Following the update, the rtl8852bu driver (from AUR) stopped working/was not installed for the new kernel, so I removed,reinstalled it to get the output from Add-Remove Software:
Preparing...
Cloning rtl8852bu-dkms-git build files...
Generating rtl8852bu-dkms-git information...
Checking rtl8852bu-dkms-git dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building rtl8852bu-dkms-git...
==> Making package: rtl8852bu-dkms-git 1.19.3.r9.e2c26e9-1 (Sun 09 Feb 2025 04:40:01 AM EST)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
-> Found dkms.conf
-> Updating rtl8852bu git repo...
==> Validating source files with sha256sums...
dkms.conf ... Passed
rtl8852bu ... Skipped
==> Removing existing $srcdir/ directory...
==> Extracting sources...
-> Creating working copy of rtl8852bu git repo...
Cloning into 'rtl8852bu'...
done.
==> Starting pkgver()...
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "rtl8852bu-dkms-git"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: rtl8852bu-dkms-git 1.19.3.r9.e2c26e9-1 (Sun 09 Feb 2025 04:40:06 AM EST)
==> Cleaning up...
Checking keyring...
Checking integrity...
Loading packages files...
Checking file conflicts...
Checking available disk space...
Running pre-transaction hooks...
Rejecting pacman transaction if running in snapshot...
Performing snapper pre snapshots for the following configurations...
==> root: 109
Installing rtl8852bu-dkms-git (1.19.3.r9.e2c26e9-1)...
Running post-transaction hooks...
Arming ConditionNeedsUpdate...
Install DKMS modules
==> dkms install --no-depmod rtl8852bu/1.19.3.r9.e2c26e9 -k 6.13.1-zen3-1-zen
Error! Bad return status for module build on kernel: 6.13.1-zen3-1-zen (x86_64)
Consult /var/lib/dkms/rtl8852bu/1.19.3.r9.e2c26e9/build/make.log for more information.
==> WARNING: `dkms install --no-depmod rtl8852bu/1.19.3.r9.e2c26e9 -k 6.13.1-zen3-1-zen' exited 10
==> ERROR: Missing 6.13.1-arch2-1 kernel modules tree for module rtl8852bu/1.19.3.r9.e2c26e9.
Updating initramfs...
:: Building initramfs for linux-zen (6.13.1-zen3-1-zen)
Creating group 'nobody' with GID 65534.
Creating group 'audio' with GID 996.
Creating group 'disk' with GID 995.
Creating group 'input' with GID 994.
Creating group 'kmem' with GID 993.
Creating group 'kvm' with GID 992.
Creating group 'lp' with GID 991.
Creating group 'optical' with GID 990.
Creating group 'render' with GID 989.
Creating group 'sgx' with GID 988.
Creating group 'storage' with GID 987.
Creating group 'tty' with GID 5.
Creating group 'uucp' with GID 986.
Creating group 'video' with GID 985.
Creating group 'users' with GID 984.
Creating group 'systemd-journal' with GID 983.
Creating user 'root' (Super User) with UID 0 and GID 0.
Creating user 'nobody' (Kernel Overflow User) with UID 65534 and GID 65534.
:: Building fallback initramfs for linux-zen (6.13.1-zen3-1-zen)
Updating linux initcpios...
Foreign/AUR package notification
Orphaned package notification...
http-parser 2.9.4-2
lib32-libcanberra 1:0.30+r2+gc0620e4-3
libomxil-bellagio 0.9.3-5
opencv 4.11.0-2
python-qtpy 2.4.2-1
vorbis-tools 1.4.2-5
wpebackend-fdo 1.14.3-2
Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/issue.pacnew
/etc/locale.gen.pacnew
/etc/pacman.conf.pacnew
/etc/makepkg.conf.d/rust.conf.pacnew
/etc/updatedb.conf.pacsave
Please check and merge
Performing snapper post snapshots for the following configurations...
==> root: 110
Syncing all file systems...
Transaction successfully finished.
Running sudo dkms status
returns:
nvidia/565.77: broken
Error! nvidia/565.77: Missing the module source directory or the symbolic link pointing to it.
Manual intervention is required!
nvidia/570.86.16, 6.13.1-zen3-1-zen, x86_64: installed
rtl8852bu/1.19.3.r9.e2c26e9: added
I can remove this package, and install the one from
and it installs and works as expected, so this isn’t a dkms issue. I suspect the issue is related to kernel 6.13.1-zen3-1 (64bit), but I cannot be sure because I know little about development/programming.
Output from running sudo garuda-inxi
Kernel: 6.13.1-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: root=UUID=f2b6d210-fe7d-468c-9168-49e00bf58b74 rw
rootflags=subvol=@ quiet loglevel=3 ibt=off intel_iommu=on iommu=pt
initrd=@\boot\initramfs-linux-zen.img
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: LENOVO product: 82AU v: Lenovo Legion 5 15IMH05
serial: <filter> Chassis: type: 10 v: Lenovo Legion 5 15IMH05
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <filter>
part-nu: LENOVO_MT_82AU_BU_idea_FM_Legion 5 15IMH05
uuid: 50ef4d03-a18c-11eb-80ef-38f3ab90854a UEFI: LENOVO v: EFCN59WW
date: 06/09/2023
ID-1: BAT0 charge: 55.2 Wh (95.0%) condition: 58.1/60.0 Wh (96.8%)
volts: 17.0 min: 15.4 model: Celxpert L19C4PC0 type: Li-poly
serial: <filter> status: not charging cycles: 14
Info: model: Intel Core i7-10750H socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 2
microcode: 0xFC
Speed (MHz): avg: 4701 min/max: 800/5000 base/boost: 2475/5000 scaling:
driver: intel_pstate governor: performance volts: 0.8 V ext-clock: 100 MHz
cores: 1: 4701 2: 4701 3: 4701 4: 4701 5: 4701 6: 4701 7: 4701 8: 4701
9: 4701 10: 4701 11: 4701 12: 4701 bogomips: 62399
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: none off: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:5 chip-ID: 5986:2137
class-ID: 0e02
Display: unspecified server: X.Org v: 24.1.5 with: Xwayland v: 24.1.5
gpu: nvidia,nvidia-nvswitch display-ID: :1 screens: 1
s-diag: 583mm (22.95") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: BOE Display 0x0900 built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.86.16 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: N/A device-ID: 10de:1f99
wl: wayland-info x11: xdpyinfo,xprop
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
API: ALSA v: k6.13.1-zen3-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.7 status: n/a (root, process) with:
port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Realtek 802.11ax WLAN Adapter driver: N/A type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-5:4 chip-ID: 0bda:b832
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: disabled
rfk-block: hardware: no software: yes address: see --recommends
Local Storage: total: 2.29 TiB used: 60.81 GiB (2.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM512GDHTNI-87A0B size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11020C00 temp: 34.9 C scheme: GPT
model: WD20SDZW-11JJ8S0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1026 scheme: MBR
ID-1: / raw-size: 154.74 GiB size: 154.74 GiB (100.00%)
used: 36.81 GiB (23.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6
ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 46.8 MiB (2.3%)
fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 74.73 GiB size: 74.73 GiB (100.00%)
used: 23.96 GiB (32.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7
ID-4: /var/log raw-size: 154.74 GiB size: 154.74 GiB (100.00%)
maj-min: 259:6
ID-5: /var/tmp raw-size: 154.74 GiB size: 154.74 GiB (100.00%)
maj-min: 259:6
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 53.0 C pch: 42.0 C mobo: N/A
Memory: total: 32 GiB available: 31.25 GiB used: 2.84 GiB (9.1%)
Processes: 361 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.44 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 1492 libs: 435 tools: pamac,yay pm: flatpak
pkgs: 0 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi (sudo)
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2025-01-10
Last full system update: 2025-02-09
Windows dual boot: Yes
I hope something I provided here helps others discover what the issue is, and how to fix it,
Ernie
