So, I've been trying out garuda for a few days on an installation on an usb stick, and was pretty satisfied with it, so I decided to get a real hard drive and move my installation onto it. I thought I'd use clonezilla for that, booted up the livecd, etc. When stqrting to clone, it gave me an error message: apparently, the USB had both MBR and GPT. After a bit of googling, I saw that this could easily be fixed by opening the drive in gdisk, picking between GPT and MBT, and saving the thing.
So, I did that. I recalled selecting GPT at some point while installing garuda, so I picked that one. I, of course, had made a backup with fdisk beforehand, on the disk where I wanted to move my installation. Seeing both my partitions present qnd of the right size, I assumed all was good, and carried on with the copy, which deleted the GPT backup. Upon rebooting though, all I was met with is the word GRUB (different of the usual Welcome to GRUB!), and nothing happening.
I booted the Live CD, and couldn't mount my partitions. I opened gparted, and I saw this:
My partitions were there with the flags and names, but the filesystem is not recognized anymore. Same with my original USB. I guess some kind of information must have been corrupted when using gdisk, but I couldn't find any resources that looked helpful.
I hope someone with more experience will be able to tell me what is going on and maybe how to fix it. I really hope that data is not gone even though it hasn't been terribly long since I've started to use this system ![]()
In the meantime, I've been running gparted's "Partition rescue tool" for 2 hours now with no signs of progression
Thanks in advance for any help ![]()
garuda-inxl (from Live CD)
Kernel: 5.18.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
misobasedir=garuda misolabel=GARUDA_DR460NIZEDGAMING_TALON quiet
systemd.show_status=1 driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Type: Desktop Mobo: ASUSTeK model: P5KPL-AM v: x.xx
serial: <superuser required> BIOS: American Megatrends v: 0603
date: 08/20/2010
Info: model: Intel Core2 Quad Q8200 bits: 64 type: MCP arch: Penryn
built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23)
stepping: 0xA (10) microcode: 0xA0B
desc: d-4x32 KiB; i-4x32 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 2326 high: 2331 min/max: 1998/2331 scaling:
driver: acpi-cpufreq governor: performance cores: 1: 2328 2: 2314 3: 2331
4: 2331 bogomips: 18648
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ASUSTeK driver: nouveau
v: kernel non-free: series: 470.xx+ status: legacy-active (EOL~2023/24)
arch: Fermi 2 code: GF119/GK208 process: TSMC 28nm built: 2010-16 pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 ports: active: VGA-1
empty: DVI-D-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:128b class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 97 s-size: 379x237mm (14.92x9.33")
s-diag: 447mm (17.6")
Monitor-1: VGA-1 model: Acer AL1916W serial: <filter> built: 2006
res: 1440x900 dpi: 89 gamma: 1.2 size: 410x257mm (16.14x10.12")
diag: 484mm (19.1") ratio: 16:10 modes: max: 1400x1050 min: 720x400
OpenGL: renderer: NV106 v: 4.3 Mesa 22.1.4 direct render: Yes
Device-1: Intel NM10/ICH7 Family High Definition Audio
vendor: ASUSTeK P5KPL-CM driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:27d8 class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k5.18.16-zen1-1-zen running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e800
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Ralink RT2770 Wireless Adapter type: USB driver: rt2800usb
bus-ID: 1-2:3 chip-ID: 148f:2770 class-ID: 0000 serial: <filter>
IF: wlp0s29f7u2 state: up mac: <filter>
Local Storage: total: 989.18 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
speed: <unknown> type: HDD rpm: 5400 serial: <filter> rev: SDM1
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Corsair model: Slider 3.0
size: 57.67 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 000D scheme: GPT
ID-1: swap-1 type: zram size: 3.83 GiB used: 40.8 MiB (1.0%)
System Temperatures: cpu: 36.0 C mobo: 40.0 C gpu: nouveau temp: 50.0 C
Fan Speeds (RPM): cpu: 2070 psu: 0 case-1: 0
Power: 12v: 12.14 5v: N/A 3.3v: 3.38 vbat: N/A gpu: nouveau mV: 925.00
Processes: 186 Uptime: 2h 31m wakeups: 0 Memory: 3.83 GiB used: 1.91 GiB
(49.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 Packages: pacman: 1785 lib: 503 Shell: fish v: 3.5.1
Garuda (2.6.5-1):
System install date: 2022-08-20
Last full system update: 2022-08-08
Is partially upgraded: Yes
Failed units: bluetooth-autoconnect.service snapper-cleanup.service
