hey, i have seen another post kinda similar to my problem, however the post was about the install process as far as i have understood it, my problem with hyprland is that the live iso just displays a gray display after logging in, no keybind i tried did anything… i first tried it on an vm on my desktop and thought well, the website said there can be problems with vms… then i tried it on my pc without an vm, gray display after logging in. then tried it on my laptop. same problem. both are using amd processors, maybe that’s relevant? if there are any useful logs please tell me where i can find them and also how i can get to them, also i have tried both the garuda hyprland login-option and the normal hyprland one, both have the same problem for me
As always, we need the garuda-inxi, Hyprland doesn’t run on every hardware, for whatever reason. Unfortunately.
You should also check the download (shasum) and whether the USB stick was safely removed.
If you are not an experienced Linux user or use an Nvidia GPU, you should not install Hyprland.
Hyprland is really awesome, but unfortunately it doesn’t run on every hardware.
or if sway works on your system you can transform it to hyprland following the guide we have on forum.
i did verify the sha sum and also safely ejected the usb stick. here’s the inxi of my laptop:
Kernel: 6.5.8-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: hpet available: acpi_pm parameters: pti=on
root=UUID=d16ddc96-5d12-402f-bbcb-9fa585484f0b rw rootflags=subvol=@
cryptdevice=UUID=3c647ba3-56c7-43a5-bafc-5f6213b05312:luks-3c647ba3-56c7-43a5-bafc-5f6213b05312
root=/dev/mapper/luks-3c647ba3-56c7-43a5-bafc-5f6213b05312
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82C7 v: Lenovo V15-ADA
serial: <superuser required> Chassis: type: 10 v: Lenovo V15-ADA
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
UEFI: LENOVO v: E8CN30WW date: 07/28/2021
ID-1: BAT0 charge: 7.8 Wh (25.0%) condition: 31.2/35.3 Wh (88.5%)
power: 7.4 W volts: 7.3 min: 7.6 model: CPT-COS L16C2PB1 type: Li-poly
serial: <filter> status: discharging cycles: 198
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1715 high: 2393 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2016 2: 2135
3: 1197 4: 1200 5: 2393 6: 2381 7: 1198 8: 1203 bogomips: 33550
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 34.0 C
Device-2: IMC Networks [] driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:5a08
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Monitor-1: eDP-1 model: BOE Display 0x0812 built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics (raven
LLVM 16.0.6 DRM 3.54 6.5.8-hardened1-1-hardened) device-ID: 1002:15d8
memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.269 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:15d8 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Vega 8 Graphics driver: amd v: (AMD proprietary shader
compiler) device-ID: 1002:15d8 surfaces: xcb,xlib device: 2 type: cpu
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.6
API: ALSA v: k6.5.8-hardened1-1-hardened status: kernel-api tools: N/A
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 48.0 C
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3
chip-ID: 0cf3:e300 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: disabled
Local Storage: total: 700.51 GiB used: 310.12 GiB (44.3%)
model: MZALQ512HALU-000L2 size: 476.94 GiB block-size: physical: 512 B
fw-rev: BL2QFXV7 temp: 22.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
tech: SSD serial: <filter> fw-rev: 041
used: 310.09 GiB (66.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-3c647ba3-56c7-43a5-bafc-5f6213b05312
used: 29.8 MiB (10.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 17.45 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-48d04c79-6793-4578-a7bd-b7f3baa922dc
System Temperatures: cpu: 35.0 C mobo: N/A gpu: amdgpu temp: 35.0 C
Processes: 309 Uptime: 3m wakeups: 1 Memory: total: 20 GiB note: est.
available: 17.45 GiB used: 3.22 GiB (18.5%) Init: systemd v: 254
Packages: 1805 pm: pacman pkgs: 1756 libs: 428 tools: paru pm: flatpak
pkgs: 49 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2022-06-18
Last full system update: 2023-10-30
here’s the one from my desktop, tho it’s just copied from an older post of mine, however there shouldn’t have been many changes:
Kernel: 6.5.3-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=6104ec12-31c8-4149-b0f4-da54e147aa2b rw rootflags=subvol=@
rd.luks.uuid=a2fc9904-d25f-4977-ac91-c799b10c769a rd.udev.log_priority=3
vt.global_cursor_default=0
rd.luks.uuid=46b27a70-db7b-45e9-b0fd-5795061b5d01
resume=/dev/mapper/luks-46b27a70-db7b-45e9-b0fd-5795061b5d01 loglevel=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Desktop Mobo: Micro-Star model: B450-A PRO MAX (MS-7B86) v: 4.0
serial: <superuser required> UEFI: American Megatrends LLC. v: M.J0
date: 06/30/2023
Info: model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2783 high: 3129 min/max: 400/4267 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2996 2: 2993 3: 2989
4: 2994 5: 2993 6: 2983 7: 2993 8: 2950 9: 2990 10: 3129 11: 400 12: 2997
bogomips: 86274
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASUSTeK
active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 12:00.0 chip-ID: 1002:73ff
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: right model: HP V22e
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: Samsung C24F390 serial: <filter> built: 2019 res: 1920x1080 hz: 60
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: AMD Radeon RX 6600
(navi23 LLVM 16.0.6 DRM 3.54 6.5.3-arch1-1) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.1 chip-ID: 1002:ab28
Device-2: AMD Renoir Radeon High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.1 chip-ID: 1002:1637
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.6 chip-ID: 1022:15e3
Device-4: JMTek LLC. USB PnP Audio Device
lanes: 1 mode: 1.1 bus-ID: 3-2.2:4 chip-ID: 0c76:161e class-ID: 0300
API: ALSA v: k6.5.3-arch1-1 status: kernel-api tools: N/A
lanes: 1 port: e000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 4.09 TiB used: 753.54 GiB (18.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 27.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500LX005-1CW162
tech: HDD rpm: 5400 serial: <filter> fw-rev: LVD1 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: <filter> fw-rev: 054
ID-1: / raw-size: 914.15 GiB size: 914.15 GiB (100.00%)
used: 601.4 GiB (65.8%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-a2fc9904-d25f-4977-ac91-c799b10c769a
ID-3: /home raw-size: 914.15 GiB size: 914.15 GiB (100.00%)
ID-4: /var/log raw-size: 914.15 GiB size: 914.15 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.15 GiB size: 914.15 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.06 GiB used: 0 KiB (0.0%)
mapped: luks-46b27a70-db7b-45e9-b0fd-5795061b5d01
ID-2: swap-2 type: zram size: 31.24 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.6 C mobo: N/A gpu: amdgpu temp: 33.0 C
mem: 34.0 C
Processes: 384 Uptime: 1h 20m wakeups: 0 Memory: total: 32 GiB
available: 31.24 GiB used: 10.68 GiB (34.2%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1702
pm: pacman pkgs: 1651 libs: 432 tools: octopi,paru pm: flatpak pkgs: 51
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date: 2023-04-12
Last full system update: 2023-09-20
if you need anything else please let me know. by the way, both systems also use an amd graphics processor, my laptop got an amd apu and my desktop pc got an “real” graphics card
i just tried that, however yay and paru (from what i know they’re basically the same) both can’t find the xdg-desktop-hyprland-git (nor an not git version), and since it sounds pretty important i don’t think it’ll work without that, am i missing some mirrors? garuda, core, extra, community, multilib and chaotic-aur got synced without any errors
Perhaps these are what you are looking for.
chaotic-aur/xdg-desktop-portal-hyprland-git 1:r322.22e7a65-1 [207.43KiB 544.25KiB]
xdg-desktop-portal backend for hyprland
extra/xdg-desktop-portal-hyprland 1.2.3-1 [130.38KiB 350.25KiB]
thank you, and for the polkit-kde-git i assume polkit-kde-agent-git? also does it make any difference if i use yay or paru to install the packages?
yes, you can also take a look at the latest comments under the post.
No, yay is an alias to paru so the command execute the same binary.
thank you, another problem now is that it said the line 62 in the hypr config file “no such field” (the one with the blur_new_optimizations = on) and commenting it out makes it say that now line 61 “no such field”… also back to the main reason for this thread, i also tried the same iso on an intel-based mini-pc and i get the exact same error… and i again verified the checksum on the iso
What is the name of the ISO?
garuda-hyprland-linux-zen-231029.iso
And now you are on metal and installation works?
Can you please post the garuda-inxi from this install?
Take a look at hyprland’s gitlab repo for that. Those config files on the tutorial are old and a lot of stuff has changed.
hyprland config: etc/skel/.config/hypr/hyprland.conf · main · Garuda Linux 🦅 / Themes and Settings / Settings / Garuda Hyprland Settings · GitLab
The two files above it in tutorial: usr/local/bin · main · Garuda Linux 🦅 / Themes and Settings / Settings / Garuda Hyprland Settings · GitLab
I believe you can place the files in the /etc/skel and other dirs from gitlab repo in their right places. ![]()
i am sorry, the current “working” system is an sway i’m trying to change to hyprland, if you want the inxi of that one here it is:
Kernel: 6.5.9-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: hpet
available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=8c0f6154-7950-4521-8764-3ec8b13a222c rw rootflags=subvol=@ quiet
rd.luks.uuid=0633b2ba-e6de-4462-b994-477ccdab2593
rd.luks.uuid=7cc13310-7938-457a-b668-31a97fee1a85
resume=/dev/mapper/luks-7cc13310-7938-457a-b668-31a97fee1a85 loglevel=3 ibt=off
Console: pty pts/1 DM: greetd Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82C7 v: Lenovo V15-ADA serial: <superuser required>
Chassis: type: 10 v: Lenovo V15-ADA serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required> UEFI: LENOVO
ID-1: BAT0 charge: 23.8 Wh (74.4%) condition: 32.0/35.3 Wh (90.8%) power: 6.8 W volts: 7.8
min: 7.6 model: CPT-COS L16C2PB1 type: Li-poly serial: <filter> status: discharging cycles: 199
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen/Zen+
note: check gen: 1 level: v3 note: check built: 2019 process: GF 12nm family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1470 high: 2100 min/max: 1400/2100 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400 4: 1400 5: 2100 6: 1375
7: 1288 8: 1400 bogomips: 33535
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series] vendor: Lenovo
driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:15d8 class-ID: 0300 temp: 34.0 C
Device-2: IMC Networks [] driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:5a08 class-ID: 0e02 serial: <filter>
Display: server: Xwayland v: 23.2.2 compositor: Hyprland driver: gpu: amdgpu tty: 190x50
Monitor-1: eDP-1 model: BOE Display 0x0812 built: 2018 res: 1920x1080 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: AMD Radeon Vega 8
Graphics (RADV RAVEN) driver: mesa radv v: 23.2.1-arch1.2 device-ID: 1002:15d8 surfaces: N/A
device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: N/A
Use of uninitialized value $val2 in string eq at /usr/bin/inxi line 7454.
Use of uninitialized value $val2 in split at /usr/bin/inxi line 7459.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 7462.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 7465.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 7466.
API: EGL Message:
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse status: off 2: wireplumber
status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Lenovo
driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 168c:003e class-ID: 0280 temp: 39.0 C
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.4:3 chip-ID: 0bda:8153 class-ID: 0000
IF: enp3s0f3u4u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 0cf3:e300 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: <filter> bt-v: 4.2 lmp-v: 8 status: discoverable: no
pairing: no
Local Storage: total: 700.51 GiB used: 6.55 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HALU-000L2 size: 476.94 GiB
fw-rev: BL2QFXV7 temp: 20.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 041
ID-1: / raw-size: 204.09 GiB size: 204.09 GiB (100.00%) used: 6.55 GiB (3.2%) fs: btrfs
dev: /dev/dm-1 maj-min: 254:1 mapped: luks-0633b2ba-e6de-4462-b994-477ccdab2593
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 720 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 204.09 GiB size: 204.09 GiB (100.00%) used: 6.55 GiB (3.2%) fs: btrfs
ID-4: /var/log raw-size: 204.09 GiB size: 204.09 GiB (100.00%) used: 6.55 GiB (3.2%) fs: btrfs
ID-5: /var/tmp raw-size: 204.09 GiB size: 204.09 GiB (100.00%) used: 6.55 GiB (3.2%) fs: btrfs
ID-1: swap-1 type: partition size: 19.18 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-0
maj-min: 254:0 mapped: luks-7cc13310-7938-457a-b668-31a97fee1a85
ID-2: swap-2 type: zram size: 17.44 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 34.9 C mobo: N/A gpu: amdgpu temp: 34.0 C
Processes: 232 Uptime: 16m wakeups: 1 Memory: total: 20 GiB note: est. available: 17.44 GiB
used: 1.03 GiB (5.9%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman pkgs: 1254 libs: 367 tools: paru pm: flatpak
pkgs: 0 Shell: Bash v: 5.2.15 running-in: pty pts/1 (SSH) inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-31
Last full system update: 2023-10-31
thank you, while in my opinion ugly (it changed the theme), it does work now as far as i can tell
BTW, I install this
on my Notebook, no problems.
Hyprland is far from perfect. ![]()
It is on version 0.31
This is another problem, and do not fit to the headline Hyprland not working after iso-login.
If it doesn’t work on your hardware yet, you should try again later. It’s no coincidence that it’s listed under the “For Experienced Users only” section.
Hmm I have live ISO of sway and hyprland in my ventoy USB and honestly I haven’t spotted a lot of differences between them (then again I haven’t installed and explored them deeply enough) so perhaps this is a config issue? or as you say theme issue in which case you can just change it.
i am not sure what to do now, i mean the modified sway works now, however the iso is (obviously) still broken, is there something i could do to help with anything so the iso either works on the machines i tested (i really don’t care about the mini pc tho) or for the next iso version to work?
I tested this ISO also and did not have any issues like you describe. The live environment booted normally, installation had no problems, and booted to the desktop without any issue. No grey screen, no issues with keybindings. The consensus on the team is this is a good ISO. If it doesn’t work for you, it may indicate an issue with your specific hardware or configuration choices.
so basically there is nothing i can do… i just find it very unlikely for three seperate systems to have the very same problem… well that’s me… is there anything to read through for the config files, the overall desktop view etc. or do i just have to read through all config files i think could be relevant? especially for keybinds this could be very helpful
