I messed up (dual boot)
Use lsblk -f to find th OS, edit my sample.
Save the .conf as root.
But Garuda Linux do not support dual boot.
You got the first problem if you try to restore a snapshot.
Start slowly and get experience, time is the solution.
there is not custom.conf on the dir. i should create one yes ?
and i never had an issue with garuda and especially on dual boots. even with windows NEVER. but this time I don’t know how this happened
Right
i.. uh… changed it to…uh… Arch Linux
please don’t be mad
but i installed arcolinux and vanilla arch and garuda kde lite and DUAL BOOT WORKED but after installing hyprland the error happened
Hyprland is just an DE from Garuda.
It works fine on my notebook, with custom.cfg, with M$ and 4 Garuda DE’s
lsblk -f | grep 'nvme|NAME'
NAME        FSTYPE FSVER LABEL       UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
nvme0n1
├─nvme0n1p1 vfat   FAT32 SYSTEM_DRV  94BA-ECE1                             223,9M    13% /boot/efi
├─nvme0n1p2
├─nvme0n1p3 ntfs         Windows-SSD A2A8BB95A8BB6707
├─nvme0n1p4 ntfs         WINRE_DRV   B8F6BC25F6BBE234
├─nvme0n1p5 btrfs        KDE         fc62cc44-07ab-497b-ac89-15704c290993   19,3G    94% /root
├─nvme0n1p6 btrfs        bit         91225cd8-6061-4b6a-987e-273317efb07f
├─nvme0n1p7 btrfs        i3wm        21e02e96-0ed6-4629-9a39-85ffee7a4359
└─nvme0n1p8 btrfs        Hyprland    b147dd48-f302-484d-80b0-661e7ff40a76
You can also use other boot options, but we can’t fix, most of the times, dual boot problems, on other persons hardware.
Maybe rEFInd is for you a better solution?
Once again, great respect to the guy who maintains Arco Linux but crikey, I could never get along with it.
I haven’t followed much the thread :smiling_face:, but when it’s about multiple Garuda installations I always used successfully the update grub section of this:
