Epoch
14 July 2022 15:33
#1
I have used every driver the garuda assistant has and none of them seem to work, iam opening blender and checking for cuda gpus but its saying no compatible gpus are detected even though I can see both my gpus in the terminal, iam new to linux so iam not sure what's wrong
Specs:
GPU: Intel UHD Graphics \ Nvidia GeForce MX250
CPU: Intel Core i7-10510U (8) @ 4.9GHz
Kernel: 5.18.11-zen1-1-zen
RAM: 12gb
SSD: 1TB (128GB partitioned for garuda since iam dual booting windows)
Here is the garuda~inxi command:
Kernel: 5.18.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=9c6dcd15-150d-43e5-a121-0bccb94e8c9c rw [email protected]
Type: Laptop System: Acer product: Aspire A515-54G v: V1.24
Mobo: CML model: Doc_WC v: V1.24 serial: <filter> UEFI: Insyde v: 1.24
date: 07/07/2021
ID-1: BAT1 charge: 34.5 Wh (100.0%) condition: 34.5/48.9 Wh (70.6%)
volts: 16.2 min: 15.2 model: LGC AC14B8K type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-10510U socket: BGA1528 (U3E1) note: check
bits: 64 type: MT MCP arch: Comet/Whiskey Lake note: check gen: core 10
stepping: 0xC (12) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4509 high: 4777 min/max: 400/4900 base/boost: 1782/8300
scaling: driver: intel_pstate governor: performance volts: 0.7 V
ext-clock: 100 MHz cores: 1: 4492 2: 4342 3: 4777 4: 4447 5: 4653 6: 4601
7: 4400 8: 4363 bogomips: 36799
Device-1: Intel CometLake-U GT2 [UHD Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Acer Incorporated ALI
driver: N/A alternate: nouveau non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 bus-ID: 0000:02:00.0 chip-ID: 10de:1d13 class-ID: 0302
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a061 class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0x61ed built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.3
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Acer Incorporated ALI
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.18.11-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.55 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:02f0 class-ID: 0280
vendor: Acer Incorporated ALI driver: N/A modules: r8169 port: 3000
bus-ID: 0000:03:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 634.05 GiB (66.5%)
size: 953.87 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 002C temp: 29.9 C scheme: GPT
SMART: yes health: PASSED on: 233d 5h cycles: 1,735
read-units: 53,358,201 [27.3 TB] written-units: 37,462,240 [19.1 TB]
ID-1: / raw-size: 125 GiB size: 125 GiB (100.00%) used: 20.77 GiB (16.6%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5
used: 52.4 MiB (54.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 125 GiB size: 125 GiB (100.00%)
used: 20.77 GiB (16.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-4: /var/log raw-size: 125 GiB size: 125 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 125 GiB size: 125 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 11.51 GiB used: 512 KiB (0.0%)
System Temperatures: cpu: 62.0 C pch: 65.0 C mobo: N/A
Processes: 265 Uptime: 57m wakeups: 5 Memory: 11.51 GiB
used: 3.52 GiB (30.6%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1935
lib: 548 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-07-14
Last full system update: 2022-07-14 ↻
Windows dual boot: Yes
SGS
14 July 2022 15:37
#2
First reboot.
Then search about prime-run in forum.
Epoch
14 July 2022 15:38
#3
ok, I will search that now
filo
14 July 2022 15:47
#5
The driver is still not installed. Unless the indication was due to pending reboot.
What happened when you tried with the tool? Errors? System not booting?
To install the drivers I'd try
sudo mhwd -a pci nonfree 0300
Then, if successful, for sure use prime-run to use the dGPU.
Epoch
14 July 2022 15:52
#6
it was installed but it still wouldnt appear in programs even after restart
Epoch
14 July 2022 15:53
#7
ok it says: "Successfully installed video-nvidia-prime-render-offload", what now?
Epoch
14 July 2022 15:54
#9
ok, thanks alot, seems that "sudo mhwd -a pci nonfree 0300" works alot better, its visible in blender now
The first inxi tells that official drivers were installed but not loaded.
Epoch
14 July 2022 15:55
#11
date: 07/07/2021
status: full
Speed (MHz): avg: 4380 high: 4618 min/max: 400/4900 base/boost: 1782/8300
ext-clock: 100 MHz cores: 1: 3917 2: 4526 3: 4515 4: 4417 5: 4618 6: 4604
7: 4264 8: 4185 bogomips: 36799
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
direct render: Yes
Local Storage: total: 953.87 GiB used: 634.39 GiB (66.5%)
serial: <filter> rev: 002C temp: 30.9 C scheme: GPT
read-units: 53,358,867 [27.3 TB] written-units: 37,464,264 [19.1 TB]
ID-1: / raw-size: 125 GiB size: 125 GiB (100.00%) used: 21.11 GiB (16.9%)
maj-min: 259:1
used: 21.11 GiB (16.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
maj-min: 259:5
maj-min: 259:5
System Temperatures: cpu: 72.0 C pch: 66.0 C mobo: N/A
Processes: 296 Uptime: 1h 16m wakeups: 5 Memory: 11.51 GiB
used: 3.37 GiB (29.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1953
lib: 551 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
Garuda (2.6.5-1):
Epoch
14 July 2022 15:56
#13
should i still install this prime thing?
filo
14 July 2022 15:59
#15
You can verify PRIME Render Offload is working correctly by using the following command:
prime-run glxinfo -B | grep "OpenGL vendor string"
Your output should look similar to this:
OpenGL vendor string: NVIDIA Corporation
From
system
closed
16 July 2022 16:04
#17
