Firas
10 February 2023 08:54
1
I am Following these instructions here
https://forum.garudalinux.org/t/remove-access-restriction-from-home-directory/712
after putting usermod -u 1000 it asks for a password I put in the password says login incorrect
I am 100% sure my password is correct and then I tried to leave it empty
and that did not work also
any help on how to get permission for directories?
btw all I want is to run MAKEPKG -sri
here https://www.addictivetips.com/ubuntu-linux-tips/run-foobar2000-on-linux/
Ξ» garuda-inxi
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "de_DE.UTF-8",
LC_NAME = "de_DE.UTF-8",
LC_MONETARY = "de_DE.UTF-8",
LC_PAPER = "de_DE.UTF-8",
LC_IDENTIFICATION = "de_DE.UTF-8",
LC_TELEPHONE = "de_DE.UTF-8",
LC_MEASUREMENT = "de_DE.UTF-8",
LC_TIME = "de_DE.UTF-8",
LC_NUMERIC = "de_DE.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 6.1.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=0f858422-e127-45ae-b225-bbbaf6192ae4 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 2601 date: 05/17/2022
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1550 high: 3800 min/max: 800/5100 scaling:
5: 800 6: 3800 7: 800 8: 800 9: 800 10: 800 11: 3800 12: 3800 13: 800
14: 800 15: 3800 16: 800 bogomips: 121596
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: HDMI-A-1 empty: DP-1, DP-2, DVI-D-1, HDMI-A-2
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 51.0 C
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.7
s-diag: 777mm (30.58")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC Q32G1WG4 serial: <filter>
built: 2019 res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x393mm (27.44x15.47")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon RX 580 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.1.10-zen1-1-zen) direct-render: Yes
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound API: ALSA v: k6.1.10-zen1-1-zen running: yes
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 3.18 TiB used: 8.81 GiB (0.3%)
model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
rev: 211070WD temp: 32.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
rev: 2B2QEXM7 temp: 42.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD130 size: 2.73 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
ID-1: / raw-size: 232.59 GiB size: 232.59 GiB (100.00%) used: 8.8 GiB (3.8%)
used: 8.8 GiB (3.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 34.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1222
Processes: 321 Uptime: 13m wakeups: 0 Memory: 31.25 GiB
used: 2.72 GiB (8.7%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1326
libs: 325 tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.0
running-in: konsole inxi: 3.3.25
Garuda (2.6.14-1):
System install date: 2023-02-09
Last full system update: 2023-02-10
Can you explain why you think this thread is related to your situation? This sounds like it may be an XY problem .
The instructions are pretty straightforward; where are you encountering an issue?
Alternatively, just use Paru.
paru trizen
Review the build, press Q to get out of the review and start the install.
Re foobar2000: maybe give deadbeef a try, it's very similar and linux native.
Binary package is in chaotic-aur. Plugins only in AUR though.
Firas
10 February 2023 12:53
4
@BluishHumility
ββfiraswtips@firaswtips in repo: trizen on ο master
β°βΞ» paru trizen
error: failed to initialize alpm: root=/ dbpath=/var/lib/pacman/: database already registered
Hi Thanks, I found out you can also
right click and choose root action and that will give u permission also
But I would Like to Know why is the TTY3 not working or what did I do wrong
Just in case I need to use it in the future
btw how can I log in as root always?
Firas
10 February 2023 12:54
5
@meanruse
ββfiraswtips@firaswtips in ~
β°βΞ» sudo pacman -S deadbeef
sudo: /etc/sudo.conf is owned by uid 1000, should be 0
sudo: /etc/sudoers is owned by uid 1000, should be 0
sudo: no valid sudoers sources found, quitting
sudo: error initializing audit plugin sudoers_audit
I will give it a Try
Many thanks
Deabeef is an audio player for GNU/Linux
this is not what I'm looking for
Oof, thatβs not good. What is the output of:
ls -la /etc
what the hell have you done there???
that should be owned by root, id 0
Firas
10 February 2023 13:37
8
BluishHumility:
β°βΞ» ls -la /etc
drwxr-xr-x - firaswtips 10 Feb 14:32 ο .
drwxr-xr-x - root 10 Feb 10:05 ο ..
drwxr-xr-x - firaswtips 19 Oct 2022 ο alsa
drwxr-xr-x - firaswtips 9 Feb 21:45 ο ananicy.d
drwxr-xr-x - firaswtips 9 Feb 21:13 ο audit
drwxr-xr-x - firaswtips 19 Oct 2022 ο avahi
drwxr-xr-x - firaswtips 14 Oct 2022 ο binfmt.d
dr-xr-xr-x - firaswtips 9 Feb 21:14 ο bluetooth
drwxr-xr-x - firaswtips 19 Oct 2022 ο ca-certificates
drwxr-xr-x - firaswtips 19 Oct 2022 ο chromium
drwxr-xr-x - firaswtips 9 Feb 21:14 ο cifs-utils
drwxr-xr-x - firaswtips 9 Feb 21:21 ο conf.d
drwxr-xr-x - firaswtips 9 Feb 21:14 ο cron.daily
drwxr-xr-x - firaswtips 9 Feb 21:14 ο cron.hourly
drwxr-xr-x - firaswtips 9 Feb 21:14 ο daxctl.conf.d
drwxr-xr-x - firaswtips 9 Feb 21:21 ο dbus-1
drwxr-xr-x - firaswtips 19 Oct 2022 ο dconf
drwxr-xr-x - firaswtips 9 Feb 21:13 ο debuginfod
drwxr-xr-x - firaswtips 10 Feb 00:13 ο default
drwxr-xr-x - firaswtips 30 Jun 2022 ο depmod.d
drwxr-xr-x - firaswtips 9 Aug 2022 ο exports.d
drwxr-xr-x - firaswtips 9 Feb 21:14 ο fastfetch
drwxr-xr-x - firaswtips 9 Feb 21:14 ο fish
drwxr-xr-x - firaswtips 9 Feb 21:13 ο fonts
drwxr-xr-x - firaswtips 9 Feb 21:14 ο fwupd
drwxr-xr-x - firaswtips 19 Oct 2022 ο garuda
drwxr-xr-x - firaswtips 19 Oct 2022 ο garuda-settings
drwxr-xr-x - firaswtips 9 Feb 21:14 ο geoclue
drwxr-xr-x - firaswtips 10 Feb 00:02 ο grub.d
drwxr-xr-x - firaswtips 19 Oct 2022 ο gss
drwxr-xr-x - firaswtips 19 Oct 2022 ο gssproxy
drwxr-xr-x - firaswtips 9 Feb 21:21 ο gtk-2.0
drwxr-xr-x - firaswtips 9 Feb 21:14 ο gtk-3.0
drwxr-xr-x - firaswtips 9 Feb 21:14 ο hostapd
drwxr-xr-x - firaswtips 9 Feb 21:14 ο ImageMagick-7
drwxr-xr-x - firaswtips 19 Oct 2022 ο initcpio
drwxr-xr-x - firaswtips 9 Feb 21:14 ο iproute2
drwxr-xr-x - firaswtips 19 Oct 2022 ο ipsec.d
drwxr-xr-x - firaswtips 9 Feb 21:13 ο iptables
drwxr-xr-x - firaswtips 19 Oct 2022 ο kernel
drwxr-xr-x - firaswtips 7 Jul 2020 ο keyutils
drwxr-xr-x - firaswtips 9 Feb 21:13 ο ld.so.conf.d
drwxr-xr-x - firaswtips 19 Oct 2022 ο libblockdev
drwxr-xr-x - firaswtips 12 Jun 2022 ο libinput
drwxr-xr-x - firaswtips 9 Feb 21:13 ο libnl
drwxr-xr-x - firaswtips 21 May 2022 ο libpaper.d
drwxr-xr-x - firaswtips 19 Oct 2022 ο libsmbios
drwxr-xr-x - firaswtips 9 Feb 21:14 ο lirc
drwxr-xr-x - firaswtips 9 Feb 21:21 ο logrotate.d
drwxr-xr-x - firaswtips 9 Feb 21:14 ο lvm
drwxr-xr-x - firaswtips 9 Feb 21:14 ο mercurial
drwxr-xr-x - firaswtips 19 Oct 2022 ο mkinitcpio-systemd-tool
drwxr-xr-x - firaswtips 9 Feb 21:22 ο mkinitcpio.d
drwxr-xr-x - firaswtips 19 Oct 2022 ο ModemManager
drwxr-xr-x - firaswtips 30 Jun 2022 ο modprobe.d
drwxr-xr-x - firaswtips 14 Oct 2022 ο modules-load.d
drwxr-xr-x - firaswtips 9 Feb 21:14 ο mpv
drwxr-xr-x - firaswtips 19 Oct 2022 ο ndctl
drwxr-xr-x - firaswtips 9 Feb 21:14 ο ndctl.conf.d
drwxr-xr-x - firaswtips 9 Feb 21:14 ο NetworkManager
drwxr-xr-x - firaswtips 19 Oct 2022 ο nginx
drwxr-xr-x - firaswtips 11 May 2022 ο ODBCDataSources
drwxr-xr-x - firaswtips 9 Feb 21:14 ο openfortivpn
drwxr-xr-x - firaswtips 9 Feb 21:14 ο openldap
drwxr-xr-x - firaswtips 19 Oct 2022 ο openmpi
drwxr-xr-x - firaswtips 9 Feb 21:14 ο openpmix
drwxr-xr-x - firaswtips 19 Oct 2022 ο openvpn
drwxr-xr-x - firaswtips 19 Oct 2022 ο opt
drwxr-xr-x - firaswtips 9 Feb 21:21 ο PackageKit
drwxr-xr-x - firaswtips 10 Feb 10:33 ο pacman.d
drwxr-xr-x - firaswtips 9 Feb 21:14 ο pam.d
drwxr-xr-x - firaswtips 19 Oct 2022 ο pinentry
drwxr-xr-x - firaswtips 19 Oct 2022 ο pipewire
drwxr-xr-x - firaswtips 19 Oct 2022 ο pkcs11
drwxr-xr-x - firaswtips 19 Oct 2022 ο pki
drwxr-xr-x - firaswtips 9 Feb 22:11 ο plymouth
drwxr-xr-x - firaswtips 19 Oct 2022 ο polkit-1
drwxr-xr-x - firaswtips 10 Feb 10:38 ο powerpill
drwxr-xr-x - firaswtips 9 Feb 21:14 ο ppp
drwxr-xr-x - firaswtips 10 Feb 08:22 ο profile.d
drwxr-xr-x - firaswtips 9 Feb 21:14 ο pulse
drwxr-xr-x - firaswtips 31 Oct 2021 ο rc_keymaps
drwxr-xr-x - firaswtips 9 Feb 21:14 ο request-key.d
drwxr-xr-x - firaswtips 10 Feb 00:21 ο sddm.conf.d
drwxr-xr-x - firaswtips 10 Feb 09:59 ο security
drwxr-xr-x - firaswtips 18 Feb 2021 ο sensors.d
drwxr-xr-x - firaswtips 9 Feb 21:14 ο skel
drwxr-xr-x - firaswtips 19 Oct 2022 ο snapper
drwxr-xr-x - firaswtips 9 Feb 21:14 ο ssh
drwxr-xr-x - firaswtips 9 Feb 21:13 ο ssl
drwxr-xr-x - firaswtips 9 Feb 21:14 ο sstpc
drwxr-xr-x - firaswtips 9 Feb 21:14 ο strongswan.d
drwxr-x--- - firaswtips 9 Feb 21:14 ο sudoers.d
drwxr-xr-x - firaswtips 9 Feb 21:14 ο swanctl
drwxr-xr-x - firaswtips 14 Oct 2022 ο sysctl.d
drwxr-xr-x - firaswtips 9 Feb 21:13 ο systemd
drwxr-xr-x - firaswtips 14 Oct 2022 ο tmpfiles.d
drwxr-xr-x - firaswtips 9 Feb 21:13 ο tpm2-tss
drwxr-xr-x - firaswtips 9 Feb 21:13 ο udev
drwxr-xr-x - firaswtips 19 Oct 2022 ο udisks2
drwxr-xr-x - firaswtips 19 Oct 2022 ο ufw
drwxr-xr-x - firaswtips 9 Feb 21:14 ο UPower
drwxr-xr-x - firaswtips 8 Mar 2022 ο usb_modeswitch.d
drwxr-xr-x - firaswtips 9 Feb 21:14 ο vpnc
drwx------ - firaswtips 14 Sep 2021 ο wireguard
drwxr-xr-x - firaswtips 3 Aug 2022 ο wpa_supplicant
drwxr-xr-x - firaswtips 19 Oct 2022 ο X11
drwxr-xr-x - firaswtips 9 Feb 21:14 ο xdg
drwxr-xr-x - firaswtips 9 Feb 21:14 ο xinetd.d
drwxr-xr-x - firaswtips 9 Feb 21:14 ο xl2tpd
drwxr-xr-x - firaswtips 9 Feb 21:21 ο Yozosoft
.rw------- 0 firaswtips 19 Oct 2022 ο£ .pwd.lock
.rw-r--r-- 208 root 10 Feb 14:22 ο
.updated
.rw-r--r-- 44 firaswtips 9 Feb 21:06 ο adjtime
.rw-r--r-- 833 firaswtips 27 Jan 07:58 ξ appstream.conf
.rw-r--r-- 0 firaswtips 31 Jan 21:51 ο arch-release
.rw-r--r-- 0 firaswtips 27 Jan 19:44 ξ arptables.conf
.rw-r--r-- 28 firaswtips 2 Feb 07:38 ο
bash.bash_logout
.rw-r--r-- 605 firaswtips 2 Feb 07:38 ο bash.bashrc
.rw-r--r-- 2.4k firaswtips 27 Jan 21:20 ο
bind.keys
.rw-r--r-- 535 firaswtips 15 Nov 2022 ο
bindresvport.blacklist
.rw-r--r-- 779 firaswtips 7 Jan 20:16 ξ btrfs-assistant.conf
.rw-r--r-- 432 firaswtips 5 Nov 2022 ξ create_ap.conf
.rw------- 576 firaswtips 9 Feb 21:05 ο crypttab
.rw-r--r-- 28k firaswtips 5 Feb 21:18 ξ dnsmasq.conf
.rw-r--r-- 685 firaswtips 2 Feb 21:00 ξ e2scrub.conf
.rw-r--r-- 0 firaswtips 27 Jan 19:44 ξ ebtables.conf
.rw-r--r-- 97 firaswtips 8 Sep 2021 ο environment
.rw-r--r-- 1.4k firaswtips 27 Jan 19:44 ο ethertypes
.rw-r--r-- 429 firaswtips 9 Aug 2022 ο exports
.rw-r--r-- 20 firaswtips 26 Feb 2022 ξ fprintd.conf
.rw-r--r-- 1.4k firaswtips 9 Feb 21:05 ο fstab
.rw-r--r-- 694 firaswtips 13 Jan 18:57 ξ fuse.conf
.rw-r--r-- 2.6k firaswtips 3 Feb 19:27 ξ gai.conf
.rw-r--r-- 3.9k firaswtips 3 Feb 13:50 ο
gprofng.rc
.rw-r--r-- 1.0k firaswtips 10 Feb 14:32 ο group
.rw-r--r-- 1.0k firaswtips 10 Feb 14:31 ο group-
.rw------- 907 firaswtips 10 Feb 01:10 ο gshadow
.rw------- 893 firaswtips 9 Feb 21:22 ο gshadow-
.rw-r--r-- 450 firaswtips 17 Nov 2022 ξ healthd.conf
.rw-r--r-- 73 firaswtips 31 Jan 21:51 ξ host.conf
.rw-r--r-- 29 firaswtips 9 Feb 21:05 ο hostname
.rw-r--r-- 8.8M firaswtips 9 Feb 21:28 ο hosts
.rw-r--r-- 5.8k firaswtips 9 Aug 2022 ξ idmapd.conf
.rw-r--r-- 714 firaswtips 27 Dec 2022 ο inputrc
.rw-r--r-- 608 firaswtips 8 Jan 03:38 ξ ipsec.conf
.rw------- 48 firaswtips 8 Jan 03:38 ο
ipsec.secrets
.rw-r--r-- 1.4k firaswtips 31 Oct 2022 ο’ irqbalance.env
.rw-r--r-- 22 firaswtips 9 Feb 21:14 ο issue
.rw-r--r-- 369 firaswtips 6 Dec 2022 ξ krb5.conf
.rw-r--r-- 1.2k firaswtips 8 Jun 2021 ο ksysguarddrc
.rw-r--r-- 145k root 10 Feb 14:26 ο
ld.so.cache
.rw-r--r-- 117 firaswtips 31 Jan 21:51 ξ ld.so.conf
.rw-r----- 191 firaswtips 30 Jan 18:47 ξ libaudit.conf
.rw-r--r-- 8.6k firaswtips 5 Nov 2022 ξ libinput-gestures.conf
.rw-r--r-- 24 firaswtips 26 Dec 2022 ξ libva.conf
.rw-r--r-- 17 firaswtips 9 Feb 21:28 ξ locale.conf
.rw-r--r-- 10k firaswtips 9 Feb 21:28 ο
locale.gen
lrwxrwxrwx 33 firaswtips 9 Feb 21:05 ο localtime -> /usr/share/zoneinfo/Europe/Berlin
.rw-r--r-- 8.2k firaswtips 25 Jan 09:29 ο
login.defs
.rw-r--r-- 686 firaswtips 14 Dec 2022 ξ logrotate.conf
.rw-r--r-- 102 firaswtips 9 Feb 21:14 ο lsb-release
.r--r--r-- 33 firaswtips 9 Feb 21:05 ο machine-id
.rw-r--r-- 272 firaswtips 4 May 2021 ο mailcap
.rw-r--r-- 6.2k firaswtips 1 Nov 2022 ξ makepkg.conf
.rw-r--r-- 5.2k firaswtips 9 Jan 08:18 ξ man_db.conf
.rw-r--r-- 2.3k firaswtips 30 Mar 2022 ξ mdadm.conf
.rw-r--r-- 23 firaswtips 19 Oct 2022 ξ mhwd-x86_64.conf
.rw-r--r-- 70k firaswtips 4 May 2021 ο
mime.types
.rw-r--r-- 782 firaswtips 2 Feb 21:00 ξ mke2fs.conf
.rw-r--r-- 2.6k firaswtips 9 Feb 21:06 ξ mkinitcpio.conf
.rw-r--r-- 2.8k firaswtips 8 Dec 2022 ο
mkinitcpio.conf.pacnew
lrwxrwxrwx 19 firaswtips 31 Jan 21:51 ο mtab -> ../proc/self/mounts
.rw-r--r-- 2.6k firaswtips 22 Oct 2022 ξ mtools.conf
.rw-r----- 1.2k firaswtips 27 Jan 21:20 ξ named.conf
.rw-r--r-- 11k firaswtips 18 Jan 14:50 ο nanorc
.rw-r--r-- 767 firaswtips 15 Nov 2022 ο netconfig
.rw-r--r-- 1.5k firaswtips 9 Aug 2022 ξ nfs.conf
.rw-r--r-- 3.6k firaswtips 9 Aug 2022 ξ nfsmount.conf
.rw-r--r-- 846 firaswtips 22 Dec 2022 ξ nftables.conf
.rw-r--r-- 2.5k firaswtips 27 Dec 2022 ξ nilfs_cleanerd.conf
.rw-r--r-- 2.7k firaswtips 3 Feb 19:27 ξ nscd.conf
.rw-r--r-- 390 firaswtips 19 Oct 2022 ξ nsswitch.conf
.rw-r--r-- 0 firaswtips 11 May 2022 ο
Ί odbc.ini
Ί odbcinst.ini
.rw-r--r-- 665 firaswtips 5 Nov 2022 ξ openswap.conf
lrwxrwxrwx 21 firaswtips 19 Oct 2022 ο os-release -> ../usr/lib/os-release
.rw-r--r-- 748 firaswtips 19 Oct 2022 ξ pacman-mirrors.conf
.rw-r--r-- 5.1k firaswtips 10 Feb 10:58 ξ pacman.conf
.rw-r--r-- 1.2k firaswtips 19 Oct 2022 ξ pamac.conf
.rw-r--r-- 1.2k firaswtips 5 Nov 2022 ο
pamac.conf.pacnew
.rw-r--r-- 68 firaswtips 21 May 2022 ο papersize
.rw-r--r-- 425 firaswtips 19 Oct 2022 ξ paru.conf
.rw-r--r-- 1.9k firaswtips 10 Feb 01:10 ο passwd
.rw-r--r-- 1.8k firaswtips 9 Feb 21:27 ο passwd-
.rw-r--r-- 323 firaswtips 5 Nov 2022 ξ ppl.conf
.rw-r--r-- 5.3k firaswtips 5 Nov 2022 ξ preload.conf
.rw-r--r-- 1.0k firaswtips 31 Jan 21:51 ο profile
.rw-r--r-- 3.2k firaswtips 18 Dec 2022 ο protocols
.rw-r--r-- 220 firaswtips 6 Nov 2022 ο quotagrpadmins
.rw-r--r-- 261 firaswtips 6 Nov 2022 ο quotatab
.rw-r--r-- 7.7k firaswtips 31 Oct 2021 ξ rc_maps.cfg
.rw-r--r-- 1.8k firaswtips 7 Jul 2020 ξ request-key.conf
.rw-r--r-- 49 root 10 Feb 14:26 ξ resolv.conf
.rw-r--r-- 255 firaswtips 30 Dec 2020 ξ resolvconf.conf
.rw-r--r-- 1.6k firaswtips 3 Feb 19:27 ο rpc
.rw-r--r-- 172 firaswtips 20 Dec 2022 ξ rsyncd.conf
.rw-r--r-- 0 firaswtips 10 Feb 00:21 ξ sddm.conf
.rw-r--r-- 139 firaswtips 31 Jan 21:51 ο securetty
.rw-r--r-- 11k firaswtips 17 Nov 2022 ξ sensors3.conf
.rw-r--r-- 299k firaswtips 18 Dec 2022 ο services
.rw------- 1.0k firaswtips 10 Feb 01:10 ο shadow
.rw------- 990 firaswtips 9 Feb 21:22 ο shadow-
.rw-r--r-- 152 firaswtips 9 Feb 21:13 ο shells
.rw-r--r-- 94 firaswtips 31 Jan 21:51 ο
shells.pacnew
.rw-r--r-- 1.8k firaswtips 9 Mar 2022 ξ signond.conf
.rw-r--r-- 2.0k firaswtips 27 Dec 2022 ο
slsh.rc
.rw-r--r-- 6.7k firaswtips 1 Mar 2022 ξ smartd.conf
.rw-r--r-- 1.6k firaswtips 7 Dec 2022 ο
Ί snap-pac.ini
.rw-r--r-- 281 firaswtips 8 Jan 03:38 ξ strongswan.conf
.rw-r--r-- 0 firaswtips 31 Jan 21:51 ο subgid
.rw-r--r-- 0 firaswtips 31 Jan 21:51 ο subuid
.rw-r--r-- 4.6k firaswtips 18 Jan 16:45 ξ sudo.conf
.rw-r--r-- 9.8k firaswtips 18 Jan 16:45 ξ sudo_logsrvd.conf
.r--r----- 3.3k firaswtips 18 Jan 16:45 ο sudoers
.rw-r--r-- 14 firaswtips 9 Feb 21:05 ο timezone
.rw-r--r-- 738 firaswtips 13 Oct 2020 ο
trusted-key.key
.rw-r--r-- 938 firaswtips 1 Jul 2020 ξ ts.conf
.rw-r--r-- 628 firaswtips 19 Oct 2022 ξ updatedb.conf
.rw-r--r-- 1.5k firaswtips 8 Mar 2022 ξ usb_modeswitch.conf
.rw-r--r-- 79k firaswtips 8 Mar 2022 ο
usb_modeswitch.setup
.rw-r--r-- 24 firaswtips 9 Feb 21:05 ξ vconsole.conf
.rw-r--r-- 51 firaswtips 12 Mar 2022 ξ vdpau_wrapper.cfg
.rw-r--r-- 3.9k firaswtips 6 Nov 2022 ξ warnquota.conf
.rw-r--r-- 5.0k firaswtips 20 Mar 2022 ο wgetrc
.rw-r--r-- 380 firaswtips 28 Dec 2022 ξ whois.conf
.rw-r--r-- 681 firaswtips 1 Feb 2022 ξ xattr.conf
.rw-r--r-- 2.0k firaswtips 27 Jan 19:44 ξ xtables.conf
Firas
10 February 2023 13:39
9
It looks like you have recursively chown'd some directories that should be owned by root. In its current state, your system is very broken. It will not be simple to manually fix; I recommend restoring a snapshot from before that decision was made.
Firas
10 February 2023 13:42
11
then it must be the right-click option root actions / own
system
Closed
12 February 2023 13:43
12
