i try to mount device and see could not mount massage
in other linux distro i have not problem
my device is a external hard 1TB/western digital /format=ntfs
this is my first question if i had mistake i'm sorry
Welcome ![]()
You are not alone, just search in forum or web for ntfs, gnome-disk-utility and fstab.
Just read the template ![]()
Hello.
Kernel: 5.16.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=070f3418-a9f5-485f-bb0a-6bab612b20cb rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 info: latte-dock
Type: Laptop System: ASUSTeK product: N552VW v: 1.0
Mobo: ASUSTeK model: N552VW v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: N552VW.204 date: 02/04/2016
ID-1: BAT0 charge: 0 Wh (0.0%) condition: 31.8/48.0 Wh (66.3%) volts: 15.0
min: 15.0 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 302
Info: model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3320 high: 3501 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 3313 2: 3300 3: 3296
4: 3250 5: 3301 6: 3501 7: 3301 8: 3302 bogomips: 41599
Type: l1tf
Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel
ports: active: HDMI-A-2,eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: ASUSTeK
driver: nouveau v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:139b
class-ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-4:2 chip-ID: 13d3:5666 class-ID: 0e02 serial: <filter>
loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
Screen-1: 0 s-res: 2443x1980 s-dpi: 96 s-size: 645x523mm (25.39x20.59")
s-diag: 830mm (32.69")
Monitor-1: HDMI-A-2 mapped: HDMI2 pos: bottom-r
model: LG (GoldStar) HD PLUS built: 2016 res: 1600x900 hz: 60 dpi: 92
gamma: 1.2 size: 440x250mm (17.32x9.84") diag: 506mm (19.9") ratio: 16:9
modes: max: 1600x900 min: 720x400
Monitor-2: eDP-1 mapped: eDP1 pos: primary,top-left
model: LG Display 0x04d4 built: 2015 res: 1920x1080 hz: 60 dpi: 143
gamma: 1.2 size: 340x190mm (13.39x7.48") diag: 395mm (15.5") ratio: 16:9
modes: 3840x2160
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
lanes: 1 port: d000 bus-ID: 03:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0f1 state: down mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
bus-ID: 1-9:4 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 2.87 TiB used: 1.37 TiB (47.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNLF128HCHP-00004
type: SSD serial: <filter> rev: 301Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate
model: ST2000LM003 HN-M201RAD size: 1.82 TiB block-size: physical: 4096 B
rev: 0001 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Ultra
size: 28.65 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital
model: WD My Passport 0820 size: 931.48 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1007 scheme: MBR
ID-1: / raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
used: 20.56 GiB (35.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 60.16 GiB size: 60.16 GiB (100.00%)
used: 955.1 MiB (1.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
ID-5: /var/tmp raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.58 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.0 C pch: 53.5 C mobo: N/A gpu: nouveau
temp: 53.0 C
Fan Speeds (RPM): cpu: 2100
Processes: 306 Uptime: 3h 23m wakeups: 10383 Memory: 11.59 GiB
used: 3.25 GiB (28.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1182 lib: 297 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-03-24
Last full system update: 2022-03-26
@matin might want to check on this one External hard disk mount problem
Be sure you disable fast startup in Windows.
Also test the LTS kernel.
Thank you everyone
problem has solved and i don't know how
if anybody has the same problem please be patient
Garuda "Magic" Linux.
