I have been attempting updating Garuda for several days and I'm having dependency problems. I update either through update or garuda -update and I'm not sure if there's a difference
ystem:
Kernel: 6.5.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=013a0e6f-1e15-4ec6-8862-4c62cb69ca18 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3202
date: 06/15/2023
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 978 high: 3877 min/max: 400/4464 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 400 2: 400 3: 400
4: 400 5: 400 6: 3868 7: 400 8: 400 9: 400 10: 3877 11: 400 12: 400
bogomips: 93426
built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300 temp: 61.0 C
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 046d:0825
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: SCEI MONITOR serial: <filter>
built: 2011 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 522x294mm (20.55x11.57") diag: 600mm (23.6") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 480 Graphics
(polaris10 LLVM 16.0.6 DRM 3.54 6.5.7-zen2-1-zen) device-ID: 1002:67df
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.264 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 480 Graphics (RADV POLARIS10) driver: mesa radv
v: 23.2.1-arch1.2 device-ID: 1002:67df surfaces: xcb,xlib device: 1
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
Device-4: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.5.7-zen2-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.82 status: active with: 1: pipewire-pulse
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0029
Local Storage: total: 1.36 TiB used: 384.89 GiB (27.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 043 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD1
used: 384.89 GiB (82.7%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 1.2 MiB (0.4%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.41 GiB used: 10.5 MiB (0.1%)
System Temperatures: cpu: 39.6 C mobo: N/A gpu: amdgpu temp: 62.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 753
Processes: 340 Uptime: 40m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.41 GiB used: 4.54 GiB (29.5%) Init: systemd v: 254
Packages: 2127 pm: pacman pkgs: 2124 libs: 580 tools: octopi,pamac,paru,yay
pm: snap pkgs: 3 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
Garuda (2.6.17-1):
System install date:     2023-10-19
Last full system update: 2023-10-18
Failed units:            nmb.service
I have tried using several snapshots and booting to no avail, and would appreciate any help. I have been using Garuda for a couple of years with next to no problems.
Read through this thread when you have a chance:
After that, run the update command and paste the input/output into the thread so we can see what the problem is.
╭─markf@mark1 in ~
╰─λ update
[sudo] password for markf:
garuda is up to date
core is up to date
extra                                   8.2 MiB  8.88 MiB/s 00:01 [------------------------------------] 100%
multilib is up to date
chaotic-aur                             2.6 MiB  1555 KiB/s 00:02 [------------------------------------] 100%
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
:: Replace kde-servicemenus-pdf with chaotic-aur/kf5-servicemenus-pdf? [Y/n] y
warning: kde-servicemenus-pdf-encrypt-decrypt: local (1-1.4) is newer than chaotic-aur (1-1)
warning: reshade-shaders-git: local (r909.2459c73-1) is newer than chaotic-aur (r33.9e9fa9e-1)
resolving dependencies...
:: cachyos-ananicy-rules-git and ananicy-rules are in conflict (ananicy-rules-git). Remove ananicy-rules? [y/N] y
:: installing kio5 (5.111.0-1) breaks dependency 'kio' required by kipi-plugins
:: installing kxmlgui5 (5.111.0-1) breaks dependency 'kxmlgui' required by libkipi
:: installing kservice5 (5.111.0-1) breaks dependency 'kservice' required by libkipi
:: installing kcoreaddons5 (5.111.0-1) breaks dependency 'kcoreaddons' required by libmediawiki
:: installing kauth5 (5.111.0-1) breaks dependency 'kauth' required by samba-mounter-git
:: installing kcmutils5 (5.111.0-1) breaks dependency 'kcmutils' required by samba-mounter-git
:: installing kconfig5 (5.111.0-1) breaks dependency 'kconfig' required by samba-mounter-git
:: installing kio5 (5.111.0-1) breaks dependency 'kio' required by samba-mounter-git
:: installing ki18n5 (5.111.0-1) breaks dependency 'ki18n' required by samba-mounter-git
:: installing solid5 (5.111.0-1) breaks dependency 'solid' required by samba-mounter-git
Thanks for your prompt reply! Here is the text.
Witness garuda-update working as intended here :wink:
These packages have all been removed from the repos and should be uninstalled before you take the update.
sudo pacman -R kipi-plugins libkipi libmediawiki samba-mounter-git
If you want to replace any of them with the AUR version you should do that after you finish the update.
Thanks so much everyone! But, is there a difference between Update and Garuda-update.? It seems like I might be having more problems after using the latter.
They are the same. :slightly_smiling_face:
❯ ls /usr/bin/update
lrwxrwxrwx 22 root 24 Sep 20:17 update -> /usr/bin/garuda-update
Thanks! I thought so.
