I cannot shrink a partition, where my garuda is running
I cannot shrink a partition, where my garuda is running ,
To do that you have to use a live USB, unmount the partition, if mounted, and shrink, possibly with gparted
I want to shrink "/", this partition.
When i unmount it ; It show me this: "The file system on partition ‘/dev/sda1’ could not be unmounted."
Booting from a live USB?
I am assuming that you are not currently using the partition you are trying to change.
Try gparted, this has always worked for me so far.
I have already install garuda.
When i was installing it , I had use the all storage.
And now i need some partition, to use windows on it.
Ok but you have to boot from a live USB, not from your HD
I don't have any usb, so i tried on hdd.
Dear @filo ,
Thank you so much for your response.
I tried to resize, the system partition.
And I got the solution.
