I need help with graphics
My graphics glitches when playing a game its kinda green looking and i need help
Kernel: 6.8.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=1315c1f2-37c8-4d5b-99b8-6aadac655d56 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: G10DK v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: ASUSTek v: 310 date: 09/29/2022
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3782 high: 3996 min/max: 2200/4409 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3744 2: 3664
3: 3800 4: 3996 5: 3800 6: 3800 7: 3800 8: 3800 9: 3591 10: 3800 11: 3800
12: 3800 bogomips: 91032
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: ASUSTeK driver: nvidia
v: 550.40.61 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
off: DP-1,HDMI-A-2 empty: DP-2,HDMI-A-1 bus-ID: 13:00.0 chip-ID: 10de:2182
Device-2: Realtek USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 0bda:5697
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.0.99
d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-2 pos: right res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.40.61
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
memory: 5.86 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1660 Ti driver: nvidia v: 550.40.61 device-ID: 10de:2182
17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM 17.0.6)
Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
bus-ID: 13:00.1 chip-ID: 10de:1aeb class-ID: 0403
bus-ID: 15:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Realtek USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
Device-4: Logitech Blue Microphones
lanes: 1 mode: 2.0 bus-ID: 5-3:3 chip-ID: 046d:0ab7 class-ID: 0300
API: ALSA v: k6.8.9-zen1-2-zen status: kernel-api tools: N/A
vendor: Lite-On driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 10:00.0 chip-ID: 10ec:c822
IF: wlp16s0 state: up mac: <filter>
lanes: 1 port: d000 bus-ID: 12:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp18s0 state: down mac: <filter>
Device-1: Lite-On Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 04ca:4005
Local Storage: total: 935.23 GiB used: 87.99 GiB (9.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 37.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: SMI (STMicroelectronics) model: USB
size: 3.72 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1100
scheme: MBR
ID-1: / raw-size: 930.51 GiB size: 930.51 GiB (100.00%)
used: 87.99 GiB (9.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 930.51 GiB size: 930.51 GiB (100.00%)
ID-4: /var/log raw-size: 930.51 GiB size: 930.51 GiB (100.00%)
ID-5: /var/tmp raw-size: 930.51 GiB size: 930.51 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.25 GiB used: 1024 KiB (0.0%)
System Temperatures: cpu: 53.9 C mobo: N/A
Fan Speeds (rpm): cpu: 900
Memory: total: 32 GiB available: 31.25 GiB used: 4.55 GiB (14.6%)
Processes: 356 Power: uptime: 9h 43m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: 1385 pm: pacman pkgs: 1351 libs: 382
tools: gnome-software,octopi,paru pm: flatpak pkgs: 34 Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-05-07
Last full system update: 2024-05-09
Please post the output of garuda-inxi for all topics in the Issues & Assistance category as requested in the topic template.
Also, going to need more information to go on here. When did this first started happening? What game(s)? Is the system running hot? Any logs to show?
Topic template
:warning: Missing information requested in the template may result in not receiving assistance :warning:
Issue still unresolved? Then:
  • ONE issue per topic.
It has started happening since i installed the os i’ve tried some methods and none have worked it flashes a kind of green and it doesn’t run hot i will try some other games
I want to try to use x11 how do i?
elaborate on the “green looking”, but attach the garuda-inxi in the first post, else no one will be able to help.
Where do i find that
And it looks kinda like a flashing green look
But no lines or anything just flashing green
just type garuda-inxi in the terminal and edit your first post to include it there.
Maybe on the login screen? Since you haven’t posted your garuda-inxi and we don’t know which DE/DM you are using, we can only use a crystal ball :upside_down_face:
Login screen below: change the desktop session from Plasma (Wayland) to Plasma (X11) and log in.
How do i save it or do i have to keep applying it everytime
It keep by it self.
Thats weird everytime i restart my pc it resets back to wayland
Works fine here, changed to X11 next login stay on X11.
Wayland stays on Wayland too.
Yeah it still does it for me idk why
you can try this: How can I choose between an X and Wayland session before login? - #2 by hhlp - Fedora Discussion
