Hi, I’m trying to configure two monitors (change position screen, scale) but it doesn’t save the configuration in .hyprland.conf at all. Has anyone managed to save after reboot?
root=UUID=aa4eb384-7a43-4915-9a5c-a8909c47b2db rw rootflags=subvol=@
quiet resume=UUID=0ffec380-e955-4da5-a925-e330cdf15770 loglevel=3 ibt=off
Type: Desktop Mobo: N/A model: X99-GT v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: 5.11 date: 11/30/2020
Info: model: Intel Xeon E5-2620 v3 bits: 64 type: MT MCP arch: Haswell
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3F (63) stepping: 2 microcode: 0x49
L3: 15 MiB desc: 1x15 MiB
Speed (MHz): avg: 1650 high: 3200 min/max: 1200/3200 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1200 2: 1200 3: 2600
4: 1200 5: 1200 6: 1200 7: 1200 8: 1200 9: 3200 10: 1200 11: 3200 12: 1200
bogomips: 57597
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: Hightech Information System
active: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 03:00.0 chip-ID: 1002:67ef
class-ID: 0300 temp: 35.0 C
compositor: Hyprland driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3286x1080
display-ID: 1
Monitor-1: DP-1 pos: primary,left model: SFP2701G FHD serial: <filter>
built: 2022 res: 1920x1080 hz: 120 dpi: 81 gamma: 1.2 scale: 1
Monitor-2: HDMI-A-1 pos: right model: HDMI serial: <filter> built: 2022
res: 1366x768 hz: 60 dpi: 85 gamma: 1.2 scale: 2
size: 410x230mm (16.14x9.06") diag: 470mm (18.51") modes: max: 1366x768
min: 720x400
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: discrete-gpu name: AMD
Radeon RX 460 Graphics (RADV POLARIS11) driver: mesa radv
v: 23.2.1-arch1.2 device-ID: 1002:67ef surfaces: xcb,xlib,wayland
device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits)
driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Hightech Information System driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 03:00.1 chip-ID: 1002:aae0
Server-2: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2725
IF: wls2 state: up mac: <filter>
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:3 chip-ID: 8087:0032
Local Storage: total: 704.24 GiB used: 389.05 GiB (55.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: NX-256 size: 238.47 GiB
tech: SSD serial: <filter> fw-rev: SN08381 temp: 34.9 C scheme: GPT
model: WD5000AAKX-00U6AA0 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 1H15 scheme: MBR
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 7.91 GiB (3.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.0 C mobo: N/A gpu: amdgpu temp: 35.0 C
Processes: 316 Uptime: 2h 29m wakeups: 0 Memory: total: 8 GiB
available: 7.67 GiB used: 2.37 GiB (30.9%) Init: systemd v: 254
pm: pacman pkgs: 1339 libs: 404 tools: paru Shell: fish v: 3.6.1
running-in: foot inxi: 3.3.31
Garuda (2.6.17-1):
System install date: 2023-11-02
Last full system update: 2023-11-03 ↻
hyprctl monitors
Monitor DP-1 (ID 0):
1920x1080@120.00000 at 0x0
description: WAM SFP2701G FHD 0000000000001 (DP-1)
make: WAM
model: SFP2701G FHD
serial: 0000000000001
active workspace: 1 (1)
special workspace: 0 ()
reserved: 0 40 0 0
scale: 1.00
transform: 0
focused: yes
dpmsStatus: 1
vrr: 0
activelyTearing: false
Monitor HDMI-A-1 (ID 1):
1366x768@59.79000 at 1920x0
description: IPS, Inc. (Intellectual Property Solutions, Inc.) HDMI 0x00000001 (HDMI-A-1)
make: IPS, Inc. (Intellectual Property Solutions, Inc.)
model: HDMI
serial: 0x00000001
active workspace: 2 (2)
reserved: 0 40 0 0
scale: 2.00
transform: 0
focused: no
dpmsStatus: 1
vrr: 0
