I having A error with barcode.When ever i upgrading my system and when i reboot my system i getting error message with “Kernel Penic Please Reboot Your System” and this error message arriving with Barcode Please Help me How I can solve This Error.
Can you restore the latest working snapshot?
Or have you done it, it worked, and the issue occurred again at the next update?
If so, restore again and start providing your system specs with
yes, I tried restoring the Garuda Linux snapshot, but even after that, when I upgraded the system, the error started appearing again.
Please, do not ignore the template and question from Moderators.
Just wait for the upstream fix.
❯ garuda-inxi
root=UUID=44ff60b6-b988-470c-9dfa-19ef9a8b63ee rw rootflags=subvol=@
quiet resume=UUID=3033f928-bf5d-4e11-8bf1-9b10597658b7 loglevel=3 ibt=off
wm: kwin_wayland tools: avail: i3lock vt: 1 dm: SDDM Distro: Nirantar Linux
Type: Laptop System: LENOVO product: 20351 v: Lenovo G50-70
serial: <superuser required> Chassis: type: 10 v: Lenovo G50-70
Mobo: LENOVO model: Lancer 5A2 v: NANANANANO DPK
part-nu: LENOVO_MT_20351_BU_idea_FM_Lenovo G50-70
uuid: <superuser required> UEFI-[Legacy]: LENOVO v: 9ACN29WW
date: 10/20/2014
ID-1: BAT0 charge: 15.4 Wh (56.8%) condition: 27.1/31.7 Wh (85.7%)
power: 13.9 W volts: 15.2 min: 14.4 model: Lenovo IdeaPad type: Unknown
Info: model: Intel Core i5-4258U bits: 64 type: MT MCP arch: Haswell
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/2900 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 19155
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a2e
Device-2: Advanced Micro Devices [AMD/ATI] Sun LE [Radeon HD 8550M / R5
M230] vendor: Lenovo driver: radeon v: kernel alternate: amdgpu
arch: GCN-1 code: Southern Islands process: TSMC 28nm built: 2011-20 pcie:
gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 bus-ID: 03:00.0
chip-ID: 1002:666f class-ID: 0380 temp: 54.0 C
Device-3: Realtek Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-6:3 chip-ID: 0bda:579a
compositor: kwin_wayland driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: crocus,radeonsi gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x0456 built: 2014 res: mode: 1366x768
hz: 60 scale: 75% (0.75) to: 1821x1024 dpi: 101 gamma: 1.2
modes: 1366x768
API: EGL v: 1.5 hw: drv: intel crocus drv: amd radeonsi platforms:
device: 0 drv: crocus device: 1 drv: radeonsi device: 2 drv: swrast gbm:
drv: crocus surfaceless: drv: crocus wayland: drv: crocus x11: drv: crocus
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Graphics 5100 (HSW
GT3) device-ID: 8086:0a2e memory: 1.46 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: integrated-gpu name: Intel
Iris Graphics 5100 (HSW GT3) driver: mesa intel v: 25.1.4-arch1.1
device-ID: 8086:0a2e surfaces: N/A device: 1 type: cpu name: llvmpipe
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
API: ALSA v: k6.15.3-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:08b4 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-7:4 chip-ID: 8087:07dc
Report: btmgmt ID: hci0 rfk-id: 8 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 63.38 GiB (6.8%)
model: WD10JPCX-24UE4T0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-1: / raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
used: 63.38 GiB (6.9%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-3: /var/log raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-4: /var/tmp raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.65 GiB used: 2.16 GiB (28.2%)
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 58.0 C mobo: N/A gpu: radeon temp: 54.0 C
Memory: total: 8 GiB available: 7.65 GiB used: 2.78 GiB (36.3%)
Processes: 285 Power: uptime: 3h 10m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 5 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 3.04 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1768 libs: 446 tools: octopi,paru Compilers:
clang: 20.1.6 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
System install date: 2025-06-21
Last full system update: 2025-06-28 ↻
here the output of
@SGS I uploaded the output of garuda-inxi Please help me to solve this error
Restore again the latest working snapshot, reboot (always after restoring) and install the lts kernel:
Reboot and make sure to select the lts kernel in the grub screen.
Then update again.
If the issue persists, it could be one of the packages that are updated…
In that case, you could wait for a fix for a few days, as suggested.
Please don’t ping the moderators begging for help.
We are all volunteers here, in our free time…
Okay, I will keep this in mind from now on and I won’t ping again next time. Also, I sincerely apologize for the mistake that happened this time.And thank So much For your Support.
