i have an issue with internet when i connect my pc to wifi i only getting kb/s but when i use ethernet it's working fine
here is my information
Please, post your garuda-inxi, not -Fxxxza (same like -Faz) as text, here in forum.
Check your router and also the position to your PC.
not router issue i tested everything and reported to service provider and they said no issues with their server and i just installed garuda xfce today and previously I'm on garuda cinnamon and no issues at all
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.15.26-1-lts running: yes
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
bus-ID: 1-4:2 chip-ID: 8087:0029 class-ID: e001
address: <filter>
Local Storage: total: 942.7 GiB used: 138.19 GiB (14.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX016N
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41020C20
temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB model: External USB3.0
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0204 scheme: GPT
ID-1: / raw-size: 464.76 GiB size: 464.76 GiB (100.00%)
used: 138.19 GiB (29.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 584 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 464.76 GiB size: 464.76 GiB (100.00%)
ID-4: /var/log raw-size: 464.76 GiB size: 464.76 GiB (100.00%)
ID-5: /var/tmp raw-size: 464.76 GiB size: 464.76 GiB (100.00%)
ID-1: swap-1 type: partition size: 20 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: swap-2 type: zram size: 15.03 GiB used: 994 MiB (6.5%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 41.0 C
Processes: 354 Uptime: 9h 3m wakeups: 23 Memory: 15.03 GiB
used: 1.94 GiB (12.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: 1235 pacman: 1232 lib: 326 snap: 3 Shell: Bash
v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-03-12
Last full system update: 2022-03-12
I meant that if there are three reinforced concrete walls between the PC and the transmitter (your router), or if you live in a house where your network is brought to its knees by other routers, then you will have poor reception. I would advise you to simply use the cable, if that doesn't work, there are also socket solutions (power lan).
Your answer is not clearly understood by my translation assistant.
Translated with DeepL Translate: The world's most accurate translator (free version)
no Buddy it's not the issue I'm sure something happened with Garuda xfce
my wifi is located in my room just a two step from my lap
and I don't have the issue in Garuda cinnamon edition
What’s different between the two?
LTS kernel on Xfce.
Install Zen kernel.
yes but i saw some posg that zen kernel not work well in nvidia drivers
I saw this post that they telling about nvidia drivers
i have nvidia driver’s
Use the Linux kernel if you’re all skittish about Zen, (for little reason).
My sympathies.
You didn’t read the thread though. It had absolutely nothing to do with the linux-zen
kernel.
