I have recently installed LibreOffice and whenever i open it crashes
I have recently installed LibreOffice whenever i try to open it it crashes I have installed it via Add/Remove Software in garuda linux I took a screenshot how it crashed
Here you can see at the bottom how it crashed i am unable to open it i have work pending can anyone help me
start libreoffice with
libreoffice --safe-mode
and disable hardware acceleration
click on apply changes and restart
ok Thanx for your advice
oh no now my Alacritty is not responding
someone help me
New Problem, new thread. :slight_smile:
Don’t post pictures like in Telegram with “empty” content. :wink:
This is a forum not a chat, do not push your thread with “empty” content.
Just close terminal and start again.
If same than open console and do
alacritty
and look for errors.
It looks like your running an old version as theres no community tag update via
sudo pacman -Syu
and see what happens.
After getting a magnifying glass I see that it is still about LibreOffice.
Please do not post pictures of terminal output, read
and
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
Post info
inxi -Fxxxza
journalctl -b -p3 --no-hostname --no-pager
mhwd --pci -li
Hi, I have this same problem with libreoffice.
I disabled the hardware acceleration and clicked on apply and restart. It worked.
But after I close libreoffice and run it again, it does not start and have to start it in the safe mode and disable hardware acceleration and clicked on apply and restart, to get it to work everytime.
How can I fix this?
Please open your own help request. Do not necro and hijack others old threads please.
Post the error message you receive when you start the program from the terminal. Do not post a pic of errors.
