Smurg
                    4 October 2023 08:30
              1
              So after copying my install to a new larger drive i moved my swap partition with Gparted so i could enlarge my root Partition and now it doesn’t work, would deleting the partition and remaking it with KDE Partition manager fix it?
[e[0;1;31mFAILEDe[0m] Failed to activate swap e[0;1;39m/dev/disk/by-uuid/29f15791-f1dd-436f-902e-804af7e61bb0e[0m.
[e[0;1;38;5;185mDEPENDe[0m] Dependency failed for e[0;1;39mSwapse[0m.
[e[0;1;31mFAILEDe[0m] Failed to start e[0;1;39mVirtual Console Setupe[0m.
                SGS
                    4 October 2023 09:39
              2
               Please post always your garuda-inxi.
Check your /etc/fstab, the UUID has probably changed.
                Smurg
                    5 October 2023 11:46
              3
              i changed the uuid to the new id and it just made the boot take much longer.
                SGS
                    5 October 2023 12:18
              4
              Then you did something wrong.
Where ist the garuda-inxi, btw.
                filo
                    5 October 2023 12:19
              5
              Reboot again and provide
systemd-analyze
systemd-analyze critical-chain
                Smurg
                    6 October 2023 06:51
              6
here is the info you asked for, also I have tried both the UUID and the Partition UUID in fstab the Partition UUID only made it take longer to boot.
systemd-analyze
Kernel: 6.5.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=f343e266-2bba-4823-826a-311cb6319709 rw rootflags=subvol=@
resume=UUID=29f15791-f1dd-436f-902e-804af7e61bb0 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Desktop Mobo: Gigabyte model: B650M AORUS ELITE
serial: <superuser required> UEFI: American Megatrends LLC. v: F8c
date: 08/16/2023
Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4540 high: 5439 min/max: 400/5453 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4350 2: 4349 3: 3346
4: 4346 5: 5438 6: 5431 7: 4349 8: 4346 9: 3302 10: 4349 11: 5439 12: 5438
bogomips: 112583
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2,HDMI-A-1 off: DP-3 empty: DP-1
bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4, DP-5,
DP-6, HDMI-A-2 bus-ID: 12:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 40.0 C
s-diag: 1052mm (41.43")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,right
model: ViewSonic XG2401 SERIES serial: <filter> built: 2016 res: 1920x1080
dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77") diag: 609mm (24")
Monitor-2: DP-3 mapped: DisplayPort-2 note: disabled model: Samsung
built: 2010 res: 1920x1080 dpi: 55 gamma: 1.2 size: 160x90mm (6.3x3.54")
diag: 1021mm (40.2") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: left model: Philips PHL 243V5
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: AMD Radeon RX 6750 XT
(navi22 LLVM 16.0.6 DRM 3.54 6.5.3-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.3-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 0bda:8771
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 18.24 TiB used: 8.03 TiB (44.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000D2048G
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 41.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000AS0002-1NA17Z
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5980 serial: <filter> fw-rev: AR15 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST8000AS0002-1NA17Z
tech: HDD rpm: 5980 serial: <filter> fw-rev: RT18 scheme: GPT
ID-1: / raw-size: 1.83 TiB size: 1.83 TiB (100.00%) used: 1.66 TiB (90.7%)
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
used: 1.66 TiB (90.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-1: swap-1 type: zram size: 30.5 GiB used: 27.2 MiB (0.1%) priority: 100
System Temperatures: cpu: 68.0 C mobo: 34.0 C
GPU: device: amdgpu temp: 45.0 C mem: 44.0 C fan: 0 watts: 17.00
device: amdgpu temp: 40.0 C
Processes: 453 Uptime: 2m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.5 GiB used: 6.98 GiB (22.9%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: pm: pacman pkgs: 2234 libs: 559
tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: yakuake inxi: 3.3.29
System install date:     2023-07-10
Last full system update: 2023-09-23
Failed units:            run-media-j-8TB2.mount packagekit.service syncthing.service systemd-vconsole-setup.service
Startup finished in 12.326s (firmware) + 2.552s (loader) + 5.061s (kernel) + 4.338s (initrd) + 1min 35.853s (userspace) = 2min 132ms
graphical.target reached after 1min 35.853s in userspace.
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @1min 35.853s
└─multi-user.target @1min 35.853s
└─smb.service @1min 35.809s +33ms
└─nmb.service @1min 35.791s +17ms
└─network-online.target @1min 35.780s
└─NetworkManager-wait-online.service @1min 30.906s +4.872s
└─NetworkManager.service @1min 30.649s +246ms
└─dbus.service @1min 30.539s +25ms
└─basic.target @1min 30.536s
└─sockets.target @1min 30.536s
└─virtlogd.socket @1min 30.536s
└─sysinit.target @1min 30.533s
└─systemd-timesyncd.service @1min 30.511s +21ms
└─systemd-tmpfiles-setup.service @1min 30.421s +76ms
└─local-fs.target @1min 30.412s
└─run-user-1000-doc.mount @1min 32.320s
└─run-user-1000.mount @1min 31.905s
└─local-fs-pre.target @529ms
└─systemd-tmpfiles-setup-dev.service @504ms +23ms
└─systemd-tmpfiles-setup-dev-early.service @435ms +56ms
└─kmod-static-nodes.service @222ms +54ms
                filo
                    6 October 2023 07:33
              7
OK, I think this confirms to be the bottleneck (I don’t see anything else important).
So, it’s most likely the swap partition mounting.
Could you please provide
cat /etc/fstab
and
lsblk -f
                Smurg
                    6 October 2023 10:01
              8
              cat /etc/fstab
File: /etc/fstab
UUID=157E-16A9                              /boot/efi                  vfat    noatime                                0 2
UUID=f343e266-2bba-4823-826a-311cb6319709   /                          btrfs   subvol=/@,noatime,compress=zstd        0 0
UUID=f343e266-2bba-4823-826a-311cb6319709   /home                      btrfs   subvol=/@home,noatime,compress=zstd    0 0
UUID=f343e266-2bba-4823-826a-311cb6319709   /root                      btrfs   subvol=/@root,noatime,compress=zstd    0 0
UUID=f343e266-2bba-4823-826a-311cb6319709   /srv                       btrfs   subvol=/@srv,noatime,compress=zstd     0 0
UUID=f343e266-2bba-4823-826a-311cb6319709   /var/cache                 btrfs   subvol=/@cache,noatime,compress=zstd   0 0
UUID=f343e266-2bba-4823-826a-311cb6319709   /var/log                   btrfs   subvol=/@log,noatime,compress=zstd     0 0
UUID=f343e266-2bba-4823-826a-311cb6319709   /var/tmp                   btrfs   subvol=/@tmp,noatime,compress=zstd     0 0
UUID=29f15791-f1dd-436f-902e-804af7e61bb0   swap                       swap    defaults                               0 0
tmpfs                                       /tmp                       tmpfs   noatime,mode=1777                      0 0
UUID=34a626e2-8c10-453a-ab86-d896fff6c46d   /run/media/j/8TB/          ext4    nofail                                 0 0
UUID=3B3AB44977D448F4                       /run/media/j/8TB2/         ext4    nofail                                 0 0
UUID=04781BCC781BBB7E                       /mnt                       ntfs    noauto,users                           0 0
UUID=232c7499-efa9-4066-a95e-6c58183b8558   /run/media/j/Sata\040SSD   btrfs   nofail,users                           0 0
#/dev/sda2                                   /run/media/j/SSD    btrfs   users                                  0 0
lsblk -f
NAME        FSTYPE FSVER LABEL    UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
sda
└─sda1      btrfs        Sata SSD 232c7499-efa9-4066-a95e-6c58183b8558    1.8T     0% /run/media/j/Sata SSD
sdb
└─sdb1      ntfs         8TB2     3B3AB44977D448F4
sdc
└─sdc1      ext4   1.0   8TB      34a626e2-8c10-453a-ab86-d896fff6c46d  488.1G    88% /run/media/j/8TB
zram0        [SWAP]
nvme0n1
├─nvme0n1p1 vfat   FAT32          157E-16A9                             298.8M     0% /boot/efi
├─nvme0n1p2 btrfs                 f343e266-2bba-4823-826a-311cb6319709                /var/tmp
└─nvme0n1p3 swap   1     swap     29f15791-f1dd-436f-902e-804af7e61bb0
                filo
                    6 October 2023 10:17
              9
 Smurg:
The delay should come from somewhere here.
I’d start commenting them one-by-one in /etc/fstab and reboot, to see where the problem might come from. Especially:
04781BCC781BBB7E does not appear in lsblk
3B3AB44977D448F4 appears but not in mountpoint
                system
                  Closed
                    20 October 2023 10:17
              10
