I’ve been using the hyprland edition for a long time and today I did a garuda-update and now hyprland doesn’t start. When I enter my password into the greeter it flickers and is back. No hyprland in sight…
In a terminal session I tried hyprstart and get the following error:
Hyprland: error while loading shared libraries: libhyprutils.so.5: cannot open shared object file: No such file or directory
Running ldd /usr/bin/Hyprland | grep "not found" confirms:
libhyprutils.so.5 => not found
Here’s ls -l /usr/lib/libhypr*, note that there’s libhyprutils.so.6 not .so.5 there…:
lrwxrwxrwx 1 root root 18 Apr 29 13:33 /usr/lib/libhyprcursor.so -> libhyprcursor.so.0
lrwxrwxrwx 1 root root 23 Apr 29 13:33 /usr/lib/libhyprcursor.so.0 -> libhyprcursor.so.0.1.12
-rwxr-xr-x 1 root root 343016 Apr 29 13:33 /usr/lib/libhyprcursor.so.0.1.12
lrwxrwxrwx 1 root root 20 Apr 22 15:44 /usr/lib/libhyprgraphics.so -> libhyprgraphics.so.0
lrwxrwxrwx 1 root root 24 Apr 22 15:44 /usr/lib/libhyprgraphics.so.0 -> libhyprgraphics.so.0.1.3
-rwxr-xr-x 1 root root 157632 Apr 22 15:44 /usr/lib/libhyprgraphics.so.0.1.3
-rwxr-xr-x 1 root root 134304 Mar 10 19:46 /usr/lib/libhyprland-quick-style-impl.so
-rwxr-xr-x 1 root root 231568 Mar 10 19:46 /usr/lib/libhyprland-quick-style.so
lrwxrwxrwx 1 root root 16 Apr 22 18:41 /usr/lib/libhyprlang.so -> libhyprlang.so.2
-rwxr-xr-x 1 root root 214984 Apr 22 18:41 /usr/lib/libhyprlang.so.0.6.1
lrwxrwxrwx 1 root root 20 Apr 22 18:41 /usr/lib/libhyprlang.so.2 -> libhyprlang.so.0.6.1
lrwxrwxrwx 1 root root 17 Apr 29 19:47 /usr/lib/libhyprutils.so -> libhyprutils.so.6
-rwxr-xr-x 1 root root 223264 Apr 29 19:47 /usr/lib/libhyprutils.so.0.7.0
lrwxrwxrwx 1 root root 21 Apr 29 19:47 /usr/lib/libhyprutils.so.6 -> libhyprutils.so.0.7.0
I first had chaotic-aur/hyprland-git 0.48.1.r131.g0c73621-1 installed and I noticed that extra also has hyprland, so I pacman installed it (extra/hyprland 0.48.1-5) but that resulted in the same issue.
I then rebooted into a working snapshot, this is the first time I use this feature and I’m glad it’s there! In the wiki it says that “Once the boot process is completed you will be automatically prompted to restore the currently booted snapshot” but I saw no such thing (although I did see some errors briefly flash towards the tail end of the boot process. Is there something I need to do?
Kernel: 6.14.3-1-clear arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
avail: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-clear
root=UUID=941fde7f-dd53-42fc-87e1-085c47990c6b rw rootflags=subvol=@ quiet
rd.luks.uuid=f4353337-f608-4153-8516-712c2bdd741a
rd.luks.uuid=bb53fa49-4911-4abe-a164-e31688cc2ebd
resume=/dev/mapper/luks-bb53fa49-4911-4abe-a164-e31688cc2ebd loglevel=3 nvme.noacpi=1 ibt=off
Console: tty 4 DM: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: Framework product: Laptop (13th Gen Intel Core) v: A6
Mobo: Framework model: FRANMCCP06 v: A6 serial: <superuser required> part-nu: FRANDECP06
uuid: <superuser required> UEFI: INSYDE v: 03.04 date: 05/24/2023
ID-1: BAT1 charge: 54.5 Wh (96.0%) condition: 56.8/60.7 Wh (93.5%) volts: 17.4 min: 15.5
model: NVT FRANGWA type: Li-ion serial: <filter> status: discharging cycles: 38
Info: model: 13th Gen Intel Core i7-1360P bits: 64 type: MST AMCP arch: Raptor Lake level: v3
note: check built: 2022+ process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x4124
Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2 st: 8 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 400 min/max: 400/5000:3700 scaling: driver: intel_pstate
governor: performance cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400
10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400 bogomips: 83558
Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: Framework driver: i915 v: kernel
alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports: active: DP-2,DP-4,eDP-1
empty: DP-1,DP-3 bus-ID: 00:02.0 chip-ID: 8086:a720 class-ID: 0300
Device-2: Realtek Laptop Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 3-7:4 chip-ID: 0bda:5634 class-ID: 0e02 serial: <filter>
Display: unspecified server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915 tty: 225x75
Monitor-1: DP-2 model: LG (GoldStar) Ultra HD serial: <filter> built: 2017 res: 3840x2160
dpi: 163 gamma: 1.2 size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
Monitor-2: DP-4 model: BenQ PD2500Q serial: <filter> built: 2020 res: 2560x1440 dpi: 118
gamma: 1.2 size: 553x311mm (21.77x12.24") diag: 634mm (25") ratio: 16:9 modes: max: 2560x1440
min: 720x400
Monitor-3: eDP-1 model: BOE Display 0x0bca built: 2022 res: 2256x1504 dpi: 201 gamma: 1.2
size: 285x190mm (11.22x7.48") diag: 343mm (13.5") ratio: 3:2 modes: 2256x1504
API: Vulkan v: 1.4.309 layers: 6 device: 0 type: integrated-gpu name: Intel Graphics (RPL-P)
driver: mesa intel v: 25.0.4-arch1.1 device-ID: 8086:a720 surfaces: N/A device: 1 type: cpu
name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.0.4-arch1.1 (LLVM 19.1.7)
API: OpenGL Message: GL data unavailable in console, glxinfo missing.
Info: Tools: api: vulkaninfo wl: kanshi, nwg-displays, wdisplays, wlr-randr x11: xprop,xrandr
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Framework driver: snd_hda_intel v: kernel
alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0403
API: ALSA v: k6.14.3-1-clear status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.2 status: off with: 1: pipewire-pulse status: off 2: wireplumber
status: off 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: aa:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp170s0 state: up mac: <filter>
Device-2: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2 speed: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.3:4 chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
IF: usb10 state: down mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-10:7 chip-ID: 8087:0032 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.3 lmp-v: 12 status:
discoverable: no pairing: no class-ID: 10c
Local Storage: total: 931.51 GiB used: 274.49 GiB (29.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD BLACK SN850X 1000GB
serial: <filter> fw-rev: 620311WD temp: 40.9 C scheme: GPT
ID-1: / raw-size: 897.05 GiB size: 897.05 GiB (100.00%) used: 274.49 GiB (30.6%) fs: btrfs
dev: /dev/dm-1 maj-min: 252:1 mapped: luks-f4353337-f608-4153-8516-712c2bdd741a
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 768 KiB (0.3%) fs: vfat
ID-3: /home raw-size: 897.05 GiB size: 897.05 GiB (100.00%) used: 274.49 GiB (30.6%) fs: btrfs
ID-4: /var/log raw-size: 897.05 GiB size: 897.05 GiB (100.00%) used: 274.49 GiB (30.6%)
fs: btrfs dev: /dev/dm-1 maj-min: 252:1 mapped: luks-f4353337-f608-4153-8516-712c2bdd741a
ID-5: /var/tmp raw-size: 897.05 GiB size: 897.05 GiB (100.00%) used: 274.49 GiB (30.6%)
ID-1: swap-1 type: partition size: 34.17 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-0
maj-min: 252:0 mapped: luks-bb53fa49-4911-4abe-a164-e31688cc2ebd
ID-2: swap-2 type: zram size: 31.05 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lz4,deflate max-streams: 16 dev: /dev/zram0
System Temperatures: cpu: 68.0 C mobo: N/A
Fan Speeds (rpm): cpu: 6814
Memory: total: 32 GiB note: est. available: 31.05 GiB used: 3.59 GiB (11.6%)
Processes: 369 Power: uptime: 32m states: freeze,mem,disk suspend: s2idle avail: deep
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.4 GiB
services: thermald,upowerd Init: systemd v: 257 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1695 libs: 477 tools: octopi,pacseek,paru Compilers: clang: 19.1.7
gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2 running-in: tty 4 inxi: 3.3.38
System install date: 2023-09-30
Last full system update: 2025-05-02 ↻
Relevant software: snapper tlp NetworkManager dracut
