Hello community,
As I was trying to install the newest version of Garuda Linux GNOME on my hp 255 G10, I encountered an error. The same happened when I tried to install the newest dra46onized KDE edition. By creating the USB with etcher, it does not show up on the boot menu. Magically, it worked by using an older version of Garuda Linux. By creating it with Ventoy, it drops me to the debug shell. By leaving the grub entry as it was, it showed me that md5sum was not found. Though, by testing it manually, the command was found. Then I set checksum to “n” so it does not try to do something with checksums. Then, it said “could not mount /dev/loop0”. Could you help me please?
Welcome ![]()
Would you please define exactly what older and latest version mean?
The full ISO name would be more helpful.
Also, the garuda-inxi, from the live ISO (nobody can do anything with hp255 G10
Where did you set checksum to “n”?
We should only talk about either GNOME or KDE here but not mix the two.
By older version I mean version 231027 from sourceforge and by newer version I mean the newest version from sour ceforge. By HP 255 G10 I mean my laptop model, because it worked fine on my second laptop. I set checksum=n in the grub menu entry - boot with open source drivers in the first line.
Newer images don’t work with Ventoy…you would need to write the image directly to a jumpdrive for install…or use the older 24xxxx iso available from the main garudalinux website and then install updates.
The problem is that the device does not show up in my boot menu at all
What device are you using and what chipset does it use? Have you plugged it into the laptop that is working and checked if it shows in lsusb? If it doesn’t then the device is the issue.
I tried all of my 5 usbs, they show up on my os, I use an HP 255 G10 with an AMD Ryzen 5 7530u and Radeon graphics
Please.
garuda-inxiin the body of the post (not linked externally, or collapsed with the “hide details” feature)
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Without garuda-inxi this request will be moved to 412 Precondition Failed
Okay will add it at German evening today
That is a lot older–more than one year old! Try the 240428 ISO instead.
If you want to use Ventoy, be sure your Ventoy stick is up to date. https://www.ventoy.net/en/doc_start.html
Here is garuda-inxi
Kernel: 6.11.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=c8015512-50b9-4dba-bf9f-730c7ae12e30 rw rootflags=subvol=@
quiet resume=UUID=c4877411-4bbf-4965-b973-555bca1a3b01 loglevel=3 ibt=off
Desktop: GNOME v: 47.1 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Garuda base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP 255 15.6 inch G10 Notebook
PC v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 8BA5 v: 53.43 serial: <filter>
part-nu: 853S9ES#ABD uuid: 34384831-3930-4230-5a35-354239303831 UEFI: AMI
v: F.10 date: 12/22/2023
ID-1: BAT0 charge: 23.0 Wh (55.4%) condition: 41.5/41.5 Wh (100.0%)
power: 3.5 W volts: 11.4 min: 11.2 model: HP Primary type: Li-ion
serial: <filter> status: discharging cycles: 7
Info: model: AMD Ryzen 5 7530U with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
microcode: 0xA50000F
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1095 min/max: 400/4546 boost: enabled
base/boost: 2000/4550 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1095 2: 1095 3: 1095 4: 1095
5: 1095 6: 1095 7: 1095 8: 1095 9: 1095 10: 1095 11: 1095 12: 1095
bogomips: 47906
Device-1: Advanced Micro Devices [AMD/ATI] Barcelo vendor: Hewlett-Packard
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:15e7 class-ID: 0300 temp: 34.0 C
Device-2: Quanta HP True Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0408:5489
Display: unspecified server: X.Org v: 24.1.3 with: Xwayland v: 24.1.3
compositor: gnome-shell driver: gpu: amdgpu display-ID: :0 screens: 1
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: BOE Display 0x0a17 built: 2021 res: 1920x1080
hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48") diag: 395mm (15.5")
API: Vulkan v: 1.3.295 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.5-arch1.1
device-ID: 1002:15e7 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.5-arch1.1 (LLVM
Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6
API: ALSA v: k6.11.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.6 status: n/a (root, process) with:
Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network [1T1R]
vendor: Hewlett-Packard driver: rtw89_8852be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:b85b
Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:b85d
Local Storage: total: 476.94 GiB used: 51.99 GiB (10.9%)
model: MZVL4512HBLU-00BH1 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS3NHAV temp: 26.9 C scheme: GPT
ID-1: / raw-size: 258.79 GiB size: 258.79 GiB (100.00%)
used: 51.99 GiB (20.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 872 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 258.79 GiB size: 258.79 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 258.79 GiB size: 258.79 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 258.79 GiB size: 258.79 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 14.97 GiB used: 3.35 GiB (22.4%)
ID-2: swap-2 type: partition size: 16.47 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 35.6 C mobo: N/A gpu: amdgpu temp: 34.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 16 GiB note: est. available: 14.97 GiB used: 5.37 GiB (35.9%)
Processes: 424 Power: uptime: 1h 37m states: freeze,mem,disk
suspend, test_resume image: 5.98 GiB services: gsd-power,
Packages: 1565 pm: pacman pkgs: 1557 libs: 457 tools: gnome-software,paru
pm: flatpak pkgs: 8 Compilers: gcc: 14.2.1 Shell: garuda-inxi (sudo)
default: Bash v: 5.2.37 running-in: gnome-terminal inxi: 3.3.36
System install date: 2024-10-05
Last full system update: 2024-10-31 ↻
Relevant software: snapper NetworkManager dracut grub-customizer
Failed units: grub-btrfs-snapper.service
Hope you can do something with that,
notchapplez
