I can't resize my monitor resolution after update (yay)
With the garuda-update my screen was changed to the largest possible screen resolution.
When I wanted to change it again, I saw that there is only this largest option, in the system settings -> monitor.
I don't know what to do and the solutions I found with xrandr don't give me the promised success
Before the update xrandr -q:
Screen 0: minimum 320 x 200, current 1920 x 1200, maximum 16384 x 16384
eDP connected primary 1920x1200+0+0 (normal left inverted right x axis y axis) 302mm x 189mm
   2880x1800     90.00 +  60.00
   1920x1200     90.00*
   1920x1080     90.00
   1600x1200     90.00
   1680x1050     90.00
   1280x1024     90.00
   1440x900      90.00
   1280x800      90.00
   1280x720      90.00
   1024x768      90.00
   800x600       90.00
   640x480       90.00
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
DisplayPort-3 disconnected (normal left inverted right x axis y axis)
DisplayPort-4 disconnected (normal left inverted right x axis y axis)
DisplayPort-5 disconnected (normal left inverted right x axis y axis)
Afterwards xrandr -q:
Screen 0: minimum 320 x 200, current 2880 x 1800, maximum 16384 x 16384
eDP connected primary 2880x1800+0+0 (normal left inverted right x axis y axis) 302mm x 189mm
   2880x1800     90.00*+  60.00
garuda-inxi:
  Kernel: 6.3.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc
    v: 13.1.1 parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
    root=UUID=e2f08cd4-4a33-411b-aeda-1ff7c6bf97cc rw
    rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3
    vt.global_cursor_default=0 loglevel=3 ibt=off
  Type: Convertible System: LENOVO product: 82QF v: Yoga 7 14ARB7
    serial: <superuser required> Chassis: type: 31 v: Yoga 7 14ARB7
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
    serial: <superuser required> UEFI: LENOVO v: K5CN40WW
    date: 04/17/2023
  ID-1: BAT0 charge: 51.2 Wh (71.4%) condition: 71.7/71.0 Wh (101.0%)
    volts: 15.9 min: 15.4 model: LGES L21L4PE0 type: Li-poly
    serial: <filter> status: discharging cycles: 33
  Info: model: AMD Ryzen 7 6800U with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check built: 2022
    process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68)
    stepping: 1 microcode: 0xA404102
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 2214 high: 3274 min/max: 1600/4767 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2142
    2: 1811 3: 1516 4: 2115 5: 3265 6: 3218 7: 1465 8: 1468 9: 1455
    10: 1450 11: 2173 12: 2140 13: 1467 14: 3208 15: 3274 16: 3269
    bogomips: 86238
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
    ssse3 svm
  Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
    v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1
    bus-ID: 33:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 47.0 C
  Device-2: Luxvisions Innotech Integrated RGB Camera
    driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 5-1:2 chip-ID: 30c9:0057 class-ID: fe01
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0
  Screen-1: 0 s-res: 2880x1800 s-dpi: 96
    s-size: 762x476mm (30.00x18.74") s-diag: 898mm (35.37")
  Monitor-1: eDP-1 mapped: eDP model: Samsung 0x417a built: 2020
    res: 2880x1800 hz: 90 dpi: 242 gamma: 1.2
    size: 302x189mm (11.89x7.44") diag: 356mm (14") ratio: 16:10
    modes: 2880x1800
  API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon Graphics
    (rembrandt LLVM 15.0.7 DRM 3.52 6.3.9-zen1-1-zen)
    direct-render: Yes
  Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
    bus-ID: 33:00.1 chip-ID: 1002:1640 class-ID: 0403
    driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x,
    snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 33:00.5 chip-ID: 1022:15e2
    class-ID: 0480
    bus-ID: 33:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.3.9-zen1-1-zen status: kernel-api tools: N/A
    status: active 2: wireplumber status: active 3: pipewire-alsa
    type: plugin 4: pw-jack type: plugin
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network
    Adapter vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:0616
  IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-2: vetheb6fc92 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2
    chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
  Local Storage: total: 476.94 GiB used: 266.93 GiB (56.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
    speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: 0107ANLS temp: 49.9 C scheme: GPT
  ID-1: / raw-size: 200.09 GiB size: 200.09 GiB (100.00%)
    used: 118.75 GiB (59.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 80.5 MiB (83.8%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 200.09 GiB size: 200.09 GiB (100.00%)
  ID-4: /var/log raw-size: 200.09 GiB size: 200.09 GiB (100.00%)
  ID-5: /var/tmp raw-size: 200.09 GiB size: 200.09 GiB (100.00%)
  ID-1: swap-1 type: zram size: 13.34 GiB used: 61.5 MiB (0.5%)
  System Temperatures: cpu: 49.4 C mobo: N/A gpu: amdgpu temp: 48.0 C
  Processes: 423 Uptime: 2m wakeups: 8205 Memory: available: 13.34 GiB
  used: 4.22 GiB (31.6%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman
  pkgs: 1562 libs: 392 tools: octopi,paru Shell: fish v: 3.6.1
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
  System install date:     2023-04-05
  Last full system update: 2023-06-30
  Failed units:            vmware.service
Looks to be the same issue as in this thread:
The issue is currently unsolved, but some of the discussion could prove useful to you.
exactly the same here. i use a Macbook pro. and after an update, the screen is in the biggest resolution (2880x1800) and doesn't have the option to change the settings. and icons and everything is small. and still, I can not solve the problem .
