I can't connect my wifi
Like i said i cant connect my wifi with garuda gaming edition. I don’t know anything about linux this is my first time and i tested but because i can’t connect the wifi don’t installed. My motherboard mpg z790 edge ti max wifi. Please help me.
Like we wrote in the template
All specs we need are inside.
My Englis is also not that good. If i’m being rude i’m sorry for that. Can you explain step by step? I need internet to learn linux.
You need to run garuda-inxi in the terminal.
Then, copy the output and paste it in this post, using the preformatted text button (</>) at the top of the text box you’re writing your reply into.
But i dont have internet connection​:confused: how can i copy that text.
Are you able to connect your pc with a internet cable so that your issue can be resolved . Or please provide more information so that we are able to help you.
Also, if you have a cell phone with a data plan you can get internet by connecting your phone to your computer. Your computer can connect using your phones WiFi using USB phone tethering.
You can do an offline install, so that you don’t use a bunch of your phone data doing the large update that happens at installation time.
I router is in the other room and i haven’t a cable that long. I can take pictures but i cant upload. I guess in this situation you can’t help me. Thanks anyway.
See my post just above your last reply.
Do an offline install. Internet is not required to install Garuda.
Then use USB phone tetherering to upload your garuda-inxi output to the forum.
I plug my phone but it does not work
Search the internet on your phone. Search terms:
How to use USB Android phone tethering for internrt.
i did it finally.
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=a30942f6-d422-421f-a2e3-fcee2a9a6290 rw rootflags=subvol=@
quiet rd.luks.uuid=9bfe9d4c-b699-4239-9a3f-fce7773ec9c4 loglevel=3
Type: Desktop Mobo: Micro-Star model: MPG Z790 EDGE TI MAX WIFI (MS-7E25)
v: 1.0 serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.70 date: 08/14/2024
Info: model: Intel Core i7-14700KF bits: 64 type: MST AMCP arch: Raptor Lake
gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x129
Topology: cpus: 1x cores: 20 mt: 8 tpc: 2 st: 12 threads: 28 smt: enabled
cache: L1: 1.8 MiB desc: d-12x32 KiB, 8x48 KiB; i-8x32 KiB, 12x64 KiB
L2: 28 MiB desc: 8x2 MiB, 3x4 MiB L3: 33 MiB desc: 1x33 MiB
Speed (MHz): avg: 805 high: 958 min/max: 800/5500:5600:4300 scaling:
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 958 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 25: 800 26: 800 27: 800 28: 800 bogomips: 191385
Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti] vendor: Micro-Star MSI
driver: nvidia v: 550.76 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: none off: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 01:00.0
chip-ID: 10de:2803 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia d-rect: 4480x2520
display-ID: 0
Monitor-1: DP-3 pos: top-right res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.76
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060 Ti/PCIe/SSE2
memory: 15.62 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Ti driver: nvidia v: 550.76 device-ID: 10de:2803
Device-1: Intel Raptor Lake High Definition Audio vendor: Micro-Star MSI
Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22bd
Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:9
chip-ID: 0db0:a74b class-ID: 0300
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api with: aoss
Device-1: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
Device-2: Qualcomm WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800]
vendor: Foxconn Band Simultaneous Wireless driver: ath12k_pci v: N/A
modules: ath12k pcie: gen: 3 speed: 8 GT/s lanes: 1 link-max: lanes: 2
bus-ID: 04:00.0 chip-ID: 17cb:1107 class-ID: 0280
IF-ID-1: enp0s20f0u1 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung Galaxy series misc. (tethering mode) driver: rndis_host
v: kernel type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-1:16 chip-ID: 04e8:6863 class-ID: 0a00 serial: <filter>
Device-2: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:11 chip-ID: 0489:e10a
Local Storage: total: 3.75 TiB used: 9.01 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with
Heatsink 4TB size: 3.64 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QJXG7
temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: USB 3.2Gen1
size: 114.6 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 9.01 GiB (0.2%)
mapped: luks-9bfe9d4c-b699-4239-9a3f-fce7773ec9c4
used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 9.01 GiB (0.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
ID-5: /var/tmp raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
ID-1: swap-1 type: zram size: 46.89 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 28 dev: /dev/zram0
System Temperatures: cpu: 24.0 C mobo: N/A
Memory: total: 48 GiB available: 46.89 GiB used: 3.7 GiB (7.9%)
Processes: 463 Power: uptime: 40m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.72 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1805 libs: 531 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
uyarı: database file for 'garuda' does not exist (use '-Sy' to download)
uyarı: database file for 'core' does not exist (use '-Sy' to download)
uyarı: database file for 'extra' does not exist (use '-Sy' to download)
uyarı: database file for 'community' does not exist (use '-Sy' to download)
uyarı: database file for 'multilib' does not exist (use '-Sy' to download)
uyarı: database file for 'chaotic-aur' does not exist (use '-Sy' to download)
System install date:     2024-11-24
Last full system update: 2024-11-24
I did a quick search on the mobo model you gave in your initial post. What info I found online listed an Intel Wi-Fi 6e as the chip used on the mainboard.
I was not expecting your mobo to have Wi-Fi 7 installed, as this standard was only just ratified very recently.
Yours is the first garuda-inxi output that I have seen on the forum here with a Wi-Fi 7 chip onboard.
I’ll have to do some research, but my first complete guess would be this chip has not been certified for use in your region yet.
The other possibility is that the Atheros Wi-Fi 7 driver simply doesn’t have proper Linux kernel support as yet.
Unfortunately, very recently released hardware sometimes takes a long time before it works reliably in Linux.
I figured out someway. Re-install garuda do nothing exept turn off/on wifi, and turn on/off airplane mod. restart the system. Don’t understand but it worked. But i have plenty of other problems. forexample steam is installed but i can’t run it, so i decided to learn linux on virtual machine first. Thanks @tbg @TilliDie . i want to thank SGS and Heyian too but the site don’t let me to mention after 2. Thanks.
https://forum.garudalinux.org/faq#keep-tidy
Rather than posting “Thank you”, “+1” or “Agreed”, use the like button :heart: .
I think the solution comes from I can't connect my wifi - #15 by tbg :slight_smile:
