The logo was showing up correctly in the terminal and now I have a message:
Error: couldn’t find config: neofetch
I searched the internet and our forum, but found nothing. How can I fix it?
Complete guess, but maybe make the config file with the contents in this post on GitHub
Thanks for the answer, but previously everything was fine.
When I generate the
λ neofetch --config
logo it shows up to me, but only for a moment. After restarting the terminal again, I have the same thing again.
How can I save it permanently?
Please, as always, post your garuda-inxi.
You use fish or bash?
man neofetch
There is no neofetch --config
OTHER:
--config /path/to/config
Specify a path to a custom config file
--config none
Launch the script without a config file
Thanks for the answer.
> λ garuda-inxi
Kernel: 5.18.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=412f7b00-714f-4f95-9df3-7a098c95620b rw rootflags=subvol=@
quiet quiet amdgpu.cik_support=1 radeon.cik_support=0 splash
resume=UUID=a8415b23-e856-46ab-8fd2-a2f43492a61c loglevel=3
Type: Laptop System: Hewlett-Packard product: HP EliteBook 745 G2
v: A3009DD10303 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 221C v: KBC Version 63.19
serial: <superuser required> BIOS: Hewlett-Packard v: M84 Ver. 01.44
date: 09/26/2016
ID-1: BAT0 charge: 49.6 Wh (97.3%) condition: 51.0/51.0 Wh (100.0%)
volts: 12.3 min: 11.1 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: N/A
Info: model: AMD A8 PRO-7150B R5 10 Compute Cores 4C+6G bits: 64
type: MT MCP arch: Steamroller built: 2014 process: GF 28nm
family: 0x15 (21) model-id: 0x30 (48) stepping: 1 microcode: 0x6003106
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 256 KiB desc: d-4x16
KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 1211 high: 1336 min/max: 1100/1900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1116 2: 1100
3: 1293 4: 1336 bogomips: 15171
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: AMD Kaveri [Radeon R6 Graphics] vendor: Hewlett-Packard
driver: amdgpu v: kernel alternate: radeon arch: GCN-2 code: Sea Islands
process: GF/TSMC 16-28nm built: 2013-17 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, VGA-1 bus-ID: 00:01.0 chip-ID: 1002:130a class-ID: 0300
Device-2: Chicony HP HD Webcam type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 04f2:b477 class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x123d built: 2012
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD KAVERI (LLVM 14.0.6 DRM 3.46 5.18.16-zen1-1-zen)
v: 4.6 Mesa 22.1.6 direct render: Yes
Device-1: AMD Kaveri HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:1308
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.18.16-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168
IF: enp1s0f0 state: down mac: <filter>
Device-2: Broadcom BCM4352 802.11ac Wireless Network Adapter
vendor: Hewlett-Packard driver: wl v: kernel modules: bcma pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:43b1
Device-1: Broadcom BCM20702A0 type: USB driver: btusb v: 0.8 bus-ID: 3-3:2
chip-ID: 0a5c:21fb class-ID: fe01 serial: <filter>
Local Storage: total: 931.51 GiB used: 40.19 GiB (4.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM014-1EJ164
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: DEMG
scheme: MBR
ID-1: / raw-size: 915.46 GiB size: 915.46 GiB (100.00%) used: 40.19 GiB
(4.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 915.46 GiB size: 915.46 GiB (100.00%) used: 40.19
GiB (4.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 915.46 GiB size: 915.46 GiB (100.00%) used: 40.19
ID-4: /var/tmp raw-size: 915.46 GiB size: 915.46 GiB (100.00%) used: 40.19
ID-1: swap-1 type: zram size: 14.59 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.05 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 64.8 C mobo: N/A gpu: amdgpu temp: 64.0 C
Processes: 233 Uptime: 1h 57m wakeups: 1 Memory: 14.59 GiB used: 2.99 GiB
(20.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 Packages: pacman: 1452 lib: 356 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.20
Garuda (2.6.5-1):
System install date: 2022-08-08
Last full system update: 2022-08-13 ↻
Failed units: shadow.service
I generate
λ neofetch --config >> /home/wojtek/.config/neofetch/config.conf
and everything is fine now. Thanks for the help.
I format your output ![]()
Change your
.config/fish/config.fish
fastfetch to neofetch.
Aways reboot KDE
I reboot KDE twice.
Than post the garuda-inxi after reboot ![]()
