Here is the garuda-inxi
Kernel: 6.9.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=25376516-84e0-46d7-86bc-264dac89496b rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: Dell product: Vostro 3501 v: N/A
Mobo: Dell model: 0790WT v: A00 serial: <superuser required> part-nu: 0A2A
uuid: <superuser required> UEFI: Dell v: 1.11.0 date: 12/15/2021
ID-1: BAT0 charge: 28.3 Wh (100.0%) condition: 28.3/42.0 Wh (67.3%)
volts: 13.1 min: 11.4 model: SMP DELL VM73283 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xC4
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2089 high: 3400 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 3400 2: 1428 3: 3002
4: 527 bogomips: 9523
Device-1: Intel Iris Plus Graphics G1 vendor: Dell driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4
chip-ID: 1bcf:2b98 class-ID: 0e02
Screen-1: 0 s-res: 1280x720 s-dpi: 96 s-size: 338x190mm (13.31x7.48")
s-diag: 388mm (15.27")
Monitor-1: eDP-1 model: BOE Display 0x08cd built: 2019 res: 1280x720
hz: 60 dpi: 95 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
device-ID: 8086:8a56 memory: 5.59 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: integrated-gpu name: Intel
UHD Graphics (ICL GT1) driver: mesa intel v: 24.1.3-arch1.1
device-ID: 8086:8a56 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.3-arch1.1 (LLVM
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_icl
API: ALSA v: k6.9.8-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 0cf3:e009
Local Storage: total: 990.11 GiB used: 73.87 GiB (7.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 model: USB DISK 3.0 size: 58.59 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: PMAP
used: 73.87 GiB (7.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 600 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 11.46 GiB used: 1.75 GiB (15.3%)
System Temperatures: cpu: 61.0 C mobo: 45.0 C
Fan Speeds (rpm): cpu: 3640
Memory: total: 12 GiB note: est. available: 11.46 GiB used: 7.82 GiB (68.3%)
Processes: 289 Power: uptime: 1d 13h 50m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 12 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 4.54 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1546 libs: 424 tools: octopi,paru,yay
Compilers: gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26
System install date: 2022-12-26
Last full system update: 2024-07-21 ↻
So i Installed woeusb on garuda cause i wanted to put another iso file in it and after putting the iso file and the usb i am getting an error like this:
Installation failed!
Error: Unable to create /media/woeusb_source_1721561655_46509 mountpoint directory
It would be nice if someone could help!
