Hyprland fresh install stuck at "Running mhwdcfg operations"
I have been a long term user of Gaurde KDE Dr460nized. After using NixOS with hyprland in a VM for awhile, i decided to switch over to Garuda’s Hyprland.
I have attempted with lots of tweaks in a bare metal desktop. I am trying to replace the current Garuda linux install.
  1. Fast boot and secure boot disabled
  2. checked the download, checked the sha256, attempted to reflash the usb drive a couple of time using etcher
  3. tried with and without UEFI
  4. tried disabling the wifi card and bluetooth.
  5. tried with free and proprietary nvidia drivers.
but no luck. below is the where the install is stuck
2024-11-04 - 12:23:29 [6]: [PYTHON JOB]: Found gettext "en_GB" in "/usr/share/locale/en_GB"
2024-11-04 - 12:23:29 [6]: [PYTHON JOB]: "lightdm selected but not installed"
2024-11-04 - 12:23:29 [6]: [PYTHON JOB]: "gdm selected but not installed"
2024-11-04 - 12:23:29 [6]: [PYTHON JOB]: "mdm selected but not installed"
2024-11-04 - 12:23:29 [6]: [PYTHON JOB]: "lxdm selected but not installed"
2024-11-04 - 12:23:29 [6]: [PYTHON JOB]: "slim selected but not installed"
2024-11-04 - 12:23:29 [6]: [PYTHON JOB]: "Using rootMountPoint '/tmp/calamares-root-vg7_90dp'"
2024-11-04 - 12:23:29 [6]: [PYTHON JOB]: ".. selected DE hyprland"
2024-11-04 - 12:23:29 [2]: Calamares::Python::Object Calamares::Python::GlobalStorageProxy::value(const std::string&) const
2024-11-04 - 12:23:29 [2]:     WARNING: Unknown GS key autoLoginUser
2024-11-04 - 12:23:29 [6]: [PYTHON JOB]: "Unsetting autologin."
2024-11-04 - 12:23:29 [6]: virtual void Calamares::JobThread::run()
2024-11-04 - 12:23:29 [6]:     Starting job "mhwdcfg" ( 30 / 36 )
2024-11-04 - 12:23:29 [6]:     .. Running QList("mhwd", "-a", "pci", "free", "0200", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2024-11-04 - 12:23:30 [6]:     .. Finished. Exit code: 0 output:
 e[1me[31mWarning: e[mNo config found for device: 0000:07:00.0 (0200:8086:2723) Network controller Intel Corporation Wi-Fi 6 AX200
e[1me[31mWarning: e[mNo config found for device: 0000:06:00.0 (0200:8086:1539) Network controller Intel Corporation I211 Gigabit Network Connection
e[1me[31mWarning: e[mNo config found for device: 0000:05:00.0 (0200:1d6a:11b1) Network controller Aquantia Corp. AQC111 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion]
2024-11-04 - 12:23:30 [6]:     .. Running QList("mhwd", "-a", "pci", "free", "0280", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
 e[1me[31mWarning: e[mNo device of class 0280 found!
2024-11-04 - 12:23:30 [6]:     .. Running QList("mhwd", "-a", "pci", "free", "0300", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
garuda-inxi output
  Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    misobasedir=garuda root=miso:LABEL=GARUDA_HYPRLAND_BIRDOFPREY quiet
    systemd.show_status=1 checksum=y driver=free nouveau.modeset=1
  Desktop: Hyprland v: 0.39.1 with: waybar tools: avail: swayidle,swaylock
    vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
  Mobo: ASUSTeK model: ROG CROSSHAIR VIII FORMULA v: Rev X.0x
    UEFI: American Megatrends v: 4006 date: 03/07/2022
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201205
  Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
    L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2333 high: 3400 min/max: 2200/5083 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
    3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 3400 10: 2200 11: 2875
    12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 17: 3400 18: 2200 19: 2200
    20: 2200 21: 2200 22: 2200 23: 2200 24: 2200 25: 2200 26: 2200 27: 2200
    28: 2200 29: 3400 30: 2200 31: 2200 32: 2200 bogomips: 217197
  Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: ASUSTeK driver: nouveau
    v: kernel non-free: 550.xx+ status: current (as of 2024-04; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: HDMI-A-1 empty: DP-1,DVI-D-1,HDMI-A-2 bus-ID: 0b:00.0
    chip-ID: 10de:1e89 class-ID: 0300
  Device-2: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.4.3:6
    chip-ID: 046d:085e class-ID: 0102 serial: <filter>
    compositor: Hyprland v: 0.39.1 driver: X: loaded: modesetting,nouveau
    alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: 1
  Monitor-1: HDMI-A-1 model: LG (GoldStar) HDR DQHD serial: <filter>
    built: 2021 res: 3840x1080 hz: 60 dpi: 81 gamma: 1.2 scale: 1
    size: 1198x337mm (47.17x13.27") diag: 1244mm (49") modes: max: 3840x1080
    min: 640x480
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: cpu name: llvmpipe (LLVM
    17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM 17.0.6)
  Device-1: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:10f8 class-ID: 0403
    bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
  Device-1: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
    vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 1 link-max: lanes: 4 port: N/A bus-ID: 05:00.0 chip-ID: 1d6a:11b1
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
  Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp7s0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0029
  Local Storage: total: 3.75 TiB used: 3.44 GiB (0.1%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 44.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 1TB
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
  ID-5: /dev/sdc maj-min: 8:32 vendor: SanDisk model: USB 3.2Gen1
    size: 114.6 GiB block-size: physical: 512 B logical: 512 B type: USB
    fw-rev: 1.00 scheme: MBR
  ID-1: swap-1 type: zram size: 62.7 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 68.97 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:10
  System Temperatures: cpu: 42.0 C mobo: 32.0 C
  Fan Speeds (rpm): cpu: 0
  Memory: total: 64 GiB note: est. available: 62.7 GiB used: 3.95 GiB (6.3%)
  Processes: 523 Power: uptime: 55m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.05 GiB services: upowerd Init: systemd
    v: 255 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1279 libs: 376 tools: pacseek,paru Compilers:
    gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: foot
    inxi: 3.3.34
  System install date:     2024-11-04
  Last full system update: 2024-11-04 ↻
Did you use Hyprland ISO from download page?
If, try dd
sudo dd bs=4M if=garuda.iso of=/dev/sdX  oflag=sync status=progress
Last time I must burn it two times with dd on the stick, etcher doesn’t work for me. BTW, if you download the 240428 ISO, ventoy will work too.
Next, use
sudo -E calamares -D8
on live ISO to install the OS.
If this has not been done before, it will shorten the issue if you want to post it here in case of another failure.
Thanks a ton, worked like a charm!
