Hey guys,
first of all here are my system informations
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=abebce50-1051-46a8-b1b1-de9453461e5a rw
rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland
Type: Laptop System: HP product: HP ProBook 450 G8 Notebook PC v: N/A
serial: <superuser required> Chassis: type: 10
Mobo: HP model: 8A75 v: KBC Version 54.18.00
serial: <superuser required> UEFI: HP v: T87 Ver. 01.14.00
date: 06/27/2023
ID-1: BAT0 charge: 37.4 Wh (85.4%) condition: 43.8/45.0 Wh (97.2%)
volts: 13.1 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: charging cycles: 5
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xB4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 806 high: 2102 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 536 3: 401
4: 1816 5: 400 6: 2102 7: 400 8: 400 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics]
vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-12.1
process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:9a49
Device-2: Chicony HP HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 04f2:b6bf
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa
v: 23.2.1-arch1.2 glx-v: 1.4 direct-render: yes renderer: Mesa Intel
Xe Graphics (TGL GT2) device-ID: 8086:9a49 memory: 14.95 GiB
unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 13 device: 0 type: integrated-gpu
name: Intel Xe Graphics (TGL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:9a49 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel Tiger Lake-LP Smart Sound Audio
vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api with: aoss
status: active 2: wireplumber status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4
chip-ID: 8087:0026 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter>
bt-v: 5.2 lmp-v: 11 status: discoverable: no pairing: no
class-ID: 7c010c
Hardware-1: Intel Volume Management Device NVMe RAID Controller
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:9a0b rev:
class-ID: 0104
Local Storage: total: 238.47 GiB used: 91.2 GiB (38.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC711 HFM256GD3JX013N size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD
serial: <filter> fw-rev: HPS1 temp: 38.9 C scheme: GPT
used: 91.2 GiB (38.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
zswap: no
ID-1: swap-1 type: zram size: 15.31 GiB used: 3.44 GiB (22.5%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842
max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 63.0 C mobo: N/A
Processes: 304 Uptime: 50m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.31 GiB used: 8.42 GiB (55.0%) Init: systemd v: 255
pm: pacman pkgs: 3084 libs: 538 tools: octopi,paru Shell: fish
v: 3.6.4 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-12-07
Last full system update: 2023-12-16 ↻
Now to my problem, i cant get to run LoL properly on my system, i installed the epic games launcher, but when i start the game itself it just shows the logo which quits itself without any error message.
Im new to the linux game so it would be great to get some help from you
best regards
Max
