Intel i5-8265U (8) @ 3.9GHz
GPU: Nvidia GeForce MX130
GPU: Intel WhiskeyLke-UGT2 [UHD Graphics 620]
Memory: 7.63 GiB
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=60d555c7-9238-4641-ae00-5913ab1a2273 rw rootflags=subvol=@
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP ProBook 450 G6 v: N/A
Mobo: HP model: 8538 v: KBC Version 51.2B.00 serial: <superuser required>
UEFI: HP v: R71 Ver. 01.12.00 date: 07/30/2020
ID-1: BAT0 charge: 36.2 Wh (100.0%) condition: 36.2/36.2 Wh (100.0%)
volts: 12.6 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Full
Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEA
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 683 high: 700 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 636 2: 700 3: 700 4: 700
5: 700 6: 686 7: 648 8: 700 bogomips: 28800
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620]
vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3ea0 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX130] vendor: Hewlett-Packard
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:174d class-ID: 0302
Device-3: Chicony HP HD Camera type: USB driver: uvcvideo bus-ID: 1-2:2
chip-ID: 04f2:b669 class-ID: 0e02 serial: <filter>
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi
v: kernel bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
driver: btusb v: 0.8 bus-ID: 1-10:5 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 938.96 GiB used: 188.4 GiB (20.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: RPM2
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston model: DT 101 G2
size: 7.45 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
used: 188.4 GiB (20.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.63 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.0 C pch: 37.0 C mobo: 35.0 C
Processes: 293 Uptime: 21m wakeups: 5 Memory: 7.64 GiB
used: 2.37 GiB (31.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1529 lib: 359 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.12
Garuda:
System install date: 2022-01-22
Last full system update: 2022-01-28
Using TLP: No
If someone here speaks Spanish and can support me, I will be very grateful, if not, then I will continue using the translator.
I hope you can help me soon, I need to recover files from
my thesis and my work.
I tried to start a snapshot from grub, but the same thing happened, neither the panel nor the latte-dock are shown.
Right click on the desktop and add a new panel.
Brave (internet explorer) works. From here I write to you.
But I can’t get it to start Dolphin (file manager) or Konsole (terminal?)
When I tried to restore a previous snapshot from grub, during boot I got this message:
Configuration file “/var/lib/sddm/config/sddm-greeterrc” not writable. Please contact your system administrator.
Also say that before the failure I installed some package that required the internet browser to play radio from a web page.
Maybe some of that information will help.
==Update==
I can open Openoffice, but when I try to open or save a file the program closes.
and a little window appears with the message that it stopped working, also when I want to use the imp pnt button that error message appears.
Paper holder works (ctrl+c, ctrl+v)
==Update 2==
I rebooted from the usb stick, to try to rescue my files from there, but the /root directory was blocked, do you know how I can get my files out?
==update 3==
Kernel panic not syncing: VFS: Una le to mount root fs on unknown-block(0,0)
