Those are just some questions in my mind as I am a nub in Hyprland…
I wanna know if that happens in my case or others…
- can someone please tell me how to do night-light in hyprland ?
- And is kde-connect not working in hyprland?
another thing to notify:
- that james DSP not work crashes, and not launching
Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
root=UUID=cef7463d-ac6e-4d76-a945-b8002b8e34ff rw rootflags=subvol=@ quiet
resume=UUID=d194e71c-09c2-4434-8f35-8dfb9c05c716 loglevel=3 ibt=off
Desktop: Hyprland v: 0.35.0-83-g8c361363 with: waybar tools: avail: swayidle,swaylock vt: 1
Type: Laptop System: Hewlett-Packard product: HP Pavilion 15 Notebook PC
v: 098C110000404100000610180 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 2186 v: 35.12 serial: <superuser required> part-nu: F6C93PA#ACJ
uuid: <superuser required> UEFI: Insyde v: F.30 date: 10/03/2013
ID-1: BAT0 charge: 12.3 Wh (37.0%) condition: 33.2/33.2 Wh (100.0%) volts: 13.9 min: 14.8
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: discharging
Info: model: Intel Core i3-3217U bits: 64 type: MT MCP arch: Ivy Bridge gen: core 3 level: v2
built: 2012-15 process: Intel 22nm family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1796 min/max: 800/1800 scaling: driver: intel_cpufreq governor: schedutil
cores: 1: 1796 2: 1796 3: 1796 4: 1796 bogomips: 14366
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard driver: i915 v: kernel
arch: Gen-7 process: Intel 22nm built: 2012-13 ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 05c8:036e class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4 compositor: Hyprland
v: 0.35.0-83-g8c361363 driver: X: loaded: modesetting alternate: fbdev,intel,vesa dri: crocus
gpu: i915 display-ID: 1
Monitor-1: LVDS-1 model: Samsung 0x4651 built: 2012 res: 1366x768 hz: 60 dpi: 101 gamma: 1.2
scale: 1 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
API: Vulkan v: 1.3.276 layers: 3 device: 0 type: integrated-gpu name: Intel HD Graphics 4000
(IVB GT2) driver: mesa intel v: 24.0.1-arch1.1 device-ID: 8086:0166 surfaces: xcb,xlib,wayland
device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 24.0.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Hewlett-Packard 7
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse status: active
Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Hewlett-Packard driver: rt2800pci
v: 2.3.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 1814:3290 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8136
Device-1: Ralink RT3290 Bluetooth vendor: Hewlett-Packard driver: N/A pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.1 chip-ID: 1814:3298 class-ID: 0d11
Local Storage: total: 465.76 GiB used: 17.58 GiB (3.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB block-size:
physical: 4096 B logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter> fw-rev: 2C
ID-1: / raw-size: 62.5 GiB size: 62.5 GiB (100.00%) used: 14.45 GiB (23.1%) fs: btrfs
dev: /dev/sda14 maj-min: 8:14
ID-2: /boot/efi raw-size: 800 MiB size: 798.4 MiB (99.80%) used: 584 KiB (0.1%) fs: vfat
dev: /dev/sda15 maj-min: 8:15
ID-3: /home raw-size: 99.48 GiB size: 99.48 GiB (100.00%) used: 3.13 GiB (3.1%) fs: btrfs
dev: /dev/sda16 maj-min: 259:0
ID-4: /var/log raw-size: 62.5 GiB size: 62.5 GiB (100.00%) used: 14.45 GiB (23.1%) fs: btrfs
ID-5: /var/tmp raw-size: 62.5 GiB size: 62.5 GiB (100.00%) used: 14.45 GiB (23.1%) fs: btrfs
ID-1: swap-1 type: zram size: 3.72 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
ID-2: swap-2 type: partition size: 4.06 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda13
maj-min: 8:13
System Temperatures: cpu: 47.0 C mobo: N/A
Memory: total: 4 GiB available: 3.72 GiB used: 2.11 GiB (56.8%)
Processes: 227 Power: uptime: 3m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 1.47 GiB
services: upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1308 libs: 373 tools: octopi,pacseek,paru Compilers: gcc: 13.2.1
Client: shell wrapper v: 5.2.26-release inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-01-27
Last full system update: 2024-02-23
i create this topic for this… if i need to provide more details … i will add them…
