Hey guys so I downloaded the version that was on the Octopi store and nothing happened. I could not find it under my applications either. I was wondering if you guys had a guide or could give me the play by play on how to install it on Garuda. Thank you.
Kernel: 5.18.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=dc312809-6c72-4613-8e07-19c04af934e5 rw [email protected]
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: PRIME Z390-P v: Rev X.0x
serial: UEFI: American Megatrends v: 2417
date: 06/03/2019
Device-1: sony_controller_battery_dc:af:68:f4:7d:7b model: N/A serial: N/A
charge: N/A status: full
Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xD (13) microcode: 0xF0
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 983 high: 3567 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3567 2: 967 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 802 12: 800 13: 800
14: 800 15: 800 16: 800 bogomips: 115200
Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: ZOTAC
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1e81 class-ID: 0300
Device-2: Razer USA Kiyo Pro type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2.4.2:9 chip-ID: 1532:0e05 class-ID: 0102
compositor: kwin_x11 driver: N/A note: X driver n/a display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 69 s-size: 707x392mm (27.83x15.43")
s-diag: 808mm (31.83")
Monitor-1: DP-0 res: 1920x1080 dpi: 70 size: 698x393mm (27.48x15.47")
diag: 801mm (31.54") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
bus-ID: 1-2.4.2:9 v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
chip-ID: 1532:0e05 class-ID: 0102 bus-ID: 00:1f.3 chip-ID: 8086:a348
Device-2: NVIDIA TU104 HD Audio vendor: ZOTAC driver: snd_hda_intel
Device-3: Razer USA Kiyo Pro type: USB driver: snd-usb-audio,uvcvideo
Device-4: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.4.4:10
chip-ID: 0d8c:0005 class-ID: 0300 serial:
Device-5: Sony DualShock 4 [CUH-ZCT2x] type: USB
driver: snd-usb-audio,sony,usbhid bus-ID: 1-3:12 chip-ID: 054c:09cc
Sound Server-1: ALSA v: k5.18.11-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.55 running: yes
IF: wlo1 state: down mac:
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac:
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Local Storage: total: 3.67 TiB used: 418.34 GiB (11.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: ADATA SX6000LNP
speed: 31.6 Gb/s lanes: 4 type: SSD serial: rev: V9002s16
temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3000DM008-2DM166
type: HDD rpm: 7200 serial: rev: CC26 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: PNY model: USB 2.0 FD
size: 14.48 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: rev: PMAP scheme: GPT
ID-1: / raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
used: 418.34 GiB (15.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
ID-4: /var/log raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
ID-5: /var/tmp raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
ID-1: swap-1 type: zram size: 31.26 GiB used: 19 MiB (0.1%) priority: 100
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 45 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 407 Uptime: 3h 32m wakeups: 3 Memory: 31.26 GiB
used: 14.94 GiB (47.8%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: 1553 pacman: 1547 lib: 489
flatpak: 6 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-07-17
Last full system update: 2022-07-17 ↻
