Yesterday I connected my microphone because I needed to use Discord and chat with my friends. I discovered a strange behavior. No matter what I do there is a strange noise coming from my microphone (I guess?). The thing I can hear the noise even if my microphone is not connected and pavucontrol seems to confirm this.
Today I was able do make a recordig of the issue, here: Audio bug Garuda - YouTube
Let me know what logs do you need, I'll gladly provide them to you
SGS
21 July 2022 21:01
#2
Missing your garuda-inxi.
Did it not alert you to include this when you made this post?
SGS
21 July 2022 23:19
#4
Sure, but people do not like to read, my picture about nobody understand (so I moved it away).
And for a video, I have no time
Sorry I must have deleted the text in a hurry
Here's the output:
Kernel: 5.18.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=3b52a2cf-a724-4548-b109-e2a369bab4d2 rw [email protected]
resume=UUID=fb2cf117-9582-47a3-87a3-e38488adb30d loglevel=3 ibt=off
nvidia-drm.modeset=1
Desktop: GNOME v: 42.3.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM
v: 42.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7A34 v: 1.0
Mobo: Micro-Star model: B350 TOMAHAWK (MS-7A34) v: 1.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 1.M0
date: 01/23/2019
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1 stepping: 1
microcode: 0x8001137
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3644 high: 3699 min/max: N/A cores: 1: 3483 2: 3699
3: 3699 4: 3699 5: 3256 6: 3699 7: 3699 8: 3699 9: 3699 10: 3699 11: 3699
12: 3699 bogomips: 88786
Device-1: NVIDIA TU106 [GeForce RTX 2070 Rev. A] vendor: CardExpert
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none off: HDMI-A-1
empty: DP-1, DP-2, DP-3, Unknown-1 bus-ID: 1c:00.0 chip-ID: 10de:1f07
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: BenQ GW2270
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: CardExpert
driver: snd_hda_intel v: kernel bus-ID: 5-3.3.4:11 pcie: chip-ID: 1b1c:0a51
gen: 3 class-ID: 0300 speed: 8 GT/s lanes: 16 bus-ID: 1c:00.1
chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 1e:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Corsair VOID ELITE Wireless Gaming Dongle type: USB
Sound Server-1: ALSA v: k5.18.12-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 19:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp25s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 5-3.3.3:10 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
address: <filter>
Local Storage: total: 2.05 TiB used: 1.3 TiB (63.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: RKT303.3
temp: 39.9 C scheme: MBR
model: WD10EZEX-00MFCA0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: KC48
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 221.27 GiB size: 221.27 GiB (100.00%)
used: 145.59 GiB (65.8%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 221.27 GiB size: 221.27 GiB (100.00%)
ID-3: /var/log raw-size: 221.27 GiB size: 221.27 GiB (100.00%)
ID-4: /var/tmp raw-size: 221.27 GiB size: 221.27 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.57 GiB used: 2.2 MiB (0.0%)
ID-2: swap-2 type: partition size: 17.2 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 376 Uptime: 14h 35m wakeups: 1 Memory: 15.57 GiB
used: 4.45 GiB (28.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: 1590 pacman: 1574 lib: 489
flatpak: 16 Shell: fish v: 3.4.1 running-in: gnome-terminal inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-03-05
Last full system update: 2022-07-20
If your microphone is not connected then the noise can't be coming from the microphone. It could, however, be electrical noise that is being amplified (so check your audio gain settings).
What other changes did you make to your audio setup when you were configuring it for Discord?
zoner
22 July 2022 21:19
#7
So, how close is your cell phone to your setup?
I made no changes to my audio setup
I haven't been using my microphone in a long time
The gain is 100%, if I lower it the noise seems to be gone but my voice too lol
I think it should not be there to begin with
Pretty far and noise is still there
tbg
25 July 2022 17:45
#10
Have you searched extensively for terms such as:
Audio noise Linux
Audio static Linux
I'm sure there must be many hits regarding this issue, as I have researched it in the past when I had similar issues. Sometimes a kernel update would solve the issue, or simply test other kernels for some improvement.
So, I found this Wiki but I don't know how to make such changes since Garuda uses pipewire by default
SGS
25 July 2022 21:44
#12
I created a new config file following the "Microphone is not detected" section, which looks like this:
context.objects = [
{ factory = adapter
args = {
factory.name = api.alsa.pcm.source
node.name = "microphone"
node.description = "Undetected Microphone"
media.class = "Audio/Source"
api.alsa.path = "hw:1,0"
audio.format = "S16LE"
audio.rate = 48000
The issue is still there. To rule out it is a hardware problem, I tested it on Windows too, and it works perfectly
Shall I try pulseaudio, an older kernel peraphs?
If you remove this device, do you still experience the issue?
Yes, I do
Actually, since it is wireless, it is one of the few devices that work flawlessly. But since it's summer and I'd like to avoid using those big headphones, it would be great if this could be sorted out
