I can't switch to sysctl vm.swappiness=10
i set a kernel parameter : sysctl vm.swappiness=10 and followed the archwiki guide
  Kernel: 6.6.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
    available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
    root=UUID=b6b92ddd-1165-4684-927f-b9ae66d45eff rw rootflags=subvol=@ quiet
    rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 mitigations=off
    sysrq_always_enabled=1 elevator=noop sysctl.vm.swappiness=10 ibt=off
  Desktop: GNOME v: 45.2 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM v: 45.0.1
  Type: Laptop System: ASUSTeK product: X540LA v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X540LA v: 1.0 serial: <superuser required> UEFI: American Megatrends
    v: X540LA.303 date: 08/31/2018
  ID-1: BAT0 charge: 17.6 Wh (78.6%) condition: 22.4/33.2 Wh (67.6%) power: 12.3 W volts: 10.8
    min: 10.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: discharging cycles: 747
  Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell gen: core 5 level: v3
    note: check built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61) stepping: 4
    microcode: 0x2F
  Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1896 high: 1897 min/max: 500/1900 scaling: driver: intel_cpufreq
    governor: performance cores: 1: 1896 2: 1897 3: 1896 4: 1896 bogomips: 15962
  Device-1: Intel HD Graphics 5500 vendor: ASUSTeK driver: i915 v: kernel arch: Gen-8
    process: Intel 14nm built: 2014-15 ports: active: DP-1 off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:1616 class-ID: 0300
  Device-2: IMC Networks USB2.0 VGA UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 13d3:5a11 class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3 compositor: gnome-shell
    driver: X: loaded: intel unloaded: modesetting alternate: fbdev,vesa dri: i965 gpu: i915
    display-ID: 0
  Monitor-1: DP-1 model: Samsung SyncMaster serial: <filter> built: 2009 res: 1600x900 dpi: 92
    gamma: 1.2 size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9 modes: max: 1600x900
    min: 720x400
  Monitor-2: eDP-1 model: ChiMei InnoLux 0x15dc built: 2015 res: 1366x768 dpi: 101 gamma: 1.2
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast
    surfaceless: drv: iris wayland: drv: iris x11: drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.1-arch1.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2) device-ID: 8086:1616
    memory: 7.47 GiB unified: yes display-ID: :0.0
  Device-1: Intel Broadwell-U Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
  API: ALSA v: k6.6.8-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.2 chip-ID: 10ec:8136
  IF: enp2s0f2 state: down mac: <filter>
  Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On driver: rtl8723be
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b723
  Device-1: Realtek Bluetooth Radio d
river: btusb v: 0.8 type: USB rev: 2.1 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:b721 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0 lmp-v: 6 status:
    discoverable: no pairing: no class-ID: 1c010c
  Local Storage: total: 704.24 GiB used: 585.11 GiB (83.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253256GB size: 238.47 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 227N
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD5000LPCX-80VHAT1 size: 465.76 GiB
    fw-rev: 1A02 scheme: GPT
  ID-1: / raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 8.6 GiB (34.5%) fs: btrfs
    dev: /dev/sda1 maj-min: 8:1
  ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 584 KiB (0.1%) fs: vfat
    dev: /dev/sda4 maj-min: 8:4
  ID-3: /home raw-size: 9.8 GiB size: 9.8 GiB (100.00%) used: 3.93 GiB (40.1%) fs: btrfs
    dev: /dev/sda2 maj-min: 8:2
  ID-4: /var/log raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 8.6 GiB (34.5%) fs: btrfs
  ID-5: /var/tmp raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 8.6 GiB (34.5%) fs: btrfs
  Kernel: swappiness: 133 (default 60) cache-pressure: 50 (default 100) zswap: no
  ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
  System Temperatures: cpu: 44.0 C pch: 38.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 1900
  Processes: 277 Uptime: 2m wakeups: 0 Memory: total: 8 GiB available: 7.65 GiB
  used: 2.71 GiB (35.4%) Init: systemd v: 255 default: graphical tool: systemctl Compilers:
  gcc: 13.2.1 Packages: 1165 pm: pacman pkgs: 1146 libs: 287 tools: pamac,paru pm: flatpak pkgs: 19
  Client: shell wrapper v: 5.2.21-release inxi: 3.3.31
Garuda (2.6.22-1):
  System install date:     2023-11-27
  Last full system update: 2023-12-26
Where did you stick the sysctl.conf file?
This isn’t enough information for anyone to be able to see if there is an error or misconfiguration somewhere. At the very least, link to the doc you followed and outline the steps you have done so for.
What is the expected result? What are you seeing instead?
Do you understand what changing the swappiness value does? I am asking because there is a lot of misinformation about swappiness.
TL;DR: swappiness does not change the threshold at which your system will start using swap, it changes how aggressively the kernel prefers to swap out pages from physical RAM to the swap space.
okay , this is the sysctl output
sysctl vm.swappiness        ░▒▓ ✔ ▓▒░
vm.swappiness = 133
I set the swapiness value permenantly following this guide in the archwiki https://wiki.archlinux.org/title/Swap
I did
sudo micro /etc/sysctl.d/99-swappiness.conf vm.swappiness = 10
I did create that file :
my output of sudo micro /etc/sysctl.d/99-swappiness.conf :
vm.swappiness = 10
vm.vfs_cache_pressure=50
and set the sysctl vm.swapiness=10 as a kernel parameter like it’s showing in my garuda-inxi.
I understand what swapiness means.
Your only swap device is zram, which has it’s swappiness set in /usr/lib/sysctl.d/99-sysctl-garuda.conf. If you want to change the swappiness of your zram device you can change it there.
Reducing the swappiness of your zram device will most likely reduce your system performance. I’m not sure what you are actually trying to do, but if you are attempting to spare some writes to the disk you should be aware that zram does not use the hard drive, it uses RAM. So you may be sacrificing performance for no benefit.
Testing suggests a higher swappiness value gives better performance on a system using zram.
zram - ArchWiki
Optimizing swap on zram
Since zram behaves differently than disk swap, we can configure the system’s swap to take full potential of the zram advantages:
/etc/sysctl.d/99-vm-zram-parameters.conf
vm.swappiness = 180
vm.watermark_boost_factor = 0
vm.watermark_scale_factor = 125
vm.page-cluster = 0
Explanation of the configuration:
These values are what Pop!_OS uses. That Pop!_OS GitHub PR also links to some testing done by users on r/Fedora, which determined that vm.page-cluster = 0 is ideal. They also found a high swappiness value to be ideal, which matches what is suggested by the kernel docs:
“The default value is 60. For in-memory swap, like zram or zswap, as well as hybrid setups that have swap on faster devices than the filesystem, values beyond 100 can be considered. For example, if the random IO against the swap device is on average 2x faster than IO from the filesystem, swappiness should be 133 (x + 2x = 200, 2x = 133.33).”
On a system with a hard drive, random IO against the zswap device would be orders of magnitude faster than IO against the filesystem, so swappiness should be ~200. Even on a system with a fast SSD, a high swappiness value may be ideal.
I understand now thank you.
