Hyprland upgrade and plugins
Today I updated and got an new version of hyprland. Because I’m using a plugin (hy3) the upgrade isn’t exactly smooth… It comes back up with errors in the config file 'cause it doesn’t load the plugin because it’s now outdated. In order to make it work, I had to run hyprpm update, hyprpm reload, and hyprpm enable hy3. I also rebooted 'cause things weren’t going exactly smoothly (see below). What is the “correct” process? (I think I first have to log out and back in so the new version of hyprland actually runs and hyprpm compiles against that?) Is there a way this can happen automatically when a new version of hyprland comes out?
(I also noticed that if I log out and log back in then hyprctl doesn’t work 'cause the control socket isn’t working. Has someone else noticed this or should I open an issue for that?)
inxi:
  Kernel: 6.14.6-1-clear arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-clear
    root=UUID=941fde7f-dd53-42fc-87e1-085c47990c6b rw rootflags=subvol=@
    quiet rd.luks.uuid=f4353337-f608-4153-8516-712c2bdd741a
    rd.luks.uuid=bb53fa49-4911-4abe-a164-e31688cc2ebd
    resume=/dev/mapper/luks-bb53fa49-4911-4abe-a164-e31688cc2ebd loglevel=3
    nvme.noacpi=1 ibt=off
  Desktop: Hyprland v: 0.49.0 with: waybar tools: swayidle avail: swaylock
    vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Laptop System: Framework product: Laptop (13th Gen Intel Core) v: A6
  Mobo: Framework model: FRANMCCP06 v: A6 serial: <superuser required>
    part-nu: FRANDECP06 uuid: <superuser required> UEFI: INSYDE v: 03.04
    date: 05/24/2023
  ID-1: BAT1 charge: 54.4 Wh (95.9%) condition: 56.7/60.7 Wh (93.5%)
    volts: 17.4 min: 15.5 model: NVT FRANGWA type: Li-ion serial: <filter>
    status: charging cycles: 38
  Info: model: 13th Gen Intel Core i7-1360P bits: 64 type: MST AMCP
    arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
    family: 6 model-id: 0xBA (186) stepping: 2 microcode: 0x4128
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
    st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
    KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 400 min/max: 400/5000:3700 scaling: driver: intel_pstate
    governor: performance cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400
    7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400
    16: 400 bogomips: 83558
  Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: Framework driver: i915
    v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
    active: DP-2,DP-4,eDP-1 empty: DP-1,DP-3 bus-ID: 00:02.0
    chip-ID: 8086:a720 class-ID: 0300
  Device-2: Realtek Laptop Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:4 chip-ID: 0bda:5634
    compositor: Hyprland v: 0.49.0 driver: X: loaded: modesetting
    alternate: fbdev,intel,vesa dri: iris gpu: i915 d-rect: 8656x5104
    display-ID: 1
  Monitor-1: DP-2 pos: middle-l model: LG (GoldStar) Ultra HD
    serial: <filter> built: 2017 res: mode: 3840x2160 hz: 60 scale: 120% (1.2)
    to: 3202x1801 dpi: 163 gamma: 1.2 size: 600x340mm (23.62x13.39")
    diag: 690mm (27.2") ratio: 16:9 modes: max: 3840x2160 min: 640x480
  Monitor-2: DP-4 pos: top-right model: BenQ PD2500Q serial: <filter>
    built: 2020 res: mode: 2560x1440 hz: 60 scale: 90% (0.9) to: 2849x1602
    dpi: 118 gamma: 1.2 size: 553x311mm (21.77x12.24") diag: 634mm (25")
    ratio: 16:9 modes: max: 2560x1440 min: 720x400
  Monitor-3: eDP-1 pos: bottom-c model: BOE Display 0x0bca built: 2022 res:
    mode: 2256x1504 hz: 60 scale: 125% (1.25) to: 1804x1203 dpi: 201 gamma: 1.2
    size: 285x190mm (11.22x7.48") diag: 343mm (13.5") ratio: 3:2
    modes: 2256x1504
  API: Vulkan v: 1.4.313 layers: 5 device: 0 type: integrated-gpu
    name: Intel Graphics (RPL-P) driver: mesa intel v: 25.0.5-arch1.1
    device-ID: 8086:a720 surfaces: N/A device: 1 type: cpu name: llvmpipe
  Info: Tools: api: vulkaninfo wl: kanshi, nwg-displays, wdisplays,
    wlr-randr x11: xprop,xrandr
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Framework
    bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0403
  API: ALSA v: k6.14.6-1-clear status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: aa:00.0
  IF: wlp170s0 state: up mac: <filter>
  Device-2: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.3:4 chip-ID: 0b95:1790
  IF: usb10 state: up speed: 1000 Mbps duplex: half mac: <filter>
  Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:7 chip-ID: 8087:0032
  Local Storage: total: 931.51 GiB used: 381.85 GiB (41.0%)
    model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 620311WD temp: 40.9 C scheme: GPT
  ID-1: / raw-size: 897.05 GiB size: 897.05 GiB (100.00%)
    used: 381.85 GiB (42.6%) fs: btrfs dev: /dev/dm-1 maj-min: 252:1
    mapped: luks-f4353337-f608-4153-8516-712c2bdd741a
    used: 776 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 897.05 GiB size: 897.05 GiB (100.00%)
  ID-4: /var/log raw-size: 897.05 GiB size: 897.05 GiB (100.00%)
  ID-5: /var/tmp raw-size: 897.05 GiB size: 897.05 GiB (100.00%)
  ID-1: swap-1 type: partition size: 34.17 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-0 maj-min: 252:0
    mapped: luks-bb53fa49-4911-4abe-a164-e31688cc2ebd
  ID-2: swap-2 type: zram size: 31.05 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lz4,deflate max-streams: 16 dev: /dev/zram0
  System Temperatures: cpu: 63.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 3575
  Memory: total: 32 GiB note: est. available: 31.05 GiB
    used: 15.22 GiB (49.0%)
  Processes: 438 Power: uptime: 18m states: freeze,mem,disk suspend: s2idle
    suspend, test_resume image: 12.4 GiB services: thermald,upowerd
  Packages: pm: pacman pkgs: 1638 libs: 458 tools: octopi,pacseek,paru
    pm: appimage pkgs: 0 Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi
    default: fish v: 4.0.2 running-in: tmux: inxi: 3.3.38
  System install date:     2023-09-30
  Last full system update: 2025-05-21
  Relevant software:       snapper tlp NetworkManager dracut
