inxi -Faz
System: Kernel: 5.15.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=1409d596-84e3-4768-b0e5-996dc20bb2a5 rw
[email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: LXQt 1.0.0 tk: Qt 5.15.2 info: cairo-dock, lxqt-panel wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: INTEL model: HM65DESK serial: <superuser required> UEFI: American Megatrends v: 4.6.5
date: 02/23/2019
CPU: Info: Dual Core model: Intel Core i7-2620M bits: 64 type: MT MCP arch: Sandy Bridge family: 6 model-id: 2A (42)
stepping: 7 microcode: 2F cache: L1: 128 KiB L2: 512 KiB L3: 4 MiB
flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 21550
Speed: 1091 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 2559 2: 3046 3: 3225 4: 3081
Graphics: Device-1: NVIDIA GM107 [GeForce GTX 750] driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1381 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1360x768 s-dpi: 90 s-size: 384x300mm (15.1x11.8") s-diag: 487mm (19.2")
Monitor-1: HDMI-0 res: 1360x768 hz: 60 dpi: 49 size: 708x398mm (27.9x15.7") diag: 812mm (32")
OpenGL: renderer: NVIDIA GeForce GTX 750/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0fbc class-ID: 0403
Sound Server-1: ALSA v: k5.15.4-zen1-1-zen running: yes
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.40 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Drives: Local Storage: total: 2.78 TiB used: 712.95 GiB (25.0%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 55.9 GiB block-size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s type: SSD serial: <filter> rev: Sb10 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000NM0053 size: 2.73 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: G00A scheme: GPT
Partition: ID-1: / raw-size: 389.6 GiB size: 389.6 GiB (100.00%) used: 318.92 GiB (81.9%) fs: btrfs dev: /dev/sdb4
maj-min: 8:20
ID-2: /boot/efi raw-size: 5.59 GiB size: 5.58 GiB (99.80%) used: 237.7 MiB (4.2%) fs: vfat dev: /dev/sda2
maj-min: 8:2
ID-3: /home raw-size: 389.6 GiB size: 389.6 GiB (100.00%) used: 318.92 GiB (81.9%) fs: btrfs dev: /dev/sdb4
maj-min: 8:20
ID-4: /var/log raw-size: 389.6 GiB size: 389.6 GiB (100.00%) used: 318.92 GiB (81.9%) fs: btrfs dev: /dev/sdb4
maj-min: 8:20
ID-5: /var/tmp raw-size: 389.6 GiB size: 389.6 GiB (100.00%) used: 318.92 GiB (81.9%) fs: btrfs dev: /dev/sdb4
maj-min: 8:20
ID-1: swap-1 type: zram size: 3.79 GiB used: 314.5 MiB (8.1%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Info: Processes: 255 Uptime: 56m wakeups: 0 Memory: 3.79 GiB used: 2.52 GiB (66.6%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1877 lib: 530 flatpak: 0 Shell: fish v: 3.3.1
running-in: qterminal inxi: 3.3.09
Hi everyone, me again. I'm just having the weirdest bug I've ever had. I was watching youtube videos like any other sunday and then: no more internet. Just like that.
Almost.
None of my 4 browsers can connect to any site, my terminal can't update the system because it can't reach the repos, and so on but... Connman still shows that I'm correctly connected, systemctl shows absolutely no errors and... KDE-Connect still could easily and quickly as ever send a 2.3Gb file back and forth between Garuda and my phone? Notification sync is also working perfectly.
-> I tried disconnecting and reconnecting several times, I tried login in and out, I tried rebooting, shuting down, I tried mannually removing the ethernet cable and putting it back in... nothing seems to get my system back online and honestly I ran out of knowledge to solve this problem. Apart from the fact that... the system seems to be online '_'
The last weird thing is that this monday morning, I booted up and there it was: the internet again! Worked perfectly for about one hour and then, back to the same mysterious issue once again. It's just weird, I have no idea what's going on.
Just as aditional info, yes, my phone still can connect to the internet, so can my TV through cable, so can my secondary system in the same exact machine, in which I am right now (and therefore I had to retrieve an inxi-faz from a previous post of mine), so I really think this is a Garuda only issue.
I literally didn't mess up with anything, last time I updated was wednesday (and that was the wildest thing I did with my system all week long) and everything was working fine untill literally from a second to another it just wasn't.
All and any ideas are more than welcome '_'
