When i am trying to connect my pc to my mobile hotspot i cant connect it first shows this message
Limited Connectivity
This device appears to be connected to a network but is unable to reach the internet.
Then after few seconds it shows this message
Wireless Interface (wlp1s0f0u7)
IP configuration was unavailable
and then it connects to another active hotspot
i thought that my mobile hotspot has problem but when i connect my another phone with that hotspot it connects
output of inxi -Fxxxza
System: Kernel: 5.12.2-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=9699b3da-875a-4507-9cf0-a4a1b0dc3b79
systemd.unified_cgroup_hierarchy=1 resume=UUID=34b61e46-1cf3-44cb-8205-37ea3381524a loglevel=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: EX-A320M-GAMING v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 5007 date: 06/18/2019
CPU: Info: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64 type: MT MCP
arch: Zen/Zen+ note: check family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108102
cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 59089
Speed: 1249 MHz min/max: 1400/3700 MHz boost: enabled Core speeds (MHz): 1: 1249 2: 1305
3: 1726 4: 1311 5: 1314 6: 2453 7: 2342 8: 1246
Graphics: Device-1: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 06:00.0
chip-ID: 1002:15d8 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4") s-diag: 485mm (19.1")
Monitor-1: HDMI-A-0 res: 1600x900 hz: 60 dpi: 94 size: 434x236mm (17.1x9.3")
diag: 494mm (19.4")
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.40.0 5.12.2-zen2-1-zen LLVM 11.1.0)
v: 4.6 Mesa 21.1.0 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 06:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.12.2-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB driver: r8188eu
bus-ID: 1-7:2 chip-ID: 0bda:8179 class-ID: 0000 serial: <filter>
IF: wlp1s0f0u7 state: up mac: <filter>
Drives: Local Storage: total: 689.33 GiB used: 127.9 GiB (18.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 041
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500414CS size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s rotation: 5900 rpm serial: <filter> rev: CA14
Partition: ID-1: / raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 13.07 GiB (6.1%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 13.07 GiB (6.1%) fs: btrfs
ID-4: /var/log raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 13.07 GiB (6.1%) fs: btrfs
ID-5: /var/tmp raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 13.07 GiB (6.1%) fs: btrfs
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 740.7 MiB used: 3 MiB (0.4%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 740.7 MiB used: 3.1 MiB (0.4%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 740.7 MiB used: 2.6 MiB (0.4%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 740.7 MiB used: 2.9 MiB (0.4%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 740.7 MiB used: 2.7 MiB (0.4%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 740.7 MiB used: 2.5 MiB (0.3%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 740.7 MiB used: 2.6 MiB (0.4%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 740.7 MiB used: 2.5 MiB (0.3%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 47.2 C mobo: 0 C gpu: amdgpu temp: 47.0 C
Info: Processes: 311 Uptime: 40m wakeups: 0 Memory: 5.79 GiB used: 2.92 GiB (50.5%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1212 lib: 301
Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
Aakarsh:
r8188eu
Seems a driver issue,
check if the driver is active.
Search in arch wiki.
Recently I have updated kernel I think I got two updates for kernel and I updated both times
Before kernel update it works fine
Then restore last working snapshot and wait for kernel fix.
I think this is a problem with your phone, not Garuda. My guess is you've exhausted your phone's monthly high speed data limit for the month with your service provider. When this happens your phone's internet will work, but you can't share your phone's internet connection.
I've posted an issue describing my wifi problem
Very few times wifi connects to that phone , can i check why this time wifi connects to that phone hotspot
and always it failed to connect
(If log files genereted where are they stored means where i can find these logs?)
Points to note--
1-- i noticed that if pc starts and tried to connect to that phone hotspot and if it failed there there is no chance that it will connect if tried again and again , it might connect after next boot (not 100% sure)
i want to check what is happening with wifi apdater so that sometimes it connect and sometimes it didnt connect
2--No problem with that phone (phone that i am trying to connect) as other phones can connect to this phone
3-- i am using usb wifi adapter
4-- when pc trying to connect with my phone , in my phone it says 1 device connected and data shared is 0b(0 byte) and then after few seconds pc disconnects
inxi -Fxxxza
System: Kernel: 5.12.4-zen1-2-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9699b3da-875a-4507-9cf0-a4a1b0dc3b79 rw rootflags=subvol=@ quiet splash
CPU: Info: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics socket: AM4
bits: 64 type: MT MCP arch: Zen/Zen+ note: check family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108102 cache: L1: 384 KiB L2: 2 MiB L3: 4 MiB
bogomips: 59087
Speed: 1256 MHz min/max: 1400/3700 MHz base/boost: 3700/4200 boost: enabled
volts: 1.5 V ext-clock: 100 MHz Core speeds (MHz): 1: 1256 2: 1226 3: 2698 4: 1224
5: 2464 6: 1730 7: 2302 8: 1334
diag: 494mm (19.4")
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.40.0 5.12.4-zen1-2-zen
LLVM 11.1.0)
driver: snd_hda_intel v: kernel bus-ID: 06:00.1 chip-ID: 1002:15de class-ID: 0403
Sound Server-1: ALSA v: k5.12.4-zen1-2-zen running: yes
driver: r8169 v: kernel port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
driver: r8188eu bus-ID: 1-7:2 chip-ID: 0bda:8179 class-ID: 0000 serial: <filter>
Drives: Local Storage: total: 689.33 GiB used: 127.57 GiB (18.5%)
family: Micron Client SSDs size: 223.57 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 041
temp: 41 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 5d 0h cycles: 351 written: 688.17 GiB
family: Pipeline HD 5900.2 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 3.0 Gb/s rotation: 5900 rpm serial: <filter>
rev: CA14 temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 6y 11d 15h cycles: 1819 Pre-Fail:
attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
Partition: ID-1: / raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 17.81 GiB (8.3%)
fs: btrfs block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 17.81 GiB (8.3%)
used: 17.81 GiB (8.3%) fs: btrfs block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
dev: /dev/sda3 maj-min: 8:3
ID-2: swap-2 type: zram size: 740.9 MiB used: 256 KiB (0.0%) priority: 32767
ID-3: swap-3 type: zram size: 740.9 MiB used: 256 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-4: swap-4 type: zram size: 740.9 MiB used: 256 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-5: swap-5 type: zram size: 740.9 MiB used: 256 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-6: swap-6 type: zram size: 740.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-7: swap-7 type: zram size: 740.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-8: swap-8 type: zram size: 740.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-9: swap-9 type: zram size: 740.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
Sensors: System Temperatures: cpu: 48.1 C mobo: 0 C gpu: amdgpu temp: 48.0 C
Info: Processes: 300 Uptime: 1h 03m wakeups: 0 Memory: 5.79 GiB used: 2.35 GiB (40.7%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 11.1.0
Packages: pacman: 1216 lib: 301 Shell: Bash (su) v: 5.1.8 running-in: konsole
inxi: 3.3.04
filo
19 May 2021 09:06
10
I'm not aware of any specific logs, but my knowledge is limited there.
I normally refer to the journal, e.g. in your case this could be:
sudo journalctl -b -1 | grep wlp1s0f0u7
But, as said, this is only a possible starting point, maybe also dmesg, I don't know better....
I believe you were warned that there maybe side effects from disabling the NM wait online service.
However, any services or software that require a network connection to be active when they start may fail or not work as expected. Therefore, if you disable it make sure to remember that you made that change so you can revert it if necessary.
Before disabling network manager online service
this problem exist
Can anyone tell me how to change driver of network adapter?
filo
21 May 2021 12:47
14
Unfortunately you have to search and try, I think there's no guaranteed solution.
In our forum, I see several times mentioned 8188eu-aircrack-dkms-git:
sudo pacman -S 8188eu-aircrack-dkms-git
After a quick internet search, I see also at least:
https://github.com/lwfinger/rtl8188eu
https://github.com/quickreflex/rtl8188eus
Both have to be git cloned and complied as per readme.
It looks like the former is actively maintained and the latter last updated on 22 mar 2019...
This is called an empty bump. Provide further information if you wish to elevate your post. Add more posts to your thread when you have some useful information to provide others. Until then your your empty posts are of little usefulness.
Your original thread was already locked as you have provided scant useful information and you are not easy to work with. I merged your most recent thread with your prior one as they are obviously the same issue. I reopened your original thread, as you seemed to want to continue this topic. Please don’t make me regret reopening your thread.
If you have nothing substantive to add to this thread then wait until you have something worthwhile before making further posts. If others were interested in contributing to this thread they would do so. Continuous prodding of others is not the proper way to get further assistance on the forum.
what further information you are expecting from me?
tell me i wiil give you
tbg
Closed
22 May 2021 08:37
17
Thread will reopen in 2 days. See if you can find some pertinent info to add when it is reopened. You do not need to be led by the hand. Search the WWW.
