I just installed garuda to VB its amazing i need advice about terminal
Hello;
Pewdiepie ruined my windows experience i agree with him a lot of things he pointed. i want to give a try for garuda my local linux users recommended it. I install gaming version which is absolutely insane good looking thing. I try to install arch 5 time on VB and its crashed hyprland giving me issues etc. However im commit to use garuda now i want to learn terminal in different way. i have 2 monitor i want to open terminal in other monitor.
Here what i am asking is there terminal command like i can see what i do in desktop like i double click something on desktop terminals tell me i did “cd blabla” or i delete something i did “rm blabla” same as runing/closing windows etc.. So atleast i can learn basic terminal commands by visualising and memorying the command every action i made on desktop.
Welcome :slight_smile:
Installing Garuda Linux in a VM is not supported and can also lead to a negative experience.
It is working great on VirtualBox i have no clue about linux but Garuda is insanely good. I wonder if i broke the system if i install hyprland to gaming edition :grin: Thank you for links i will use ai translate to my language.
Nothing exists for this, but I appreciate the spirit and desire to learn more! There are applications that give common command usage, such as Tealdeer: Introduction - Tealdeer User Manual
sudo pacman -S tealdeer
If you are a new user, consider that Hyprland, Sway, and i3 can have comparatively steep learning curves.
Thank you a lot i’m reading your guide now.
