My spec:
CPU:R5 5600X
GPU:RTX3060TI
Driver:Open source Nvidia driver
RAM:8GB*2
SWAP:16GB
OS:wayfire edition
Hey guys,I couldn't login after the installation.I have tried to login through display manager,when I input the right password,it just login and bring me back to the login page.So I change to TTY2 and I login through TTY successfully and I can enter wayfire.
Also,when I try to bot from a bootable USB to install the system,there are two options: open source driver and proprietary driver,when I choose proprietary driver it won't boot,so I need to switch to open source driver.Is there anyway to use proprietary driver?
Welcome @silverwind63 , please post the output of garuda-inxi so we can take a look. Please also post the output of:
systemctl status display-manager
SGS
30 August 2023 03:26
3
After installation with free driver, you can install the nvidia driver.
BluishHumility:
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ebc17044-ef14-4f0a-bdf5-b94090ac4139 rw rootflags=subvol=@
Desktop: wayfire v: 0.7.5 info: waybar vt: 2 dm: greetd
Mobo: ASUSTeK model: PRIME B550-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2006
date: 03/19/2021
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2303 high: 3447 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2199 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 3447 8: 2200 9: 2200 10: 2200 11: 2200
12: 2199 bogomips: 88803
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] driver: nouveau
v: kernel non-free: 535.xx+ status: current (as of 2023-08) arch: Ampere
code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 08:00.0 chip-ID: 10de:2489 class-ID: 0300
Display: wayland server: Xwayland v: 23.2.0 compositor: wayfire v: 0.7.5
driver: gpu: nouveau display-ID: 1
Monitor-1: HDMI-A-1 model: MSI G241 serial: <filter> built: 2021
res: 1920x1080 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Message: No known Wayland EGL/GBM data sources. API: EGL/GBM
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 10de:228b
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.78 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8168
Local Storage: total: 1.84 TiB used: 410.5 GiB (21.8%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 tech: SSD serial: <filter> fw-rev: 42B9T6TB temp: 38.9 C
used: 410.5 GiB (44.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 64.1 C mobo: N/A
Processes: 469 Uptime: 10m wakeups: 0 Memory: total: 16 GiB
available: 15.52 GiB used: 2.24 GiB (14.5%) Init: systemd v: 254
pm: pacman pkgs: 1279 libs: 403 tools: pamac,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.29
System install date: 2023-08-29
Last full system update: 2023-08-30 ↻
● greetd.service - Greeter daemon
Loaded: loaded (/usr/lib/systemd/system/greetd.service; enabled; preset: disabled)
Active: active (running) since Wed 2023-08-30 17:15:08 CST; 11min ago
Main PID: 747 (greetd)
Tasks: 1 (limit: 19040)
Memory: 4.4M
CPU: 36ms
CGroup: /system.slice/greetd.service
└─747 greetd
8月 30 17:15:08 chen-systemproductname systemd[1]: Started Greeter daemon.
8月 30 17:15:08 chen-systemproductname greetd[747]: config: Config { file: ConfigFile { terminal: ConfigTerminal { vt: Specific(1), switch: true }, general: ConfigGeneral { source_profile: true, runfile: "/run/g>
8月 30 17:15:08 chen-systemproductname greetd[751]: config: Config { file: ConfigFile { terminal: ConfigTerminal { vt: None, switch: false }, general: ConfigGeneral { source_profile: true, runfile: "/run/greetd.>
8月 30 17:15:08 chen-systemproductname greetd[751]: pam_unix(greetd:session): session opened for user greeter(uid=966) by greeter(uid=0)
8月 30 17:15:18 chen-systemproductname greetd[885]: config: Config { file: ConfigFile { terminal: ConfigTerminal { vt: None, switch: false }, general: ConfigGeneral { source_profile: true, runfile: "/run/greetd.>
8月 30 17:15:18 chen-systemproductname greetd[885]: pam_unix(greetd:session): session opened for user chen(uid=1000) by chen(uid=0)
8月 30 17:15:24 chen-systemproductname greetd[1844]: config: Config { file: ConfigFile { terminal: ConfigTerminal { vt: None, switch: false }, general: ConfigGeneral { source_profile: true, runfile: "/run/greetd>
8月 30 17:15:24 chen-systemproductname greetd[1844]: pam_unix(greetd:session): session opened for user greeter(uid=966) by greeter(uid=0)
lines 1-18/18 (END)
I have reply it below,please check it.
silverwind63:
Most likely the display manager is using the wrong keyboard layout.
QtGreet needs the keyboard layout specified explicitly for Wayfire in /etc/qtgreet/wayfire.ini, see here: GitHub - marcusbritanicus/QtGreet: Qt based greeter for greetd, to be run under wayfire or similar wlr-based compositors.
Configuring the keyboard layout for wayfire
Sometimes, it would be easier if the keyboard layout was not the default us. For wayfire, simply add the following line at the end of /etc/qtgreet/wayfire.ini file:
[input] xkb_layout = us
Put the keyboard layout you wish to use in place of us.
For this GPU you may use the nvidia-dkms package.
sudo pacman -S nvidia-dkms
Setting my keyboard layout to us doesn't work.
Please post the output of:
localectl status
I have executed "cat /etc/default/keyboard" and the output said that my keyboard layout is us.Should I run localectl status to check more detail?
Go ahead and paste the output of localectl status into the thread if you get a chance.
Just to clear something up: is the us keyboard layout what you want? Or do you use a different keyboard layout?
BluishHumility:
localectl status
The output:
System Locale: LANG=en_US.UTF-8
LC_NUMERIC=zh_TW.UTF-8
LC_TIME=zh_TW.UTF-8
LC_MONETARY=zh_TW.UTF-8
LC_PAPER=zh_TW.UTF-8
LC_NAME=zh_TW.UTF-8
LC_ADDRESS=zh_TW.UTF-8
LC_TELEPHONE=zh_TW.UTF-8
LC_MEASUREMENT=zh_TW.UTF-8
LC_IDENTIFICATION=zh_TW.UTF-8
VC Keymap: us
X11 Layout: us
Also,after I install nvidia-dkms, when I reboot, I can’t even enter the login page (display manager?) and wayfire,so I reinstall the system and now booting with nouveau.So if I want to use wayland,I can’t use proprietary driver?
What keyboard layout does your password depend on?
Are you still having trouble logging in to the display manager? I’m just trying to determine if the password you are trying to enter is compatible with the keyboard layout you are using.
At this point, Nvidia is pretty well supported on Wayland. Probably your issue is with Wayfire, not Wayland.
Try setting up early KMS like this:
https://wiki.archlinux.org/title/Dracut#Early_kernel_module_loading
sudo micro /etc/dracut.conf.d/nvidia_kms.conf
Paste into the file:
force_drivers+=" nvidia nvidia_modeset nvidia_uvm nvidia_drm "
Save and exit. Then rebuild the initramfs:
sudo dracut-rebuild
ALso, add this kernel parameter:
nvidia_drm.modeset=1
You can add it to the end of the kernel parameter line in Garuda Boot Options, then click Apply .
Next time, you can just restore a snapshot from the boot menu instead of completely reinstalling the system.
Thank for your reply,now it work(both login and Wayland).However my cursor disappeared in wayfire,could you help me?
You must set the WLR_NO_HARDWARE_CURSORS=1 environmental variable, see here: FAQ · WayfireWM/wayfire Wiki · GitHub
You can try setting it in ~/.profile as suggested in this post:
The mouse cursor is invisible
This is a known problem for ex. with the nouveau driver. As a workaround, set the WLR_NO_HARDWARE_CURSORS=1 environmental variable before starting Wayfire.
You can add
export WLR_NO_HARDWARE_CURSORS=1
in ~/. profile
Edit the file:
micro ~/.profile
Add this line:
Save and exit, reboot.
If that doesn’t work, you’ll have to set up a wrapper script for launching Wayfire as described in the Greetd wiki: index - man.sr.ht
system
Closed
15 September 2023 23:35
15
